Billcoke 2nd Gear January 27, 2013 Share January 27, 2013 Bro, Note 2 : Li-Ion 3100 mAh battery Note 1: Li-Ion 2500 mAh battery Are Galaxy Note and Note 2 battery interchangeable? Do they share the same battery? ↡ Advertisement Link to post Share on other sites More sharing options...
Gee 1st Gear January 28, 2013 Share January 28, 2013 i believe they share the same battery format. http://stellatech.com/samsung-gt-n8000-gal...,en,813657.html Link to post Share on other sites More sharing options...
Redstorm 1st Gear January 28, 2013 Share January 28, 2013 (edited) Bro, Note 2 : Li-Ion 3100 mAh battery Note 1: Li-Ion 2500 mAh battery Are Galaxy Note and Note 2 battery interchangeable? Do they share the same battery? Prevously, when I changed my S2 battery to a higher capacity one, the higher capacity Samsung battery package came with a back cover to accomodate the thicker battery which the original back cover couldn't fit. I don't own a Note, but basing on my experience, you might need to change the back cover to accomodate the thicker size battery if the higher capacity Note 2 battery can fit on the Note 1. I may be wrong here but it is better to consult Samsung about this. Edited January 28, 2013 by Redstorm Link to post Share on other sites More sharing options...
Kwchan 1st Gear January 28, 2013 Share January 28, 2013 Note 1 battery is slightly smaller than Note 2 and the pin-out is same as note2 so u can put Note 1 battery in Note2 but not the other way round however, since note 1 batt is smaller, u need to stuff some paper to fill up the gaps Link to post Share on other sites More sharing options...
Billcoke 2nd Gear January 28, 2013 Author Share January 28, 2013 (edited) i believe they share the same battery format. http://stellatech.com/samsung-gt-n8000-gal...,en,813657.html I checked with the shops at Ebay, they feedback that the battery is not interchangeable. Edited January 28, 2013 by Billcoke Link to post Share on other sites More sharing options...
Billcoke 2nd Gear January 28, 2013 Author Share January 28, 2013 Prevously, when I changed my S2 battery to a higher capacity one, the higher capacity Samsung battery package came with a back cover to accomodate the thicker battery which the original back cover couldn't fit. I don't own a Note, but basing on my experience, you might need to change the back cover to accomodate the thicker size battery if the higher capacity Note 2 battery can fit on the Note 1. I may be wrong here but it is better to consult Samsung about this. I see. thanks. Link to post Share on other sites More sharing options...
Billcoke 2nd Gear January 28, 2013 Author Share January 28, 2013 Note 1 battery is slightly smaller than Note 2 and the pin-out is same as note2 so u can put Note 1 battery in Note2 but not the other way round however, since note 1 batt is smaller, u need to stuff some paper to fill up the gaps Thanks. Link to post Share on other sites More sharing options...
Gee 1st Gear January 28, 2013 Share January 28, 2013 I checked with the shops at Ebay, they feedback that the battery is not interchangeable. ok thanks, will remember that if i need batt rep for my note. Link to post Share on other sites More sharing options...
Gabriel 1st Gear January 28, 2013 Share January 28, 2013 Bro, Note 2 : Li-Ion 3100 mAh battery Note 1: Li-Ion 2500 mAh battery Are Galaxy Note and Note 2 battery interchangeable? Do they share the same battery? Note has a 5,000mAh battery selling online...comes with an extra back case...can search online for it..def bigger capacity then Note 2..but um..if u get this..u cant use any other casing..and ur phone has to be naked after that ↡ Advertisement Link to post Share on other sites More sharing options...
My EV journey to the i4
2021 3rd Generation Nissan Note (E13)
Battery Voltage up & down
Request for dark mode
The Electric Vehicle Charging Problem
Lithium-Iron Battery (LFP) - New & Better Alternative?
Car key fob battery
Car key fob battery
