Damienic 5th Gear December 11, 2012 Share December 11, 2012 update: i use iphone charger to charge. ok leh. think its a charger problem. mine is use iphone charger still got problem. so likely its the samsung cable fault and not the charger fault for my case.. ↡ Advertisement Link to post Share on other sites More sharing options...
Happily1986 5th Gear December 11, 2012 Share December 11, 2012 hi bros. it charges damm slow.... sometimes i charge over night only 80+% anyone else got this problem? Chargers that are designed to charge Lithium Ion batteries usually fast charge the battery to about 80% and then trickle charge from then on to full. Trickle charging is supposed to minimise thermal dissipation which is bad for the service lifespan of the battery i.e. number of lifetime charging cycles and eventually battery stamina. It seems to me that your phone is draining the battery capacity at a higher rate than the latter can be charged in the trickle charge phase. A probable cause is that your phone is being kept awake. We call this a wakelock. A wakelock is a software method for applications to control the power state of your device. The purpose of a wakelock is in its name, to lock your device in an awake state keeping the CPU running and preventing it from entering Deep Sleep (Think of a music app or video player). A wakelock can also cause your device to turn on (think syncs or notifications). Two main kinds of wakelock. 1.) Screen is lit and CPU is running. Kernel Wakelock 2.) Screen is off and CPU is running instead of being in deep sleep. Partial Wakelock. Seems to me that Scenario 2 is the cause of your issue. Link to post Share on other sites More sharing options...
Little_prince Supersonic December 11, 2012 Author Share December 11, 2012 (edited) Chargers that are designed to charge Lithium Ion batteries usually fast charge the battery to about 80% and then trickle charge from then on to full. Trickle charging is supposed to minimise thermal dissipation which is bad for the service lifespan of the battery i.e. number of lifetime charging cycles and eventually battery stamina. It seems to me that your phone is draining the battery capacity at a higher rate than the latter can be charged in the trickle charge phase. A probable cause is that your phone is being kept awake. We call this a wakelock. A wakelock is a software method for applications to control the power state of your device. The purpose of a wakelock is in its name, to lock your device in an awake state keeping the CPU running and preventing it from entering Deep Sleep (Think of a music app or video player). A wakelock can also cause your device to turn on (think syncs or notifications). Two main kinds of wakelock. 1.) Screen is lit and CPU is running. Kernel Wakelock 2.) Screen is off and CPU is running instead of being in deep sleep. Partial Wakelock. Seems to me that Scenario 2 is the cause of your issue. ok makes sense bro.... then how do i put it to sleep? Edited December 11, 2012 by Little_prince Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear December 11, 2012 Share December 11, 2012 ok makes sense bro.... then how do i put it to sleep? A different phone, but the process is the same http://www.allaboutgalaxynote.com/how-to-s...ur-galaxy-note/ Link to post Share on other sites More sharing options...
Little_prince Supersonic December 11, 2012 Author Share December 11, 2012 A different phone, but the process is the same http://www.allaboutgalaxynote.com/how-to-s...ur-galaxy-note/ thanks bro! Link to post Share on other sites More sharing options...
Little_prince Supersonic December 11, 2012 Author Share December 11, 2012 Anyway, this is a kernel bug in ICS, we have to wait for new update. The solution for this is: shutdown your Note, peel off the back cover, remove the battery; hold the battery for more than one min, put the battery back, put back the back cover; start the phone. Then, everything goes back to normal. Reboot your phone will NOT solver this issue, at least for me. sibei leceh.... haiz Link to post Share on other sites More sharing options...
BabyBlade Internal Moderator December 11, 2012 Share December 11, 2012 Wow so they will change the faulty chargers free of charge for us? yes within 6 months of purchase show your proof of purchase. Link to post Share on other sites More sharing options...
Happily1986 5th Gear December 12, 2012 Share December 12, 2012 A different phone, but the process is the same http://www.allaboutgalaxynote.com/how-to-s...ur-galaxy-note/ it is actually not really necessary to install CPUSpy since the same function has been implemented in BetterBatteryStats and in the latter, it is even better because you can set a custom time marker to monitor CPU States among the default time markers available in BBS. ↡ Advertisement Link to post Share on other sites More sharing options...
Who's right?
Who's right?
Android Phones
Android Phones
Town Council S&C Charges May Increase Soon!
Samsung and Huawei crush Apple's smartphone global share
Parking Charges at Sim lim square area??
Maid abuse: Couple face more charges
Suu Kyi detained
Suu Kyi detained
Ex-Samsung exec indicted for stealing trade secrets to build copycat plant in China
