Jerrimie Clutched April 25, 2012 Share April 25, 2012 go ask workshop for advise lo ask here also wont get accurate diagnosis ↡ Advertisement Link to post Share on other sites More sharing options...
QQDreamer 4th Gear April 25, 2012 Author Share April 25, 2012 Ya. wanna ask here in case wrkshop carrot me Link to post Share on other sites More sharing options...
Caravan 5th Gear April 25, 2012 Share April 25, 2012 Check the lower arm. Link to post Share on other sites More sharing options...
Powerkeong Neutral Newbie April 25, 2012 Share April 25, 2012 It the bushing for your shock absorber. I am driving a Hyundai Verna and it happens to me. Once changed, problem solved! Link to post Share on other sites More sharing options...
Karebu 1st Gear April 25, 2012 Share April 25, 2012 can be the suspension arm loose. quite serious. i had that sound for some time and when i finally got it checked it was secured only by the safety pin (totally unscrewed on its own already) Link to post Share on other sites More sharing options...
QQDreamer 4th Gear April 25, 2012 Author Share April 25, 2012 ok will get my workshop to check it out Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged April 25, 2012 Share April 25, 2012 i see. the bushing is for the anti roll bar? at the suspension. if I rem correctly, it is between the springs n absorbers. if you bend down from the rear of the car, you should be able to see it. does your car feel very bouncy? Link to post Share on other sites More sharing options...
QQDreamer 4th Gear April 25, 2012 Author Share April 25, 2012 at the suspension. if I rem correctly, it is between the springs n absorbers. if you bend down from the rear of the car, you should be able to see it. does your car feel very bouncy? nope. not bouncy at all. Just having this sound whenever cross over uneven surface or humps. the sound come from the right front. Link to post Share on other sites More sharing options...
Fireboyzzz 1st Gear April 25, 2012 Share April 25, 2012 Antiroll bar bushing and linkage for my matrix case Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged April 25, 2012 Share April 25, 2012 nope. not bouncy at all. Just having this sound whenever cross over uneven surface or humps. the sound come from the right front. there is too many componentsthat will result in the sound. go workshop n check. if yours is a Honda, I can recommend you a ws at permas jaya Link to post Share on other sites More sharing options...
QQDreamer 4th Gear April 25, 2012 Author Share April 25, 2012 er.. not honda. Link to post Share on other sites More sharing options...
Remixes Clutched April 25, 2012 Share April 25, 2012 hi i also have this kinda of problem ..what remedies? hi bro galantspeed which workshop in permas jaya???Tung chun? Link to post Share on other sites More sharing options...
QQDreamer 4th Gear April 25, 2012 Author Share April 25, 2012 wow didnt know so many bro's ride having the same problem. Link to post Share on other sites More sharing options...
Galantspeedz Turbocharged April 25, 2012 Share April 25, 2012 hi i also have this kinda of problem ..what remedies? hi bro galantspeed which workshop in permas jaya???Tung chun? yup tung chun. very good experience with them always Link to post Share on other sites More sharing options...
Forhod Clutched April 25, 2012 Share April 25, 2012 Most likely is the Lower Arm Bushings that have worn out, pretty common wear and tear. Link to post Share on other sites More sharing options...
Ev0x Clutched April 25, 2012 Share April 25, 2012 i think may have something loose regarding your suspension. i also had this problem before and went to ws and they help me to tighten back. Link to post Share on other sites More sharing options...
Icyfreakass 1st Gear April 25, 2012 Share April 25, 2012 I agree with caravan. Check your front control arms. Might have gone loose, just get workshop to tighten for you. Most prob would be the control arms if u hear the sound over bumpy roads as well. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear April 25, 2012 Author Share April 25, 2012 I agree with caravan. Check your front control arms. Might have gone loose, just get workshop to tighten for you. Most prob would be the control arms if u hear the sound over bumpy roads as well. thanks i will take note of your advise. will ask mechanic to check it. ↡ Advertisement Link to post Share on other sites More sharing options...
Sound Proofing the car
Whole car sound proof
School holiday over but not IMH!
Right side speakers no sound
Metal grinding sound on civic
Unemployment rate for over-30s creeps up
