Rubbermat Clutched May 6, 2013 Share May 6, 2013 The sign will be my ITB100HD. I set it at 11.8V. If one fine morning, my cam is cut off. Then it is time for me to change my battery. ↡ Advertisement Link to post Share on other sites More sharing options...
GemLeo 1st Gear May 6, 2013 Share May 6, 2013 hi bros, found out the following, hope any of you can assist. I noticed some missing video clips. Using "file explorer" or/and "pc player", I cannot find any video files at all. i.e. I see a video of driving at 5pm. then the next video I can find is at 5.20pm. Have tried sorting out files by date. Still nothing. This probably means the cam isnt recording. I've checked the box to "off" display speed. But the speed is still indicated on video playback. Thanks in advance. Link to post Share on other sites More sharing options...
Mcf777 Turbocharged May 6, 2013 Share May 6, 2013 Are u using 8GB? Some of the files may have been overwrite. Link to post Share on other sites More sharing options...
GemLeo 1st Gear May 6, 2013 Share May 6, 2013 yes 8gb at the moment. I figured it could be becuase of the ratio settings.. however, even if it's overwriting, won't it be a long list of videos in sequence? i.e. videos of driving from 3pm to 6pm.. yet but no videos from 5pm to 5.20pm any bros encounter this? Link to post Share on other sites More sharing options...
Cerealkiller 1st Gear May 6, 2013 Share May 6, 2013 i set my ITV80 to 12v / 24hr recording See post #240 on battery http://www.mycarforum.com/index.php?showto...0&start=240 Link to post Share on other sites More sharing options...
WTF 4th Gear May 6, 2013 Share May 6, 2013 i set my ITV80 to 12v / 24hr recording See post #240 on battery http://www.mycarforum.com/index.php?showto...0&start=240 so may I know is ITV80 just a device to cut off the power when the set voltage is reached or it's also a backup battery??? Link to post Share on other sites More sharing options...
Skchiu 2nd Gear May 6, 2013 Share May 6, 2013 yes 8gb at the moment. I figured it could be becuase of the ratio settings.. however, even if it's overwriting, won't it be a long list of videos in sequence? i.e. videos of driving from 3pm to 6pm.. yet but no videos from 5pm to 5.20pm any bros encounter this? yes i encounter this also seems like cam is faulty, time to send in to change or if warranty over, time to buy new one Link to post Share on other sites More sharing options...
Sabian Turbocharged May 6, 2013 Share May 6, 2013 so may I know is ITV80 just a device to cut off the power when the set voltage is reached or it's also a backup battery??? Cut off. Link to post Share on other sites More sharing options...
WTF 4th Gear May 6, 2013 Share May 6, 2013 Cut off. thanks bro, that means if I want to use the cam for parking surveillance I'll have to either connect it to the car batt or self-rigged a spare power supply then....... Link to post Share on other sites More sharing options...
Axela525 4th Gear May 6, 2013 Share May 6, 2013 thanks bro, that means if I want to use the cam for parking surveillance I'll have to either connect it to the car batt or self-rigged a spare power supply then....... Or get T-power... Link to post Share on other sites More sharing options...
WTF 4th Gear May 6, 2013 Share May 6, 2013 (edited) Or get T-power... like this one in the link below??? http://list.qoo10.sg/item/BRAND-NEW-T-POWE...-PACK/408517469 where did you got yours, if any? and can it work with the ITB-100HD? Edited May 6, 2013 by WTF Link to post Share on other sites More sharing options...
Axela525 4th Gear May 7, 2013 Share May 7, 2013 (edited) like this one in the link below??? http://list.qoo10.sg/item/BRAND-NEW-T-POWE...-PACK/408517469 where did you got yours, if any? and can it work with the ITB-100HD? Yup..get from wow gadgets...120...as long as input to dvr is 12V can use. Edited May 7, 2013 by Axela525 Link to post Share on other sites More sharing options...
Flyboy744 Neutral Newbie May 7, 2013 Share May 7, 2013 Did anyone use ITB-100HD SP with the T-PowerC? Yes, though the output from the T-powerC is suitable for ITB-100, is the head suitable, ie do u need any modification to fit into the power cable form ITB-100HD to T-powerc jack? I want to use T-powerc, but it seems that it is designed for Blackvue. Any advice? Link to post Share on other sites More sharing options...
QQDreamer 4th Gear May 7, 2013 Share May 7, 2013 Did anyone use ITB-100HD SP with the T-PowerC? Yes, though the output from the T-powerC is suitable for ITB-100, is the head suitable, ie do u need any modification to fit into the power cable form ITB-100HD to T-powerc jack? I want to use T-powerc, but it seems that it is designed for Blackvue. Any advice? in my opinion get the ITV-80 you wont go wrong with this. ITV-80 is for 100HD and 100HDSP. dont go use something that is not meant for the DVR. Link to post Share on other sites More sharing options...
Flyboy744 Neutral Newbie May 7, 2013 Share May 7, 2013 Unfortunately I cannot afford to have the camcorder takes power from the fuse box as my car gizmos takes a lot of power from the car battery. Apart from that, I don't wanted AD to give any stupid reasons to void any warranty if there's anythg wrong with any electrical component. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear May 7, 2013 Share May 7, 2013 Unfortunately I cannot afford to have the camcorder takes power from the fuse box as my car gizmos takes a lot of power from the car battery. Apart from that, I don't wanted AD to give any stupid reasons to void any warranty if there's anythg wrong with any electrical component. if thats the case dont put your ITB-100HD into parking survelliance mode since warranty is a issue to you. Might as well use it on cigar socket drive and record for you. Link to post Share on other sites More sharing options...
Rubbermat Clutched May 7, 2013 Share May 7, 2013 Hi all, May I know who has ordered their SP & non SP version. The supplier has email to me that he received quite a number of orders. Now busying sorting out the shipment. Maybe a bit of delays. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear May 7, 2013 Share May 7, 2013 Hi all, May I know who has ordered their SP & non SP version. The supplier has email to me that he received quite a number of orders. Now busying sorting out the shipment. Maybe a bit of delays. Bro i ordered the SP version without ITV-80. ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
How to feedback on hospital service?
Seen the new look on Sgcarmart's Used Car pages? Love it or hate it? We want to hear from you!
Anyone have invested in SSB?
Feedback on hazard
Feedback on hazard
Cannot post an Ad
Cannot post an Ad
Any feedback on castlewoodgroup?
VW Tiguan 2011-2012 feedback
