Godfinger Neutral Newbie May 15, 2012 Author Share May 15, 2012 Mounting checked and is still Useable. Only suspect now could Be the ICA or TB. Shall rule out TB since idling when waiting at The lights or more specific, when Gear is in 'D' is perfectly normal. Could b relating problems with Loading since problem only happens When A/C is shut off. ↡ Advertisement Link to post Share on other sites More sharing options...
Godfinger Neutral Newbie May 15, 2012 Author Share May 15, 2012 Dirty fuel filter or choked injectors? Dont think these are the culprits since My engine is able to rev willing. Link to post Share on other sites More sharing options...
PaiKia-Lee 1st Gear May 15, 2012 Share May 15, 2012 I got same problems with one of my cars recently. Worse than u. Sometimes when stopping at traffic light, the engine simply vibrate and stalled. Sometimes when going upslope and when i release the accele and step on it again, engine just died. Need to sell away this car asap as i have changed aircon compressor and the problem persists Link to post Share on other sites More sharing options...
Xcen Neutral Newbie May 15, 2012 Share May 15, 2012 my colleauage had this problem when he pump at malaysia. realised that they actually mixed kerosene into their petrol and resulted in the same issue as u. Link to post Share on other sites More sharing options...
PaiKia-Lee 1st Gear May 15, 2012 Share May 15, 2012 my colleauage had this problem when he pump at malaysia. realised that they actually mixed kerosene into their petrol and resulted in the same issue as u. Strange. I have been pumping in Malaysia for 10 years for all my cars and my relatives all never complaint about kerosene added to petrol Link to post Share on other sites More sharing options...
Xcen Neutral Newbie May 15, 2012 Share May 15, 2012 petronas? esso and shell no problem Link to post Share on other sites More sharing options...
Chickensoup 1st Gear May 15, 2012 Share May 15, 2012 Recently, I discover that my engine will tremble and Vibrate before I shut off. Problem is, this issue doesnt occurs everytime. More likely to happen when I turn-Off the Aircon and engine still running. Gear in 'P' and it will trembles and Vibrates, RPM drops for that few seconds before it suddenly rev up again to prevent engine stalling. What could be the problem? I have my Plugs changed, Engine Oil renewed and Filiter change as well. Problem still persist. Could it be the sensors issue or Idling problems? Nothing of this sort happens when Gear is in 'D' What is your engine rpm showing before you off engine (aircon off) ? and what is your usual idling rpm? Did you have this problem before you went to service your car, change oil and spark plugs? Link to post Share on other sites More sharing options...
Godfinger Neutral Newbie May 15, 2012 Author Share May 15, 2012 Service done and with A/C off, idling is 800rpm. With A/C on, it's 900rpm. But when the engine trembles, the rev can go as low as 500rpm. Making The engine very unstable and like stalling any moment. Link to post Share on other sites More sharing options...
Jellyfish 1st Gear May 16, 2012 Share May 16, 2012 i suspect it the engine mounting on the gearbox side that went up lorry liao, but since you are going to a work shop, might as well change em out to save the hassle , unless you like to hang out at workshop every week Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 16, 2012 Share May 16, 2012 When you kill yr petrol powered engine, if the engine will keep on running and trembles before it comes to a stop - this is call " dieseling". That means within the engine compression chamber there are carbons that will are still burning due to extreme heat generated either by wrong plug heat range, use of high octane fuel above recomedation or the engine ignition timing is just too advance. Link to post Share on other sites More sharing options...
Gnahp Turbocharged May 16, 2012 Share May 16, 2012 Bro Yeobh, Dieseling phenomenon not found in modern fuel injection engine any more When you switch off the ignition switch of an EFI engine, the whole EFI system shut down including the fuel pump, injectors etc. No fuel, no dieseling. Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 16, 2012 Share May 16, 2012 You are correct but there are possibilities of some remain combustible fume within the combustion chamber, or blow- by fumes that are being re-circulate back into the intake system.The other cause maybe leaking injector ( the fuel header pressure remains high as 7kg/cm2 even when the fuel pump has stop pumping). Link to post Share on other sites More sharing options...
Chickensoup 1st Gear May 16, 2012 Share May 16, 2012 Service done and with A/C off, idling is 800rpm. With A/C on, it's 900rpm. But when the engine trembles, the rev can go as low as 500rpm. Making The engine very unstable and like stalling any moment. Ok your problem is call dieseling ( engine run-on after ignition is off). Is that what you are complaining? Link to post Share on other sites More sharing options...
Gnahp Turbocharged May 16, 2012 Share May 16, 2012 That Link to post Share on other sites More sharing options...
Chickensoup 1st Gear May 16, 2012 Share May 16, 2012 That Link to post Share on other sites More sharing options...
Happily1986 5th Gear May 16, 2012 Share May 16, 2012 i suspect the culprit is the ICV, Idle Control Valve. Link to post Share on other sites More sharing options...
Chickensoup 1st Gear May 16, 2012 Share May 16, 2012 I don't think it is ICV because before TS goes for this last service there isn't this problem. Can't be such a coincident just after service, the ICV knock out. Link to post Share on other sites More sharing options...
Godfinger Neutral Newbie May 16, 2012 Author Share May 16, 2012 Not dieseling. The trembling is before I shut off the engine. Here is how it goes. Park my car, put the Gear into 'P' turn off the A/C and the rev falls and engine trembles. Then moments later, the Rev builds up again to save the stalling engine and I shut off the engine. Everything is fine when I turn off the engine while Gear is in 'N' or 'D'. But nobody will shut down engine when in Gear right. This will cause Premature failure to the GB. ↡ Advertisement Link to post Share on other sites More sharing options...
Coolant level going down
Singtel line down?
Singtel line down?
Battery Voltage up & down
Websites of Singapore public hospitals, polyclinics down due to 'internet access disruption'
Migrating down under? Come share your experiences
