Headshok 1st Gear June 26, 2011 Share June 26, 2011 Hi guys, I'm thinking of blocking up my egr valve as the amt of carbon in my intake is quite scary. B4 I do so anyone knows the effects? Thanks in advance guys Cheers ↡ Advertisement Link to post Share on other sites More sharing options...
Xiaoming99 Neutral Newbie June 26, 2011 Share June 26, 2011 I removed removed mine, intake is now very clean, turbo also doesn't choke up that easily now. Only downside I can think of is increased emissions (but I still passed my inspection!) and a slightly longer time for engine to warm up Link to post Share on other sites More sharing options...
Headshok 1st Gear June 26, 2011 Author Share June 26, 2011 Thanks man!! Recently saw my intake,scary sia Link to post Share on other sites More sharing options...
Mona-vie 1st Gear June 26, 2011 Share June 26, 2011 Thanks man!! Recently saw my intake,scary sia Anything the cause dirty intake, your valve cover hose. It ducts engine oil vapor back into the intake manifold. You get lots of junk in the intake because of that. Link to post Share on other sites More sharing options...
Xiaoming99 Neutral Newbie June 27, 2011 Share June 27, 2011 If you are running bigger injectors the choke-up of carbon is even worse! Have seen manifolds with more than half choked with carbon. Causes many issues with VNT turbos as well. Check out extreme ways of clearing that unmovable carbon! ↡ Advertisement Link to post Share on other sites More sharing options...
SCHNELL Engine Oil 5W40
P2096 Check engine light
DIY engine oil change
