Tatty Neutral Newbie November 2, 2012 Share November 2, 2012 i believe it is be better next week halloween just over ↡ Advertisement Link to post Share on other sites More sharing options...
Happily1986 5th Gear November 2, 2012 Share November 2, 2012 Bro what talking you? seems like your car recently got quite a few issues. Is it possible there is a background issue causing all these problems? My guess is that you are not longer servicing at Tan Chong. How about going back to do a diagnostics? Link to post Share on other sites More sharing options...
Hamburger Hypersonic November 2, 2012 Share November 2, 2012 Bro, Nissan right? Could be the module in the steering wheel which houses the terminals for horn, signal, cruise control etc. That's what happen to my friend's cefiro. Link to post Share on other sites More sharing options...
Shor 1st Gear November 3, 2012 Author Share November 3, 2012 seems like your car recently got quite a few issues. Is it possible there is a background issue causing all these problems? My guess is that you are not longer servicing at Tan Chong. How about going back to do a diagnostics? Youre right bro, you seems know me quite well leh Link to post Share on other sites More sharing options...
Shor 1st Gear November 3, 2012 Author Share November 3, 2012 Bro, Nissan right? Could be the module in the steering wheel which houses the terminals for horn, signal, cruise control etc. That's what happen to my friend's cefiro. Yes Bro burger, Nissan..... No see you in futsal nowadays? Link to post Share on other sites More sharing options...
Shor 1st Gear November 3, 2012 Author Share November 3, 2012 CONCLUSION All the above not correct Theres a spiral coil in the Airbag causing the problem. Link to post Share on other sites More sharing options...
Hamburger Hypersonic November 3, 2012 Share November 3, 2012 CONCLUSION All the above not correct Theres a spiral coil in the Airbag causing the problem. thats the thing. That piece of spiral coil has all the terminals that connects all fixtures on the steering wheels. Proly has to replace the whole unit which cost less than 200 Link to post Share on other sites More sharing options...
Shor 1st Gear November 8, 2012 Author Share November 8, 2012 thats the thing. That piece of spiral coil has all the terminals that connects all fixtures on the steering wheels. Proly has to replace the whole unit which cost less than 200 Exactly it's solved DIY. It's the "Spiral Coil" in the steering worn out. Link to post Share on other sites More sharing options...
Ronleech 2nd Gear November 8, 2012 Share November 8, 2012 wiring or horn spoilt...cheap... Link to post Share on other sites More sharing options...
Shor 1st Gear November 8, 2012 Author Share November 8, 2012 wiring or horn spoilt...cheap... It's the spiral coil which connect all the wiring for the Audio, Signal and horn. Buy the whole thing from retail and DIY. Costing not more than $200. So not water go in horn, not relay problem .IMO Link to post Share on other sites More sharing options...
Hamburger Hypersonic November 8, 2012 Share November 8, 2012 Exactly it's solved DIY. It's the "Spiral Coil" in the steering worn out. I don't encourage DIY as there is a sequence in installation and the attachment can only be taken out when installation is in placed. Failing to do so will render the new part useless. I saw how it was done on the cefiro and .. Link to post Share on other sites More sharing options...
Shor 1st Gear November 8, 2012 Author Share November 8, 2012 I don't encourage DIY as there is a sequence in installation and the attachment can only be taken out when installation is in placed. Failing to do so will render the new part useless. I saw how it was done on the cefiro and .. But this issue very clear cut, open, install, closed. Link to post Share on other sites More sharing options...
Hamburger Hypersonic November 8, 2012 Share November 8, 2012 The spiral thingy is secured with an attachment that can only be taken out after installation. DO NOT unsecure it when taken out from the box when new. ↡ Advertisement Link to post Share on other sites More sharing options...
Balancing work and family life
The Big Read: Understanding why millennials and Gen Zers feel the way they do about work
Extend retirement age? Maybe it's time to think about that from another perspective
This Is Why Some People Get Promoted At Work
Ultrasonic electronic mosquito repellent. does it work?
