Gdspd08 2nd Gear August 4, 2014 Share August 4, 2014 Hi, I just upgrade to DVBT-2 receiver in my car. Reception is so far much better than my previous DVBT receiver. The antenna is currently on my Vios internal front bumper grille which is entire conceal. The wire fo the antenna actual loop pass my headlight whcih cause signal to be entire loss when switching on headlight. This morning I push the antenna wire down and resolve the issue. I may ask my installer to re-route the antenna cable and put on cable protect for enhancement. All I can say the reception and sound quality is really no horse run. ↡ Advertisement Link to post Share on other sites More sharing options...
AhKit11 Neutral Newbie August 8, 2014 Share August 8, 2014 Hi. Where did U install it and what's the damage? Link to post Share on other sites More sharing options...
Kk13 2nd Gear August 8, 2014 Share August 8, 2014 Yup pls share Link to post Share on other sites More sharing options...
Gdspd08 2nd Gear August 8, 2014 Author Share August 8, 2014 (edited) I install at Xtremez at Ubi Industrial. I do not know whether they still have stock anot. By the way, forget to inform that this set and my previous DVBT receiver both can do recording via thumb drive. Look for Ah Sheng for price. Address : 53 Ubi Avenue 1 #01-06 Paya Ubi Industrial Park S(408934) (map) Phone : 68416882 http://www.sgcarmart.com/directory/merchant.php?MID=14112 Review quite high. Edited August 8, 2014 by Gdspd08 Link to post Share on other sites More sharing options...
alphard96 6th Gear August 9, 2014 Share August 9, 2014 In ideal location with strong signal, are u able to watch more channels, or still only 3 (Ch5, Ch8, CNA)? Wondering whether need to upgrade to enable to watch all the mediacorp digital channels... Link to post Share on other sites More sharing options...
Kitz79 Neutral Newbie August 9, 2014 Share August 9, 2014 I install at Xtremez at Ubi Industrial. I do not know whether they still have stock anot. By the way, forget to inform that this set and my previous DVBT receiver both can do recording via thumb drive. Look for Ah Sheng for price. Address : 53 Ubi Avenue 1 #01-06 Paya Ubi Industrial Park S(408934) (map) Phone : 68416882 http://www.sgcarmart.com/directory/merchant.php?MID=14112 Review quite high. Can share the price you install? Link to post Share on other sites More sharing options...
Gdspd08 2nd Gear August 9, 2014 Author Share August 9, 2014 (edited) In ideal location with strong signal, are u able to watch more channels, or still only 3 (Ch5, Ch8, CNA)? Wondering whether need to upgrade to enable to watch all the mediacorp digital channels... I can watch the following channel1. Channel 8 HD 2. Channel 5 HD 3. Channel U 4. OKTO 5. VAS 6. Suria 7. Test (duno what channel, keep showing animal but the clearest channel) 8. Can't remember can see CNA anot. I go check. All channel will not lag or suddenly twitch, unless go underground. I tested open air, so far really signal freaking strong. My area, Bukit Purmei car park which usually cannot receive DVBT channel, now can see all DVBT-2 channel. I have also tested the signal using my AC Ryan Playon Live with TV booster antenna facing the car park, cannot receive any DVBT-2 unless it is in my living room. I expect my car DVBT-2 cannot receive as it is also at the car park. Strange, can receive. Maybe my booster antenna is not so good. Edited August 9, 2014 by Gdspd08 1 Link to post Share on other sites More sharing options...
Sigcomms Clutched August 10, 2014 Share August 10, 2014 I can watch the following channel 1. Channel 8 HD 2. Channel 5 HD 3. Channel U 4. OKTO 5. VAS 6. Suria 7. Test (duno what channel, keep showing animal but the clearest channel) 8. Can't remember can see CNA anot. I go check. All channel will not lag or suddenly twitch, unless go underground. I tested open air, so far really signal freaking strong. My area, Bukit Purmei car park which usually cannot receive DVBT channel, now can see all DVBT-2 channel. I have also tested the signal using my AC Ryan Playon Live with TV booster antenna facing the car park, cannot receive any DVBT-2 unless it is in my living room. I expect my car DVBT-2 cannot receive as it is also at the car park. Strange, can receive. Maybe my booster antenna is not so good. Hi Bro, I also using the ac ryan playon live but unable to receive any signal using the antenna that comes with the set. I search around my house, found an old 300 ohms FM antenna and a 300-75 ohms matching unit. Guess what? It works perfectly. Link to post Share on other sites More sharing options...
Gdspd08 2nd Gear August 12, 2014 Author Share August 12, 2014 (edited) Hi Bro, I also using the ac ryan playon live but unable to receive any signal using the antenna that comes with the set. I search around my house, found an old 300 ohms FM antenna and a 300-75 ohms matching unit. Guess what? It works perfectly. You should get the booster antenna during the fair. That antenna work well. The one that come with it cannot work well unless you are at a very strong signal environment. Edited August 12, 2014 by Gdspd08 ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Corolla Cross
Toyota Land Cruiser Mini
Toyota bZ4X (2026) Part 2
2022 Toyota bZ4X
2022 Toyota bZ4X
