Intel Clutched May 25, 2013 Share May 25, 2013 (edited) Bros who install a switch using ITV80. Any idea where the installer/you tap the switch? I went ahead to order a HD + ITV80. Thinking of installing the switch between the constant voltage wire and the ITV80 so when I off my vehicle, I have the option of turning on or off the ITB100HD. Is that where you all install the switch too? Edited May 25, 2013 by Intel ↡ Advertisement Link to post Share on other sites More sharing options...
Xers007 Supercharged May 25, 2013 Share May 25, 2013 (edited) Haiz.. unlucky me... just got the cam and found out that the pin on the cigarette socket plug of the power cable has broken off... Edited May 25, 2013 by Xers007 Link to post Share on other sites More sharing options...
WTF 4th Gear May 26, 2013 Share May 26, 2013 (edited) I just view my recent videos and found that one (so far) of it is jerky and hang-stop-hang-stop during play and the video is also distorted at times. However the last and next video didn't have such problems......... Edited May 26, 2013 by WTF Link to post Share on other sites More sharing options...
Skchiu 2nd Gear May 26, 2013 Share May 26, 2013 When I change some settings via the computer / PC player (e.g. sound, sensitivity, road speed), it doesn't seem to save these settings after I use the SD card back in the ITB-100HD. Anybody got any ideas? try formatting your SD card using the cam, then insert SD card to computer and do the settings, this should enable settings to be saved in SD card And if you format the SD card on the computer, all the settings files get deleted. So when you put the card back into the DVR, I assume the last known settings files will get copied back into the SD card? yes it seems so for me Link to post Share on other sites More sharing options...
Skchiu 2nd Gear May 26, 2013 Share May 26, 2013 I just view my recent videos and found that one (so far) of it is jerky and hang-stop-hang-stop during play and the video is also distorted at times. However the last and next video didn't have such problems......... seems like your cam is going to be faulty soon mine also like this before it finally happy record not happy dun record Link to post Share on other sites More sharing options...
Nicholas 5th Gear May 26, 2013 Share May 26, 2013 I just view my recent videos and found that one (so far) of it is jerky and hang-stop-hang-stop during play and the video is also distorted at times. However the last and next video didn't have such problems......... Try another brand of SD card. Link to post Share on other sites More sharing options...
WTF 4th Gear May 26, 2013 Share May 26, 2013 Try another brand of SD card. that was the one I bought.....now trying the one from iPass........ Link to post Share on other sites More sharing options...
WTF 4th Gear May 26, 2013 Share May 26, 2013 seems like your cam is going to be faulty soon mine also like this before it finally happy record not happy dun record mine problem video did record.....just that the video is distorted.......but after that video all that followed were fine as far as i checked...... Link to post Share on other sites More sharing options...
QQDreamer 4th Gear May 27, 2013 Share May 27, 2013 mine problem video did record.....just that the video is distorted.......but after that video all that followed were fine as far as i checked...... maybe could be due to bad sector in the SD card. Link to post Share on other sites More sharing options...
WTF 4th Gear May 27, 2013 Share May 27, 2013 maybe could be due to bad sector in the SD card. that's why I'm checking the videos these few days.......not sure if does reformat helps boh......and coincidentally it's the same sd card that give me the "sd card not detected" problem....... Link to post Share on other sites More sharing options...
QQDreamer 4th Gear May 27, 2013 Share May 27, 2013 that's why I'm checking the videos these few days.......not sure if does reformat helps boh......and coincidentally it's the same sd card that give me the "sd card not detected" problem....... ok.. but i think is the card problem and not the DVR problem. Link to post Share on other sites More sharing options...
Intel Clutched May 28, 2013 Share May 28, 2013 Anyone added a on off switch for the ITV-80? Link to post Share on other sites More sharing options...
WTF 4th Gear May 28, 2013 Share May 28, 2013 ok.. but i think is the card problem and not the DVR problem. I've reformat the sd card and checked the videos again......so far so good........ Link to post Share on other sites More sharing options...
Karilaksa Neutral Newbie May 28, 2013 Share May 28, 2013 still looking for installer.. can anyone advise? Link to post Share on other sites More sharing options...
GemLeo 1st Gear May 28, 2013 Share May 28, 2013 install the cam? hmmm there were some shops in earlier posts... market rate about sgd30 ba Link to post Share on other sites More sharing options...
QQDreamer 4th Gear May 29, 2013 Share May 29, 2013 Anyone added a on off switch for the ITV-80? just curious, why do you need a on off switch? and if by doing so why not just plug in to cigar socket and just record only while you drive. you want to install the switch just because only you want to do parking mode recording than why you buy ITV-80 leh? ITC-80 is for parking recording ma. if want to install than dont worry bro. Not going to drain your car batt away overnight. This my opinion. Link to post Share on other sites More sharing options...
QQDreamer 4th Gear May 29, 2013 Share May 29, 2013 I've reformat the sd card and checked the videos again......so far so good........ did you perform first format when you first install the card into the DVR? if not i think this could probably be your previous problem. Should be ok now already, monitor and see how lo. Link to post Share on other sites More sharing options...
WTF 4th Gear May 29, 2013 Share May 29, 2013 did you perform first format when you first install the card into the DVR? if not i think this could probably be your previous problem. Should be ok now already, monitor and see how lo. I did the first format by using the pc software. Yesterday by the car cam itself before starting the recording. Would be monitoring these few days........ ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
How to feedback on hospital service?
Seen the new look on Sgcarmart's Used Car pages? Love it or hate it? We want to hear from you!
Anyone have invested in SSB?
Feedback on hazard
Feedback on hazard
Cannot post an Ad
Cannot post an Ad
Any feedback on castlewoodgroup?
VW Tiguan 2011-2012 feedback
