Seanboi 1st Gear June 25, 2017 Share June 25, 2017 For F50 users, do check if your night videos are blurry. I am on my second set of F50 and night footage are still blurry. ↡ Advertisement Link to post Share on other sites More sharing options...
Soho 4th Gear June 25, 2017 Share June 25, 2017 Any comment on thinkware x550? Was given a choice by SE btw thinkware x550 and blackvue dr650s. I understand that thinkware is more ex than blaclvue. Does x550 have wifi connect for direct download? Link to post Share on other sites More sharing options...
Bape85 1st Gear June 26, 2017 Share June 26, 2017 Any comment on thinkware x550? Was given a choice by SE btw thinkware x550 and blackvue dr650s. I understand that thinkware is more ex than blaclvue. Does x550 have wifi connect for direct download? the rear cam for X550 is full hd , the 650s is only HD . the thinkware comes with speedcamera warning ( for all speed camera and red light camera ) , and Forward vehicle departure warning ( just in case you dreaming at the traffic light ) and also not mentioning the ADAS features like FCW LDWS which some of the people find irritating so i will skip that as a pro . It doesnt have wifi but file retrieval is very easy . What car are you buying ? its good that they give you such good cameras . using thinkware x550 which comes with lexus. What should I set for the min and max voltage? lower if you want longer recording , higher if you are afraid . But it wont kill your car anyway . so far mine didnt die unless my battery is critically due for a change . Link to post Share on other sites More sharing options...
7hm Turbocharged June 27, 2017 Share June 27, 2017 Read a report that recently Samsung has launched a new Evo+ card that bears the UHS 3 specification on the cards that doesn't work with Thinkware devices. So there are two versions of the 128Gb Evo+ floating around, one has UHS 3 specs and makes the F770 freak out while the other with UHS 1 specs works fine. Attached 2 pics of the different Evo+ 128gb SD cards for comments and verifications from fellow users.... Apparently Samsung does not warrant their SD cards for use in surveillance cameras or dash cams... Link to post Share on other sites More sharing options...
mercymercy 2nd Gear July 24, 2017 Share July 24, 2017 Anyone installed the Thinkware battery pack ivolt? Care to share the experience? Link to post Share on other sites More sharing options...
darkwish 1st Gear July 24, 2017 Share July 24, 2017 anyone that installed the F770 did they use a F770 or F750 rear cam? my F770 that i got they installed a F750 rear cam for mine is that normal? is the 770 and 750 rear cam the same or is there actually quality difference? Link to post Share on other sites More sharing options...
mercymercy 2nd Gear July 25, 2017 Share July 25, 2017 anyone that installed the F770 did they use a F770 or F750 rear cam? my F770 that i got they installed a F750 rear cam for mine is that normal? is the 770 and 750 rear cam the same or is there actually quality difference? Bro, two days ago i was at ZMC Serangoon North Ave 4 branch to enquire about the diff between 770 vs 750. I specifically asked the sales lady about the diff between the rear cam of 770 vs 750 and she said they are diff. The 770 rear cam has super night vision which the 750 rear cam does not. Hope this helps. Link to post Share on other sites More sharing options...
darkwish 1st Gear July 25, 2017 Share July 25, 2017 Bro, two days ago i was at ZMC Serangoon North Ave 4 branch to enquire about the diff between 770 vs 750. I specifically asked the sales lady about the diff between the rear cam of 770 vs 750 and she said they are diff. The 770 rear cam has super night vision which the 750 rear cam does not. Hope this helps. guess i got ripped off then. no wonder they didnt give me the box for the rear cam and when i ask for receipt for warranty they say its recorded in their database so no need Link to post Share on other sites More sharing options...
amc717 Neutral Newbie July 27, 2017 Share July 27, 2017 Hi, I recently joined and was interested in getting some clarification regarding the unit I bought. I have the F770 installed in my Honda Stream. Just wondering if there is anyway to automatically view the videos from my phone without having to turn on manually the wifi of the F770 unit. Or am I doing it wrong? Hope you could help. Thanks. Link to post Share on other sites More sharing options...
darkwish 1st Gear July 27, 2017 Share July 27, 2017 Hi, I recently joined and was interested in getting some clarification regarding the unit I bought. I have the F770 installed in my Honda Stream. Just wondering if there is anyway to automatically view the videos from my phone without having to turn on manually the wifi of the F770 unit. Or am I doing it wrong? Hope you could help. Thanks. you can view the videos from your phone only if you have downloaded the videos to your phone. so this means you would still have to connect to the wifi the first time round just to download the videos that you want and after that you dont have to connect to the wifi to view those videos and can play it from your phone. Link to post Share on other sites More sharing options...
amc717 Neutral Newbie July 27, 2017 Share July 27, 2017 you can view the videos from your phone only if you have downloaded the videos to your phone. so this means you would still have to connect to the wifi the first time round just to download the videos that you want and after that you dont have to connect to the wifi to view those videos and can play it from your phone. Got that. What I'm interested in is to eliminate the lag time from waiting to get connected to the wifi of the F770 plus the need to press the wifi to activate it. Isn't there a way that when I connect via the app, it will automatically turn on the wifi of the F770? Link to post Share on other sites More sharing options...
darkwish 1st Gear July 27, 2017 Share July 27, 2017 Got that. What I'm interested in is to eliminate the lag time from waiting to get connected to the wifi of the F770 plus the need to press the wifi to activate it. Isn't there a way that when I connect via the app, it will automatically turn on the wifi of the F770? would love that too but to keeping the wifi constantly on will drain the battery i guess since its gotta send the wifi signal out non stop. in another way its also for security even though theres a wifi password but people still cannot connect to it if the wifi is not on. maybe email them ask them and tell them and hope they implement such a feature in the next firmware update Link to post Share on other sites More sharing options...
amc717 Neutral Newbie July 27, 2017 Share July 27, 2017 would love that too but to keeping the wifi constantly on will drain the battery i guess since its gotta send the wifi signal out non stop. in another way its also for security even though theres a wifi password but people still cannot connect to it if the wifi is not on. maybe email them ask them and tell them and hope they implement such a feature in the next firmware update So wifi activation is always manual (i.e. I have to go inside the car and push the wifi button to turn on)? Is that true to other dash cams? I had a neighbour who showed me his dash cam live view without manually turning on the wifi of his unit. I thought the F770 would have been something like that considering it was the latest gadget when I got it. I just find it cumbersome to turn on the wifi and then wait for it be found by my bluetooth and then that's the only time I can view the recordings. It kinda takes awhile. Link to post Share on other sites More sharing options...
darkwish 1st Gear July 28, 2017 Share July 28, 2017 Read a report that recently Samsung has launched a new Evo+ card that bears the UHS 3 specification on the cards that doesn't work with Thinkware devices. So there are two versions of the 128Gb Evo+ floating around, one has UHS 3 specs and makes the F770 freak out while the other with UHS 1 specs works fine. Attached 2 pics of the different Evo+ 128gb SD cards for comments and verifications from fellow users.... wondering have you found anywhere with the U1 instead and whats the price? i search on qoo10 and lazada like all U3 now and the prices are so weird not sure if the 128gb is suppose to be so cheap Link to post Share on other sites More sharing options...
Yixiang1 3rd Gear July 30, 2017 Share July 30, 2017 So wifi activation is always manual (i.e. I have to go inside the car and push the wifi button to turn on)? Is that true to other dash cams? I had a neighbour who showed me his dash cam live view without manually turning on the wifi of his unit. I thought the F770 would have been something like that considering it was the latest gadget when I got it. I just find it cumbersome to turn on the wifi and then wait for it be found by my bluetooth and then that's the only time I can view the recordings. It kinda takes awhile. For those dashcam that auto connect ur phone to dash cam wifi, (believe Iroad can do that), the problem they have is, whenever in car, phone connect to dash cam, then phone will not have internet connection. Coz it is on this wifi network with no internet access. This is what I read Lah. Link to post Share on other sites More sharing options...
ORIN17 1st Gear July 30, 2017 Share July 30, 2017 just got my new car delivered last week. Came with the lowest end Thinkware f50, I think. There is no viewing screen to allow me to know what the camera is capturing while on the move. Thinking of trading it to one with a viewing screen. Not necessary have to be another Thinkware but one that is reliable and simple to use. Any one of you can offer suggestions? Thanks in advance. Link to post Share on other sites More sharing options...
amc717 Neutral Newbie July 30, 2017 Share July 30, 2017 For those dashcam that auto connect ur phone to dash cam wifi, (believe Iroad can do that), the problem they have is, whenever in car, phone connect to dash cam, then phone will not have internet connection. Coz it is on this wifi network with no internet access. This is what I read Lah. Thanks for the info. Eye opener. Link to post Share on other sites More sharing options...
Bape85 1st Gear July 30, 2017 Share July 30, 2017 guess i got ripped off then. no wonder they didnt give me the box for the rear cam and when i ask for receipt for warranty they say its recorded in their database so no need i upgraded from f750 to f770 , from what i know the rear camera cable both are different , so you cannot connect f750 rear cable into the f770 . i suggest you call them to double check . ↡ Advertisement Link to post Share on other sites More sharing options...
Reverse/backup camera with dashcam recording function
Thinkware F800 pro dash cam optimised settings to prevent draining car battery
Car camera recommendation
Explore High-Performance FineVu Dashcams by Auto Interior Pte Ltd
Toyota Corolla AE86 Revival! Initial D Fans COME IN!
