Mcf777 Turbocharged May 23, 2013 Share May 23, 2013 both my sets (HD and SP) also green light ON. When I played it, NO sound. This is what I wanted. ↡ Advertisement Link to post Share on other sites More sharing options...
Intel Clutched May 23, 2013 Share May 23, 2013 Actually ITB100HD got video out socket right? Only thing is which type of small LCD screen compatible with cable connection. I also prefer to have a screen to view when adjusting the camera. This will be only a 1 time off as after you adjust you won go touch it anymore. I have a portable media player with AV in. Just nice can use for this during adjusting. Link to post Share on other sites More sharing options...
WTF 4th Gear May 23, 2013 Share May 23, 2013 My cam kept beeping sound like when no sd card detected though I have put it in. I tool out and put in again also same problem. Anyone got this problem? Link to post Share on other sites More sharing options...
Rayleigh 6th Gear May 23, 2013 Share May 23, 2013 My cam kept beeping sound like when no sd card detected though I have put it in. I tool out and put in again also same problem. Anyone got this problem? Check the write-protect latch on the SD card. Otherwise, your SD card having problem. You can also try: disconnecting the power from the recorder, insert SD card and finally connect back the power. Link to post Share on other sites More sharing options...
WTF 4th Gear May 23, 2013 Share May 23, 2013 Check the write-protect latch on the SD card. Otherwise, your SD card having problem. You can also try: disconnecting the power from the recorder, insert SD card and finally connect back the power. If it's the sd card, could it be that I need to reformat it? Btw, how often should it be reformat? Link to post Share on other sites More sharing options...
WTF 4th Gear May 23, 2013 Share May 23, 2013 Check the write-protect latch on the SD card. Otherwise, your SD card having problem. You can also try: disconnecting the power from the recorder, insert SD card and finally connect back the power. I checked that the card is indeed unlocked but recorder still can't detect. Then I locked and unlocked the card and turn on the recorder, this time it was able to detect. Guessed it's prob my card's latch problem. Link to post Share on other sites More sharing options...
Vvman May 23, 2013 Share May 23, 2013 hi guys...seems my 100hd sp got no sound when playback even though i have enabled sound recording (with green light on), anyone knows why this is happening? ITB100HD light Flashing Red - Mic On, No GPS signal Flashing Green - Mic Off, No GPS Solid Red - Mic On, GPS signal detected Solid Green - Mic Off, GPS signal detected. Obviously, with green light on, your ITB sound is disabled Link to post Share on other sites More sharing options...
GemLeo 1st Gear May 24, 2013 Share May 24, 2013 I checked that the card is indeed unlocked but recorder still can't detect. Then I locked and unlocked the card and turn on the recorder, this time it was able to detect. Guessed it's prob my card's latch problem. i encounter it once. keep beeping. i formatted the card and its ok... it was when i used the ipass 8gb card. think memory full.. r u using the same card? Link to post Share on other sites More sharing options...
Karilaksa Neutral Newbie May 24, 2013 Share May 24, 2013 ITB100HD light Flashing Red - Mic On, No GPS signal Flashing Green - Mic Off, No GPS Solid Red - Mic On, GPS signal detected Solid Green - Mic Off, GPS signal detected. Obviously, with green light on, your ITB sound is disabled duh.....thanks bro... Link to post Share on other sites More sharing options...
Rayleigh 6th Gear May 24, 2013 Share May 24, 2013 If it's the sd card, could it be that I need to reformat it? Btw, how often should it be reformat? I have no idea. Been using it since last year and format it once when i upgraded the firmware recently. hahaha.... Link to post Share on other sites More sharing options...
QQDreamer 4th Gear May 25, 2013 Share May 25, 2013 not sure if any of the bros here experience that the 100HD or 100HD SP have this "WHOOOT" sound? any bros here know what is this sound? Link to post Share on other sites More sharing options...
Mcf777 Turbocharged May 25, 2013 Share May 25, 2013 i have SP and HD set in my car. what sound? can explain more? i dont seem to hear it. I only know SP set damn irritating, kept on saying out voice message. At least 3-4 different types of voice message. make my car sound so cheapo when i fetch my boss. did you manage to find ways to stop these voice message? Link to post Share on other sites More sharing options...
QQDreamer 4th Gear May 25, 2013 Share May 25, 2013 i have SP and HD set in my car. what sound? can explain more? i dont seem to hear it. I only know SP set damn irritating, kept on saying out voice message. At least 3-4 different types of voice message. make my car sound so cheapo when i fetch my boss. did you manage to find ways to stop these voice message? dun really know how to describe the sound. is like "WHOOOT" whistle sound. do you have this problem? Link to post Share on other sites More sharing options...
Frostedshreddies Neutral Newbie May 25, 2013 Share May 25, 2013 When I change some settings via the computer / PC player (e.g. sound, sensitivity, road speed), it doesn't seem to save these settings after I use the SD card back in the ITB-100HD. Anybody got any ideas? Also, can you format the SD card without needing to use the computer? I think somebody said something about holding some button etc..... And if you format the SD card on the computer, all the settings files get deleted. So when you put the card back into the DVR, I assume the last known settings files will get copied back into the SD card? Link to post Share on other sites More sharing options...
Frostedshreddies Neutral Newbie May 25, 2013 Share May 25, 2013 When I change some settings via the computer / PC player (e.g. sound, sensitivity, road speed), it doesn't seem to save these settings after I use the SD card back in the ITB-100HD. Anybody got any ideas? Also, can you format the SD card without needing to use the computer? I think somebody said something about holding some button etc..... And if you format the SD card on the computer, all the settings files get deleted. So when you put the card back into the DVR, I assume the last known settings files will get copied back into the SD card? Oh, found the answer for formatting. Press and hold Mic on/off button for 5 seconds. Anybody got any answer for the first and last questions? Thanks. Link to post Share on other sites More sharing options...
Mcf777 Turbocharged May 25, 2013 Share May 25, 2013 Bro. Didnt come across the sound u mention. Link to post Share on other sites More sharing options...
Karilaksa Neutral Newbie May 25, 2013 Share May 25, 2013 (edited) can any kind bros here pm me the shop to install the itv80 for conti ride? Edited May 25, 2013 by Karilaksa Link to post Share on other sites More sharing options...
Car_accessories Neutral Newbie May 25, 2013 Share May 25, 2013 Bro if u travel north for makan... Can install there... Did mine for 60rm nia.. ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
How to feedback on hospital service?
Seen the new look on Sgcarmart's Used Car pages? Love it or hate it? We want to hear from you!
Anyone have invested in SSB?
Feedback on hazard
Feedback on hazard
Cannot post an Ad
Cannot post an Ad
Any feedback on castlewoodgroup?
VW Tiguan 2011-2012 feedback
