Anyone can help on - Hissing sound from air con vent
Dezouk
Hi bros
Yesterday I discovered a hissing sound coming out from the air con vent in the center console of the car. When I turn it off, no sound at all. Once air con on, the hissing sound ll come out once every 1-2 min. Anyone know what happen or where should I service?
Air con is blowing cool air as usual no change though. Thanks!
Just remove your Aircon filter can give it a few knock. You should see a few dried leave there causing the sound. Happened to me.
Hi bros
I think from fan coil there, happened to my colleague, he using "chiong" part and so everytime his air-con got hissing sound.
I suggest u send to air-con specialist check, they are the expert. Here you will get a lot of answers but don't know which is true.
I went to a reputable air con service centre. Done check n found that I am low on the 'gas' . , this morn air con was blowing air that is not cold, Suspected leak that's why .
Boss told me it might b cooling cold damaged n leaking , damage $750 ! I didn't do it but done a top up gas n see how it goes first.
Will it be a case of low in gas which requires top up? I hope so , else damage $750!
You mean your air-con compressor is spoilt?! [:/]
Think not cheap to replace if anything happen to the air-con area. The other time i have one friend spent nearly $1K when his car air-con compressor and coil spoilt!
The refrigerant gas does not deplete voluntarily.
If you are 'low' again, there has to be a leak.
But one other place is the hot/cold (red/blue) pippings.
A recon cooling coil will be much cheaper if you intend to change ride soon.
The boss uses a machine which has two tubes that are use to attached on the piping of my air con unit , n the meter on the machine shows it's low on the 'gas' so they suspect a leak in cooling coil . Thats how they checked my car , nothing else , didn't check filter . He says compressor is ok
So I asked for a top up n see if the nex few days what ll happen if low again means damage big time hv to change that cooling coil!
$750 for denso brand plus labor as they need to dismantle several parts inorder to reach the air con
You can try this workshop which I've no personal or commercial interests for 2nd opinion , hope it helps:
Mark-Cool Auto Air-Conditioning Service
Address: 106 Woodlands Industrial Park 3, S(757840)
Tel: 63677666
Contact: Ah Huat
Try moto-aire at sin ming.
My van evaporator coil rotten and leaked.
Replaced coil, refill coolant about $400.
