Kelpie 2nd Gear April 19, 2012 Share April 19, 2012 Hi all, There is this scenario of upsizing a default stock tyre size from 195/60R15: The info gathered http://www.1010tires.com/tiresizecalculator.asp is this: For 195/60R15, the speed is 100Km/h For 205/55R16, the speed is about 97.3Km/h (2.726% slower) For 225/55R16, the speed is about 95.6Km/h (4.538% slower) But when I compare with another site at: http://www.tacomaworld.com/forum/tirecalc.php , the result is different: For 195/60R15, the speed is 104.61Km/h For 205/55R16, the speed is about 107.48Km/h For 225/55R16, the speed is about 109.35Km/h So who is correct? or I did it wrongly? Thank you. Regards, ↡ Advertisement Link to post Share on other sites More sharing options...
Good-Carbuyer 1st Gear April 19, 2012 Share April 19, 2012 You may be aware that some makes come with deeper tread depth than others. Hence some difference among them. Link to post Share on other sites More sharing options...
Fitvip Supersonic April 19, 2012 Share April 19, 2012 (edited) Hi all, There is this scenario of upsizing a default stock tyre size from 195/60R15: The info gathered http://www.1010tires.com/tiresizecalculator.asp is this: For 195/60R15, the speed is 100Km/h For 205/55R16, the speed is about 97.3Km/h (2.726% slower) Speedometer1: 58.4 mph 97.3 km/h For 225/55R16, the speed is about 95.6Km/h (4.538% slower) Speedometer1: 56.4 mph 94.0 km/h But when I compare with another site at: http://www.tacomaworld.com/forum/tirecalc.php , the result is different: For 195/60R15, the speed is 104.61Km/h For 205/55R16, the speed is about 107.48Km/h 65 mph (104.61 km/h) 66.79 mph (107.48 km/h) For 225/55R16, the speed is about 109.35Km/h 65 mph (104.61 km/h) 69.11 mph (111.22 km/h) So who is correct? or I did it wrongly? Thank you. Regards, I tried your 1st calculator and the result is different from yours! I think the first calculator is based on stock tyre at 100 km/h and the resultant speedo reading are slower, which is correct. The second calculator is based on the stock tyre at 60 mph/104.64 km/h, new tyre's actual speed should be ...assuming the same number of revolution! Edited April 19, 2012 by Fitvip ↡ Advertisement Link to post Share on other sites More sharing options...
Valve stem washer?
Valve stem washer?
Old WW2 Relic disposals
2 lanes turn right to 3 lanes - which lane to go?
Which brand of honey to buy?
Which airline is the best?
