Cichildae Neutral Newbie January 30, 2013 Share January 30, 2013 Hi all,Does anyone knw hw to differentiate btw a real n fake hks turbo timer? ↡ Advertisement Link to post Share on other sites More sharing options...
Lava 5th Gear January 30, 2013 Share January 30, 2013 Now a day still need turbo timer on turbo charge car? Link to post Share on other sites More sharing options...
Kiadaw 6th Gear January 30, 2013 Share January 30, 2013 Waste money only leh. I have 2 turbo cars, never need one, never do those cooling off like wait 5 mins then turn off engine. If it is useful, it will come from the factory right? Link to post Share on other sites More sharing options...
Ali_baba Neutral Newbie January 30, 2013 Share January 30, 2013 (edited) Unless u upgrade big turbo, constant high boost, then u need to cool the turbo, to increase the life span of ur turbo. Kiadaw, i disagree with ur saying, u said that if its useful it should come with stock. Den why stock dun have better intake system, Y stock brakes have to change, Y u dun wan to keep with stock tires. The list goes on .... But, turbo timer is to protect ur turbo la, u can set min sec to cool down, 5 mins is ridicules long la. unless go track. Edited January 31, 2013 by Ali_baba Link to post Share on other sites More sharing options...
Sucker Clutched January 31, 2013 Share January 31, 2013 nowadays, turbo has water cool and oil cool. Hence, it is not neccesary to have turbo timer. After a hard lap and go for a cool lap.. Unless u upgrade big turbo, constant high boost, then u need to cool the turbo, to increase the life span of ur turbo. Kiadaw, i disagree with ur saying, u said that if its useful it should come with stock. Den why stock dun have better intake system, Y stock brakes have to change, Y u dun wan to keep with stock tires. The list goes on .... But, turbo timer is to protect ur turbo la, u can set min sec to cool down, 5 mins is ridicules long la. unless go track. Link to post Share on other sites More sharing options...
Caravan 5th Gear January 31, 2013 Share January 31, 2013 Normally the slow drive and parking in the carpark is enough to cool down the turbo, for normal driving. Link to post Share on other sites More sharing options...
Soya Supersonic January 31, 2013 Share January 31, 2013 Now a day still need turbo timer on turbo charge car? yalor. thot that kinda thing same era as the pager. Link to post Share on other sites More sharing options...
Lava 5th Gear January 31, 2013 Share January 31, 2013 new car come with 3 to 5 years warranty. why border to waste time go to fix tis fix tat. Link to post Share on other sites More sharing options...
Vega Turbocharged January 31, 2013 Share January 31, 2013 Waste money only leh. I have 2 turbo cars, never need one, never do those cooling off like wait 5 mins then turn off engine. If it is useful, it will come from the factory right? Some stock cars do come with turbo timer. Link to post Share on other sites More sharing options...
Soya Supersonic January 31, 2013 Share January 31, 2013 Some stock cars do come with turbo timer. which one? Link to post Share on other sites More sharing options...
Cmcrazy Clutched January 31, 2013 Share January 31, 2013 which one? you guys will never gonna believe it, my previous ride jetta sport does come with stock turbo timer (idle for about 10-15 sec). Haaa for TS, i reckon he wanna have a turbo timer for hao lian one lah... Cheers Link to post Share on other sites More sharing options...
Tweakmax2 Neutral Newbie January 31, 2013 Share January 31, 2013 anyone does a turbo timer on a NA car? Link to post Share on other sites More sharing options...
Vega Turbocharged January 31, 2013 Share January 31, 2013 which one? as what bro Cmcrazy said, some VW models come with turbo timer. Link to post Share on other sites More sharing options...
Holdenutessv Turbocharged January 31, 2013 Share January 31, 2013 anyone does a turbo timer on a NA car? Got... For show or use it as a clock. Link to post Share on other sites More sharing options...
Mllcg 3rd Gear January 31, 2013 Share January 31, 2013 Waste money only leh. I have 2 turbo cars, never need one, never do those cooling off like wait 5 mins then turn off engine. If it is useful, it will come from the factory right? germany not that hot leh bro Link to post Share on other sites More sharing options...
Kiadaw 6th Gear January 31, 2013 Share January 31, 2013 germany not that hot leh bro You may be right, & there maybe something magical about the TFSI engine. It almost never even gets hot, even on long road trips at high speed. Sometimes, when there is snow cover, I can drive 20 mins (which is what it takes to get to work), the snow can still be on the bonnet, if they are not already brown off by the speed. But the last car I have in Singapore, which incidentally take around same time to get to work. You can practically fry an egg on the bonnet, even when you drive normally. But its not just my car. You can know how long a car is parked by just put your hand near the bonnet. But normally, just slow doen last 5 mins, even on hard drive will do the trick to 'cool' the engine. Why risk a turbo timer, if install wrong, or faulty, can damage your car or something. At most just let the engine run for some time, then get off the car. ↡ Advertisement Link to post Share on other sites More sharing options...
HKS Power Charger
HKS Power Charger
K&N or HKS airfilter.?
Hks 3 layer dry replacement filter
Cold Air Intake
Cold Air Intake
Best octane booster in local market
Coilovers exprience sharing
Looking for a HKS F Con V Pro V3.2 or 3.3
