Kurty Supercharged October 7, 2013 Share October 7, 2013 ok, just to update and clarify. i change to TS tire valve protector, whole thing is metal type, for only rm10... i did it at save n safe tyre shop, somewhere near southern city if you frequent jb. looks cool, just to match my newly rim ↡ Advertisement Link to post Share on other sites More sharing options...
TVT Supercharged October 7, 2013 Author Share October 7, 2013 Just go back to the tire shop u went last time n ask them to give u some new ones. The cap is meant to protect the valve from water n dirt. Without it yr valve cud spoil earlier. The tire shop is in JB's Johor Jaya. The problem is I don't go that area often (even if I am in JB)....and recently I don't go into JB cos nothing to go in for. So I tot if its not important to have them, then I'll just wait for next chance to go there. If important, then I just buy from a local accessory shop. Ya, I think the cap is important. Not only to protect from water and dirt, but also to prevent any air leakage. If I just walk in n ask to change to the metal valve type, I doubt got RM10ea. Unless ty use a cheepo type which not lasting. Actually what is the difference between the metal valve type and the (usual) rubber valve type? ok, just to update and clarify. i change to TS tire valve protector, whole thing is metal type, for only rm10... i did it at save n safe tyre shop, somewhere near southern city if you frequent jb. looks cool, just to match my newly rim RM10 per piece or for a set of 4 ? Is it a one size-fits-all-valve type of protector ? Link to post Share on other sites More sharing options...
Wallaw819 4th Gear October 7, 2013 Share October 7, 2013 But u also buy tires from them, right? If I just walk in n ask to change to the metal valve type, I doubt got RM10ea. Unless ty use a cheepo type which not lasting. Come to think of it I didn't bought any tires from them. My tires was a little flat and went to the mto see if got anything stuck to my tire. The guy check and discovered the rubber cracked at the joint so slowly leaking air. So the guy say must change valve and offer me the chrome steel type @ RM10 ea. Since cheap said ok and till now the valve still ok (already on another set of tires). Maybe I was lucky. Link to post Share on other sites More sharing options...
Kurty Supercharged October 7, 2013 Share October 7, 2013 RM10 per piece or for a set of 4 ? Is it a one size-fits-all-valve type of protector ? RM10 for 1 piece.. yeah, universal size. but my design is slightly different from yours.. i didn't take a picture.. but more modern only.. Link to post Share on other sites More sharing options...
Pisces69 6th Gear October 7, 2013 Share October 7, 2013 Come to think of it I didn't bought any tires from them. My tires was a little flat and went to the mto see if got anything stuck to my tire. The guy check and discovered the rubber cracked at the joint so slowly leaking air. So the guy say must change valve and offer me the chrome steel type @ RM10 ea. Since cheap said ok and till now the valve still ok (already on another set of tires). Maybe I was lucky. So to change to the metal valve, ty must remove the tire then can install the new valve, right? All that for only RM10 is damm cheap. Let me try. I go n ask to change the metal valve n see how much ty quote me. ↡ Advertisement Link to post Share on other sites More sharing options...
Valve stem washer?
Valve stem washer?
Door Protector Stripes, an important exterior feature against dings?
Do I need to change tire ?
Tire patching types and prices
Spare tire. do u remove or leave in boot?
Continental's New Sustainable Tire Concept Revealed At Munich
