Aeromania 1st Gear April 3, 2012 Share April 3, 2012 less rev less consumption but on the other hand, not so less torque that next gear have to struggle. ↡ Advertisement Link to post Share on other sites More sharing options...
LowFlyin Neutral Newbie April 3, 2012 Share April 3, 2012 You could skip shift, as well. 1-3 or 1-4. You should pause a little longer before engaging the clutch to allow the engine revs to fall into the proper range. Some of the US cars in the late 90's and early 00's had a 2nd and 3rd gear lock out when the load on the engine/trans was low and you had to shift straight to 4th from 1st. Link to post Share on other sites More sharing options...
Jamesc Hypersonic April 4, 2012 Share April 4, 2012 Assume along flat road with manual transmission: Changing up to higher gears (Example: 1st gear to 2nd gear):- Release accelerator pedal Depress clutch pedal Engage gear selected Release clutch pedal Press on accelerate pedal The car can be travelling as smoothly as the best auto-transmission, with this method Thats the perfect method for smooth changes. Smooth changes minimise fuel consumption and wear and tear. Repairing gearboxes are expensive. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear April 4, 2012 Share April 4, 2012 Auto gear box repair is expensive. Manual not that ex. Link to post Share on other sites More sharing options...
C-K 2nd Gear April 4, 2012 Share April 4, 2012 Install vacuum gauge. Change gear before the needle reaches 0. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear April 4, 2012 Share April 4, 2012 sometimes quite siong for the manual transmission also if there is not enough torque on the gear. Some of you may experience the gear to have Kack Kack Kack sound im sure. This is not very healthy for manual transmission also. Yes although change gear fast enough to reach higher gears to have a better FC, but sometimes this is compromised. The rue of thumb, change gear as per normal, but of cos do it progressively IMO. ↡ Advertisement Link to post Share on other sites More sharing options...
Proposed Changes to Fire Safety Act (2019)
Where to mod fuel needle?
