Maths problem
Sosaria
6 hours ago, Turboflat4 said:
 Case 2b: Let's say 3 does not divide k. Then k has a minimum prime factor of 5.
Let's say 5 is a factor of k.
Note that in this sub-case, you *cannot* conclude that 5 is a factor unique to k, since k+5 will also be a multiple of 5. A different argument is needed.
First observe that neither k+2 nor k+4 will be a multiple of 5 (reasoning modulo 5).
Therefore, k+2 must have a prime factor of 3 or a prime factor greater than or equal to 7.
If the latter case holds, then the prime factor will be unique to k+2 (done).
If the former case holds, then k+4 cannot be a multiple of 3 (reasoning modulo 3). It must have a prime factor greater than or equal to 7, and this will be unique to k+4 (done).
(Case 2b proven).
All cases proven. (QED).
Amend the above to:
Either 5 is a factor of k or 5 is not a factor of k.
If 5 is not a factor of k then k has to have a minimum prime factor of 7 or greater, which will be unique within the sequence (done).
Note that in this sub-case,...
(rest is the same).
Sorry @Vidplease add the bolded portion in to complete the proof. If your son can find any gaps, let me know (also means he's sibei smart). 😁
Hypersonic
25 minutes ago, Turboflat4 said:
Amend the above to:
(rest is the same).
You sibei smart... although I have no idea what everything is 🤣🤣
Let me try to digest some of them too. 😁
  • Haha! 1
LOL no lah... this one looks complicated because it's written out quite rigorously.
If I explain on a whiteboard or blackboard (Khan Academy style) it would be much easier. 😁
  • Haha! 1
Would like to tap on the experts here though this is a science question. A little explanation to the answer would help too. Thanks in advance
In a sense, all physics is applied math.
This is essentially very elementary graph theory if you think of the points as nodes and the wire segments as edges so it's definitely math.
The circuit tester just tells you if a connected path exists between two nodes.
Doesn't matter how many nodes in the middle, a path exists as long as you can travel from one node to the other via wires.
So:
Linked are:
A to F.
C to F.
Unlinked are:
A to B
B to D
C to E
Only (4) satisfies all.
(1) fails because A is not linked at all.
(2) fails because B and D are linked (through C but that doesn't matter).
(3) fails because C and E are linked.
So all violate one or more of the conditions.
The only one that doesn't violate any is (4), and that's the answer.
