Octopus 3rd Gear June 20, 2013 Share June 20, 2013 Hi all, I received my ITB100HD last weeks but I have noticed that when setting to Parking Mode (both shock + motion) the unit sometime do record when there seems to be no movement detected. Anyone experiencing this problem? I have already set the shock to be most sensitive and motion to be least sensitive, yet few times it still record for no apparent reason. Location is inside multi-story carpark and confirm no movement can been seen. Also the files recorded in parking mode sometime is purple "P" and some are green "P". What does the colour difference mean? ↡ Advertisement Link to post Share on other sites More sharing options...
Xers007 Supercharged June 21, 2013 Share June 21, 2013 Hi all, I received my ITB100HD last weeks but I have noticed that when setting to Parking Mode (both shock + motion) the unit sometime do record when there seems to be no movement detected. Anyone experiencing this problem? I have already set the shock to be most sensitive and motion to be least sensitive, yet few times it still record for no apparent reason. Location is inside multi-story carpark and confirm no movement can been seen. Also the files recorded in parking mode sometime is purple "P" and some are green "P". What does the colour difference mean? the manual mention the recording can be resumed by surrounding noises (close to factory, street side). No idea of the color of the "P" but could it be motion activate and shock activate recording. Link to post Share on other sites More sharing options...
Scoots 3rd Gear June 23, 2013 Share June 23, 2013 Use SD card and not use micro SD card Sd card use class 10 SD card Brand= sandisk or samsung Size = max 32gd Went looking for a larger size card and realised. Class10 SD cards have different read/write speeds. Anyone have feedback on this aspect? The Sandisk Extreme Class10 SD card damn pricey wor.... Link to post Share on other sites More sharing options...
Zhutou Clutched June 23, 2013 Share June 23, 2013 Went looking for a larger size card and realised. Class10 SD cards have different read/write speeds. Anyone have feedback on this aspect? The Sandisk Extreme Class10 SD card damn pricey wor.... Get the cheaper class10 will do Those ex one benefits u when u wanna copy out from ur sdcard only The copy speed is faster Link to post Share on other sites More sharing options...
Zhutou Clutched June 23, 2013 Share June 23, 2013 Hi all, I received my ITB100HD last weeks but I have noticed that when setting to Parking Mode (both shock + motion) the unit sometime do record when there seems to be no movement detected. Anyone experiencing this problem? I have already set the shock to be most sensitive and motion to be least sensitive, yet few times it still record for no apparent reason. Location is inside multi-story carpark and confirm no movement can been seen. Also the files recorded in parking mode sometime is purple "P" and some are green "P". What does the colour difference mean? Car drive passed, birds flying, trees moving, people walk passed etc are movement These will trigger the cam to record Link to post Share on other sites More sharing options...
Octopus 3rd Gear June 23, 2013 Share June 23, 2013 After some monitoring, I think unit is working correctly except it is too sensitive. Purple "P" is for motion and green "P" is for shock sensing I tested by parking in carpark facing the wall, and I still detected (recorded) many motion. Reason is vehicles passing behind cause reflection to my ERP unit screen (display), and for this it recorded even when I parked head-in facing the wall. And my motion setting was the least sensitive. For shock setting I also set it to least sensitive cos if its in the most sensitive mode, even the wind blow will cause shock sensing and recording starts (i.e. green "P"). I assume its wind cos can see the shock sensing activated (seen from shock sensing bar) even there is no obvious movement around. Anyone find the setting (motion and shock sensing) in parking mode too sensitive that it records unnecessary footage? Link to post Share on other sites More sharing options...
Mysportwish 1st Gear June 23, 2013 Share June 23, 2013 sometime..the camera also capture other event that you least expected... steady bro, 1st time see a dish turn.. thanks for sharing Link to post Share on other sites More sharing options...
Mysportwish 1st Gear June 23, 2013 Share June 23, 2013 Curious where do most bros situate such a switch and how is it mounted? i hv spare slot beside my alarm light and the installer took out the cover and cut a nice hole to install the switch... Link to post Share on other sites More sharing options...
Jtb 6th Gear June 23, 2013 Share June 23, 2013 Get the cheaper class10 will do Those ex one benefits u when u wanna copy out from ur sdcard only The copy speed is faster Sandisk is the safest.bought toshiba n samsung both worked for a recording n continuous beep after the nx cold start.u need to format again to get it work. So no gd.Sandisk @$39. Link to post Share on other sites More sharing options...
Ruhoseh Neutral Newbie June 24, 2013 Share June 24, 2013 Hi Bros, read through the entire posts. Itching to get either ITB100HD or ITB100HDSP, any lobangs to share? Link to post Share on other sites More sharing options...
Zhutou Clutched June 24, 2013 Share June 24, 2013 Sandisk is the safest.bought toshiba n samsung both worked for a recording n continuous beep after the nx cold start.u need to format again to get it work. So no gd.Sandisk @$39. i feel that not much diff la i use silicon brand (u heard this brand before?) around $27 for 1 year already still good till now IMO dun use microSD with adapter for car dvr, it wont last long use SDHC instead Link to post Share on other sites More sharing options...
Zhutou Clutched June 24, 2013 Share June 24, 2013 Hi Bros, read through the entire posts. Itching to get either ITB100HD or ITB100HDSP, any lobangs to share? since u have read through the thread, u should know where to buy liao ma Link to post Share on other sites More sharing options...
Kb27 Supersonic June 25, 2013 Share June 25, 2013 Those who use camera in parked mode, surveillance, etc..should prepare themselves with jump start cables and spare battery or someone you can reached easily for a jump start. Don't rely too much on the "auto" cut-off promises. There may be bugs in the firmware or things not working as planned. As long as the camera is wired directly to the car starting battery, you are exposed to a flat battery. Link to post Share on other sites More sharing options...
Cerealkiller 1st Gear June 25, 2013 Share June 25, 2013 Really wonder how they manage to sell it cheaper than manufacturer? manufacturer will of course sell at Premium Pricing. Same like cars, BMW sells at XXX amount, while dealers can give you same XXX price with discounts etc. Link to post Share on other sites More sharing options...
GemLeo 1st Gear June 25, 2013 Share June 25, 2013 Those who use camera in parked mode, surveillance, etc..should prepare themselves with jump start cables and spare battery or someone you can reached easily for a jump start. Don't rely too much on the "auto" cut-off promises. There may be bugs in the firmware or things not working as planned. As long as the camera is wired directly to the car starting battery, you are exposed to a flat battery. hi bro, did u get a flat battery? were you using power saver and what is your settings? Link to post Share on other sites More sharing options...
Ultra-Magnus Clutched June 25, 2013 Share June 25, 2013 Alamak! Nmind, this seller got good track record and very prompt in his response. Sent me the english firmware in zip file after I asked him about it. Cheers! Mcf got lots of poison, always tempted to buy this upgrade that Link to post Share on other sites More sharing options...
Kb27 Supersonic June 26, 2013 Share June 26, 2013 hi bro, did u get a flat battery? were you using power saver and what is your settings? Not me. But I get calls to jump start car in my business. Usually when I get there, there's always a ITB100 stuck on the window. When I ask the owner, they tell me about their power saver...blah..blah..blah. If you want my advice, don't trust the power saver, unless you have jumper cables and standby starter battery ready. Otherwise, it may make your day miserable. Link to post Share on other sites More sharing options...
Adrianli Hypersonic June 26, 2013 Share June 26, 2013 Not me. But I get calls to jump start car in my business. Usually when I get there, there's always a ITB100 stuck on the window. When I ask the owner, they tell me about their power saver...blah..blah..blah. If you want my advice, don't trust the power saver, unless you have jumper cables and standby starter battery ready. Otherwise, it may make your day miserable. Because these ppl never realise that other car electronics are also draining the battery too. Power saver only effective for the camera, the other electronics continue to drain even if power saver cut-off supply to the camera. Me use external battery pack, no worries of drain battery or warranty. ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
How to feedback on hospital service?
Seen the new look on Sgcarmart's Used Car pages? Love it or hate it? We want to hear from you!
Anyone have invested in SSB?
Feedback on hazard
Feedback on hazard
Cannot post an Ad
Cannot post an Ad
Any feedback on castlewoodgroup?
VW Tiguan 2011-2012 feedback
