Ahtong 1st Gear November 28, 2011 Share November 28, 2011 Just changed battery recently. The car suddenly feels more powerful than before. Although I only used my butt dyno for measurement, I am quite sure this is not my imagination. How is this possible? ↡ Advertisement Link to post Share on other sites More sharing options...
Lowrider 2nd Gear November 28, 2011 Share November 28, 2011 Just changed battery recently. The car suddenly feels more powerful than before. Although I only used my butt dyno for measurement, I am quite sure this is not my imagination. How is this possible? Maybe your ECU has been reset... Link to post Share on other sites More sharing options...
Cdior 1st Gear November 28, 2011 Share November 28, 2011 no. battery is only use to start the car , n nothing else. Link to post Share on other sites More sharing options...
Maka Neutral Newbie November 28, 2011 Share November 28, 2011 no. battery is only use to start the car , n nothing else. And to power your ECU which indirectly owns the map of the transmission. Performance might be increased if you have tons of electronics in the car. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear November 28, 2011 Share November 28, 2011 no. battery is only use to start the car , n nothing else. and to power your ICE. Link to post Share on other sites More sharing options...
Maka Neutral Newbie November 28, 2011 Share November 28, 2011 and to power your ICE. Bro, thats after the engine is started. However when the car engine is sleep mode, the ECU is still in functioning state just idling. Just like your PC/Lappy/mobile phone which is in standby mode. Link to post Share on other sites More sharing options...
Batlim 1st Gear November 28, 2011 Share November 28, 2011 (edited) or maybe with a new battery ( which is more efficient ) all your electronic sensors & controllers are working more efficiently...... Edited November 28, 2011 by Batlim Link to post Share on other sites More sharing options...
SimonTan 2nd Gear November 28, 2011 Share November 28, 2011 Strong battery means the sparks are stronger? And also the alternator no need to charge it as often, so the power sapping alternator is OFF, giving you the sense of smoothness power. Same thing I feel each time I use my Ctek charger to charge my car battery. The car seems to be smoother after a full battery charge. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged November 28, 2011 Share November 28, 2011 no. battery is only use to start the car , n nothing else. wow... ur car is so advance.... batt ONLY use to start the car.... Link to post Share on other sites More sharing options...
Maka Neutral Newbie November 28, 2011 Share November 28, 2011 wow... ur car is so advance.... batt ONLY use to start the car.... Maybe he driving starlet with no ice? It does seems to apply to that. Those 1980s datsun oso the same. Link to post Share on other sites More sharing options...
Sucker Clutched November 28, 2011 Share November 28, 2011 Yes, my butt feel also said that too. Just changed battery recently. The car suddenly feels more powerful than before. Although I only used my butt dyno for measurement, I am quite sure this is not my imagination. How is this possible? Link to post Share on other sites More sharing options...
Qms Neutral Newbie November 28, 2011 Share November 28, 2011 Old or poorly performing battery becomes a heavy load on the engine, when it cannot hold charge. Changing it out for a new battery lightens the load and you get a more spiffy engine. Link to post Share on other sites More sharing options...
Tigershark1976 Turbocharged November 28, 2011 Share November 28, 2011 Maybe he driving starlet with no ice? It does seems to apply to that. Those 1980s datsun oso the same. not only ICE, all electrical components in the car draws power from battery. not directly from alternator. battery act as a storage media for the electricity generated from alternator.... Link to post Share on other sites More sharing options...
Roadhogger 2nd Gear November 28, 2011 Share November 28, 2011 I noticed my transmission shift better after the battery were change. Link to post Share on other sites More sharing options...
Dadiao 1st Gear November 28, 2011 Share November 28, 2011 hmm, my guess is the engine power the electrical stuff such as air-con, lights battery etc. through the alternator. Therefore if the loads can be reduced, the power saved can directed to the wheels. For the battery, if less charging is required, the alternator & engine will work less, and more can be used to power the drive. Just my guess. Link to post Share on other sites More sharing options...
Maka Neutral Newbie November 28, 2011 Share November 28, 2011 not only ICE, all electrical components in the car draws power from battery. not directly from alternator. battery act as a storage media for the electricity generated from alternator.... Starlet n datsun isnt control by ECU as in olden days there arent electronic contraled engines technology, cars back than are easier to troubleshoot and repair. The ICE and other accessories use it when you on it... ECU in another hand is on when the battery is connected when you are or not in the car. Link to post Share on other sites More sharing options...
Maka Neutral Newbie November 28, 2011 Share November 28, 2011 hmm, my guess is the engine power the electrical stuff such as air-con, lights battery etc. through the alternator. Therefore if the loads can be reduced, the power saved can directed to the wheels. For the battery, if less charging is required, the alternator & engine will work less, and more can be used to power the drive. Just my guess. Whether new battery or old battery, your alternator is a charging mechanism once your engine starts to spin. There isnt a on off switch there to off the alternator, it will continue to run its electrons to the battery which indirect provides power to the rest. Link to post Share on other sites More sharing options...
Mkl22 Supersonic November 28, 2011 Share November 28, 2011 Whether new battery or old battery, your alternator is a charging mechanism once your engine starts to spin. There isnt a on off switch there to off the alternator, it will continue to run its electrons to the battery which indirect provides power to the rest. got regulator la. if it needs to produce more amps then the greater load on the engine. where got free power. ↡ Advertisement Link to post Share on other sites More sharing options...
Lower your car interior temp when parking in the hot SUN
How to get car financing loan?
Music Concerts
Music Concerts
COE Bidding – Jun 2026
