Greyminswift 1st Gear August 26, 2012 Share August 26, 2012 Once I change about 8k for my business trip also can see someone "bio" around...especially those OLs where they count $$ openly not at the money changer there but walking away... Do be careful guys, change and count at the counter and ask the money changer for an envelope and keep the $$ inside to hide from invasive eyes... Our ATM discipline also not very good. Some people will openly count their notes before putting in their wallet/purse etc. If you need to count, make sure to do it discreetly, make sure your back is not exposed and best if keep the counting within range of the atm's cameras. ↡ Advertisement Link to post Share on other sites More sharing options...
VellfireS 4th Gear August 26, 2012 Author Share August 26, 2012 Random pick may not yield a high return. Base on profiling and target selection, they can effectively rob him and make a escape route effectively. Random robbery they wouldn't be able to escape that fast. My take is he is marked all the way from the start. I think it's inside information.. :ph34r: Link to post Share on other sites More sharing options...
TVT Supercharged August 26, 2012 Share August 26, 2012 I've changed there many times, sometimes up to a few thousands in foreign currency...but never got rob leh. I have seen ladies changes more than SGD5K also (cos they give IC to money changer) and no issue! The best rate (I think) is in People's Park, not Raffles Place. But its more "comfortable" to change in Raffles Place due to the type of "crowd" around...if you get what I mean! Link to post Share on other sites More sharing options...
Jman888 Moderator August 26, 2012 Share August 26, 2012 papers say the victim was a money changer in batam, came here regularly hence kena marked by the robbers. Link to post Share on other sites More sharing options...
Jman888 Moderator August 26, 2012 Share August 26, 2012 why this in complaint section? Link to post Share on other sites More sharing options...
VellfireS 4th Gear August 26, 2012 Author Share August 26, 2012 why this in complaint section? It cannot be in the Lite&Ezy right? [rolleyes] Link to post Share on other sites More sharing options...
Happily1986 5th Gear August 26, 2012 Share August 26, 2012 papers say the victim was a money changer in batam, came here regularly hence kena marked by the robbers. Premeditated manslaughter then? Link to post Share on other sites More sharing options...
Passion 5th Gear August 26, 2012 Share August 26, 2012 Premeditated manslaughter then? This will never be manslaughter. Multiple wounds found on victim body. Very obvious perpetrator wants him dead. Link to post Share on other sites More sharing options...
Happily1986 5th Gear August 27, 2012 Share August 27, 2012 This will never be manslaughter. Multiple wounds found on victim body. Very obvious perpetrator wants him dead. that's your opinion. prosecutor will need to establish his case that there was intent and planning to take the victim's life. It is easy to prove that this was a planned robbery however if the victim was killed as a matter of unintended consequences, then it is manslaughter not murder. Link to post Share on other sites More sharing options...
Tayspiderx 3rd Gear August 27, 2012 Share August 27, 2012 Should be about to capture the perpetrator with all those cameras infront of money changers. Lost of life at such young age is truly sad. Link to post Share on other sites More sharing options...
Passion 5th Gear August 27, 2012 Share August 27, 2012 that's your opinion. prosecutor will need to establish his case that there was intent and planning to take the victim's life. It is easy to prove that this was a planned robbery however if the victim was killed as a matter of unintended consequences, then it is manslaughter not murder. Now my question is, if it is like what you mentioned, unintended consequences, how do you explain 20 over wounds on the victim body? If not to kill him, why need so many stabs onto the victim body? This is something which perpetrator can't even explain himself. Link to post Share on other sites More sharing options...
Sk65 1st Gear August 27, 2012 Share August 27, 2012 y he take that staircase ar? got escalator wat becos that staircase is dammmmmn quiet one la.. Link to post Share on other sites More sharing options...
Happily1986 5th Gear August 27, 2012 Share August 27, 2012 Now my question is, if it is like what you mentioned, unintended consequences, how do you explain 20 over wounds on the victim body? If not to kill him, why need so many stabs onto the victim body? This is something which perpetrator can't even explain himself. victim struggled or even fought back? in any case, I still think that the legal burden will be on prosecution to prove that assailant slashed to kill. lets hope the culprit is caught first. Link to post Share on other sites More sharing options...
Babyt 4th Gear August 27, 2012 Share August 27, 2012 why handle the cash alone? last time i worked part time at cafe, every day my mgr/supervisor go to bank to deposit previous date taking, also need at least 1 barista to accompany...in case kenna rob or as witness. Link to post Share on other sites More sharing options...
Jman888 Moderator August 27, 2012 Share August 27, 2012 y he take that staircase ar? got escalator wat becos that staircase is dammmmmn quiet one la.. maybe he was lead to the place at knife point? Link to post Share on other sites More sharing options...
Jman888 Moderator August 27, 2012 Share August 27, 2012 Now my question is, if it is like what you mentioned, unintended consequences, how do you explain 20 over wounds on the victim body? If not to kill him, why need so many stabs onto the victim body? This is something which perpetrator can't even explain himself. the motive? If the motive is to rob, then killing will become secondary hence manslaughter. If motive is to kill, then must prove why he wants to kill this guy (even without him carrying the load of cash) Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear August 27, 2012 Share August 27, 2012 I've changed there many times, sometimes up to a few thousands in foreign currency...but never got rob leh. I have seen ladies changes more than SGD5K also (cos they give IC to money changer) and no issue! The best rate (I think) is in People's Park, not Raffles Place. But its more "comfortable" to change in Raffles Place due to the type of "crowd" around...if you get what I mean! people's park is the 2nd best rate after Raffles Place. Link to post Share on other sites More sharing options...
Passion 5th Gear August 27, 2012 Share August 27, 2012 the motive? If the motive is to rob, then killing will become secondary hence manslaughter. If motive is to kill, then must prove why he wants to kill this guy (even without him carrying the load of cash) If the motive is to rob, then man slaughter stands. But now with multiple wounds, it is obvious the perpetrator wants him dead. Else, one or two knives enough to cripple him. ↡ Advertisement Link to post Share on other sites More sharing options...
Another MU Place To Consider
Raffles town club parking
Man arrested for attempted armed robbery at a Toa Payoh carpark
Know any place that sell Hanes Beefy-T plain tee shirt?
Recommended place to get good Sofa?
4 men arrested, to be charged with armed robbery in Jurong
