Kelpie 2nd Gear July 23, 2012 Share July 23, 2012 Hi all, I did wheel alignment recently but why there is still squeaky noise when the car is turning at MSCP when going down slope? Please advise me and Thank you very much. Regards, ↡ Advertisement Link to post Share on other sites More sharing options...
Furrynadz 5th Gear July 23, 2012 Share July 23, 2012 Hi all, I did wheel alignment recently but why there is still squeaky noise when the car is turning at MSCP when going down slope? Please advise me and Thank you very much. Regards, tyre design n compound Link to post Share on other sites More sharing options...
Mits_jc 5th Gear July 23, 2012 Share July 23, 2012 Because MSCP surface is not Tarmac so ur tyres will squeak. Hi all, I did wheel alignment recently but why there is still squeaky noise when the car is turning at MSCP when going down slope? Please advise me and Thank you very much. Regards, Link to post Share on other sites More sharing options...
Kelpie 2nd Gear July 23, 2012 Author Share July 23, 2012 Because MSCP surface is not Tarmac so ur tyres will squeak. So no wonder what kind of tyres we used, it will surely squeak? Regards, Link to post Share on other sites More sharing options...
Liping24cn Clutched July 23, 2012 Share July 23, 2012 The two front wheels are not entirely level. They do not turn the same degrees! Also it's angle of contact with the ground changes, you can see a older BMW or Mercedes front wheel when it's turned full lock. The tyres are so angled that it looks weird. The tyre contact with the ground only the edge of the tyre tread. I suppose it was design this way when taking a fast corner, where the suspension will compress and make the tyre contact 'full' again. But when doing a slow turn only the edges of tyre are in contact, and coupled with the 'smooth' cement floor in MSCP, the tyres rubber is 'rubbing' along and it also roll. The rubbing of the two front wheels on the smooth floor cause the sound to be heard. On the rough asphalt, the rubbing sound will be lower in frequency. Same when your wear a yellow sole, badminton shoes, it will screech and make a high pitch sound when you rub it on smooth cement floor. Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 23, 2012 Share July 23, 2012 So no wonder what kind of tyres we used, it will surely squeak? Regards, Yes...except when it is wet. Link to post Share on other sites More sharing options...
Skyiet27 Clutched July 23, 2012 Share July 23, 2012 Alignment got nothing to do with sound Yup should be tyre against wet mscp ground Link to post Share on other sites More sharing options...
Gee 1st Gear July 23, 2012 Share July 23, 2012 Forward movement bigger than turning. Try not to enter corner too sharply. Link to post Share on other sites More sharing options...
Skyiet27 Clutched July 23, 2012 Share July 23, 2012 But think cos ur tires r good that's y got sound If tires are all harden cos old or not grippy tyre I dun think there is any sound cos no grip Btw what tires u using? Link to post Share on other sites More sharing options...
W124 Clutched October 31, 2012 Share October 31, 2012 The two front wheels are not entirely level. They do not turn the same degrees! Also it's angle of contact with the ground changes, you can see a older BMW or Mercedes front wheel when it's turned full lock. The tyres are so angled that it looks weird. The tyre contact with the ground only the edge of the tyre tread. I suppose it was design this way when taking a fast corner, where the suspension will compress and make the tyre contact 'full' again. They are designed this way to allow a tighter turning circle than the normal looking front wheels - that's why many a time my old Merc can do U-turns at traffic lights easily whereas many other cars got to do 3 point turn. ↡ Advertisement Link to post Share on other sites More sharing options...
Why do drivers insist on making a missed turn - even when it's impossible to do so?
Switch Off Aircon and Media Player before Turning Off Engine
How to solve unwanted noises in your car
Turn steering wheel, let go of wheel, car keeps turning
Turning a Router into a Bridge
Heavy Veh Turning on Extreme Right lane (2 turning lanes)
Noise when turning right.
Strange noise at wheel area when doing U-turn
