Mllcg 3rd Gear September 28, 2011 Share September 28, 2011 Im looking at http://www.mycarforum.com/index.php?autoco...p;product=22518 and http://www.mycarforum.com/index.php?autoco...p;product=24653 which is better in terms of improving the downforce and reducing drag? ↡ Advertisement Link to post Share on other sites More sharing options...
Wjhr 1st Gear September 28, 2011 Share September 28, 2011 22518 Carbon GT WING Adjustable Angle Comes with brackets aerodynamics better compare to other one design Link to post Share on other sites More sharing options...
Wjhr 1st Gear September 28, 2011 Share September 28, 2011 Im looking at http://www.mycarforum.com/index.php?autoco...p;product=22518 and http://www.mycarforum.com/index.php?autoco...p;product=24653 which is better in terms of improving the downforce and reducing drag? More Downforce more drag Less Downforce less drag Link to post Share on other sites More sharing options...
Mllcg 3rd Gear September 28, 2011 Author Share September 28, 2011 More Downforce more drag Less Downforce less drag im thinking of more downforce with less drag. btw, which one looks nicer too? and if i go gt wings, how should the wing be facing? broad side facing front or tilted back? Link to post Share on other sites More sharing options...
Wjhr 1st Gear September 28, 2011 Share September 28, 2011 im thinking of more downforce with less drag. btw, which one looks nicer too? and if i go gt wings, how should the wing be facing? broad side facing front or tilted back? adjust the angle lor...... use common sense la... wind direction..... Link to post Share on other sites More sharing options...
Mllcg 3rd Gear September 28, 2011 Author Share September 28, 2011 (edited) adjust the angle lor...... use common sense la... wind direction..... ok. let me use diagrams |==\ |==/ above is the boot which position should it be tilted towards? | means boot Edited September 28, 2011 by Mllcg Link to post Share on other sites More sharing options...
Fastfive1 5th Gear September 28, 2011 Share September 28, 2011 Lol!!! The minute i saw this new thread, i knew it was started by you. The first one's nicer. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear September 28, 2011 Author Share September 28, 2011 Lol!!! The minute i saw this new thread, i knew it was started by you. The first one's nicer. i prefer 2nd one. prefer higher also. so how do i put the GT wing? |=\ |=| |=/ so which of the 3 to use? Link to post Share on other sites More sharing options...
Fastfive1 5th Gear September 28, 2011 Share September 28, 2011 i prefer 2nd one. prefer higher also. so how do i put the GT wing? |=\ |=| |=/ so which of the 3 to use? If you were to make it very high, parking may be an issue for you. Link to post Share on other sites More sharing options...
Fastfive1 5th Gear September 28, 2011 Share September 28, 2011 Eh you want the wing merely as a cosmetic enhancement to your ride right? Link to post Share on other sites More sharing options...
Mllcg 3rd Gear September 28, 2011 Author Share September 28, 2011 (edited) Eh you want the wing merely as a cosmetic enhancement to your ride right? to some extent. but i also need to see which position to put the gt wing. cosmetic is one. the other is also for the handling la. Edited September 28, 2011 by Mllcg Link to post Share on other sites More sharing options...
Happily1986 5th Gear September 28, 2011 Share September 28, 2011 The wing should be slanting downwards towards your rear windshield. Don't try the opposite slanting arrangement unless you want to try to take off. Link to post Share on other sites More sharing options...
Fastfive1 5th Gear September 28, 2011 Share September 28, 2011 to some extent. but i also need to see which position to put the gt wing. cosmetic is one. the other is also for the handling la. If you get the type meant for cosmetic purposes, your handling improvement may be negligible or worsen. You want to improve handling, get a proper one that's purpose is to do that. Same with people who buy fake wedssport rims. these fakes obviously won't do much to the car's handling. My school's technician, got a proton gen 2 then decided to put fake wedssports on. For all you know these may be worse than the original rims that came with the car. Link to post Share on other sites More sharing options...
Fastfive1 5th Gear September 28, 2011 Share September 28, 2011 (edited) double post. Edited September 28, 2011 by Fastfive1 Link to post Share on other sites More sharing options...
Mllcg 3rd Gear September 28, 2011 Author Share September 28, 2011 The wing should be slanting downwards towards your rear windshield. Don't try the opposite slanting arrangement unless you want to try to take off. how about straight? Link to post Share on other sites More sharing options...
Happily1986 5th Gear September 28, 2011 Share September 28, 2011 how about straight? straight is useless. just for show off. you want downforce then you must slant the wing towards windshield. depending on what is your compromise point between drag and downforce (both are mutually exclusive), you get your desired angle of slant. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear September 28, 2011 Author Share September 28, 2011 straight is useless. just for show off. you want downforce then you must slant the wing towards windshield. depending on what is your compromise point between drag and downforce (both are mutually exclusive), you get your desired angle of slant. can i reduce drag but increase downforce? Link to post Share on other sites More sharing options...
Yc86 Clutched September 28, 2011 Share September 28, 2011 First one is nicer.. it's new right? 2nd one looks quite old. Plus the first one looks taller? Get the taller one loh. When you hang your cloth after washing the car, won't touch the boot. Performance wise, the wing does not contribute as much towards downforce compared to the car's body itself. eg. thru flat underbody and diffusers. ↡ Advertisement Link to post Share on other sites More sharing options...
2 lanes turn right to 3 lanes - which lane to go?
Which brand of honey to buy?
Which airline is the best?
