Magfocus 5th Gear March 10, 2017 Share March 10, 2017 U mean the current Focus 1.0 facelift is a dual clutch? Its not. Its a torque converter 6sp auto ↡ Advertisement Link to post Share on other sites More sharing options...
Rgb3117 1st Gear March 13, 2017 Share March 13, 2017 (edited) Its not. Its a torque converter 6sp auto I thought the 6 speed SelectShift Automatic is a dual clutch? It's the same as the PowerShift except that it has the SelectShift function? At least that's what I read from the internet. http://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?bookCode=O21824&languageCode=en&marketCode=US&viewTech=IE&chapterTitleSelected=G1518956&subTitleSelected=G1518957&topicHRef=G1532347&div=f SelectShift is a function whereby you can use the + and - to control the gear. But its based on the same dual clutch transmission as the PowerShift. Edited March 13, 2017 by Rgb3117 1 Link to post Share on other sites More sharing options...
7hm Turbocharged March 14, 2017 Share March 14, 2017 I thought the 6 speed SelectShift Automatic is a dual clutch? It's the same as the PowerShift except that it has the SelectShift function? At least that's what I read from the internet. http://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?bookCode=O21824&languageCode=en&marketCode=US&viewTech=IE&chapterTitleSelected=G1518956&subTitleSelected=G1518957&topicHRef=G1532347&div=f SelectShift is a function whereby you can use the + and - to control the gear. But its based on the same dual clutch transmission as the PowerShift. The new drivetrains should be using the 6F35 since the PowerShift was rather poorly received in the long term. If it does not explicitly mention "PowerShift", high chances are it's a torque convertor. But yes, you are correct, SelectShift is supposed to refer to the manual over-ride feature. Link to post Share on other sites More sharing options...
Ipaq4444 1st Gear March 14, 2017 Share March 14, 2017 The new drivetrains should be using the 6F35 since the PowerShift was rather poorly received in the long term. If it does not explicitly mention "PowerShift", high chances are it's a torque convertor. But yes, you are correct, SelectShift is supposed to refer to the manual over-ride feature. i am abit lost here torque convertor. means it is not dual crutch? Link to post Share on other sites More sharing options...
7hm Turbocharged March 14, 2017 Share March 14, 2017 i am abit lost here torque convertor. means it is not dual crutch? torque convertor is one of the more technical terms used for normal automatics. Link to post Share on other sites More sharing options...
Fett 2nd Gear March 15, 2017 Share March 15, 2017 i changed outside. Wait till 10k then i go back regent. like i said, i can get 550km with balance 80km (lights on) so total 630km. (70% hway / 30% city) last week, i got 500km with balance 80km (lights on) so total 580km. (50% hway / 50% city) using Ron95. Did my servicing(5w-20) and im still getting 10km/l, at times its 9.7-9,8. Besides changing rims, what else did u do? If nothing else then can conclude that changing lighter rims reduce fc by 20%?(im getting 420km total with (50% hway / 50% city) 1 Link to post Share on other sites More sharing options...
Eyke Supercharged March 15, 2017 Share March 15, 2017 Did my servicing(5w-20) and im still getting 10km/l, at times its 9.7-9,8. Besides changing rims, what else did u do? If nothing else then can conclude that changing lighter rims reduce fc by 20%?(im getting 420km total with (50% hway / 50% city) reduce weight, change driving style Link to post Share on other sites More sharing options...
7hm Turbocharged March 15, 2017 Share March 15, 2017 SGCM say that even with some stop start and their semi-spirited driving they managed 13km/l... somehow... Link to post Share on other sites More sharing options...
Fett 2nd Gear March 15, 2017 Share March 15, 2017 reduce weight, change driving style Thats more like a general tip for improving FC, i think wat we're more curious about is why the fc figures stated in brochure is wayyy far off from what we actually get. Of course nobody should ever trust brochure specs, everyone knows its never the same, but im getting less than half of wats stated, which anyone would find ridiculous. Link to post Share on other sites More sharing options...
Eyke Supercharged March 15, 2017 Share March 15, 2017 Thats more like a general tip for improving FC, i think wat we're more curious about is why the fc figures stated in brochure is wayyy far off from what we actually get. Of course nobody should ever trust brochure specs, everyone knows its never the same, but im getting less than half of wats stated, which anyone would find ridiculous. unfortunately, nothing much u can do about it. u can throw it back to the dealer and complain about it, but they will say probably say: it's like dat one. unless u can find something that is specifically wrong that is causing the bad FC, else u can only follow "general tip for improving FC". Link to post Share on other sites More sharing options...
Fett 2nd Gear March 15, 2017 Share March 15, 2017 unfortunately, nothing much u can do about it. u can throw it back to the dealer and complain about it, but they will say probably say: it's like dat one. unless u can find something that is specifically wrong that is causing the bad FC, else u can only follow "general tip for improving FC". Was initially referring to how our bro @davo23 got 630km Link to post Share on other sites More sharing options...
Eyke Supercharged March 15, 2017 Share March 15, 2017 Was initially referring to how our bro @davo23 got 630km get him to swap cars with you then compare. Link to post Share on other sites More sharing options...
Fett 2nd Gear March 15, 2017 Share March 15, 2017 get him to swap cars with you then compare. Link to post Share on other sites More sharing options...
ccc888 4th Gear March 15, 2017 Share March 15, 2017 Its confirmed that 2017 focus using normal 6AT. Very nice car 1 Link to post Share on other sites More sharing options...
sgpeasant Neutral Newbie March 24, 2017 Share March 24, 2017 Its confirmed that 2017 focus using normal 6AT. Very nice car Any idea when will the 2017 focus be selling in singapore? Hoping to get one with sync 3. Link to post Share on other sites More sharing options...
Shull Turbocharged April 14, 2017 Share April 14, 2017 Hi guys, I'm eyeing a 2nd hand 2012 Focus Titanium. Would like to find out on the following: FC (my driving pattern is 70 Highway : 30 City) : Gearbox reliability : Read that the PowerShift has it's fair share of typical DSG problem Link to post Share on other sites More sharing options...
7hm Turbocharged April 14, 2017 Share April 14, 2017 Any idea when will the 2017 focus be selling in singapore? Hoping to get one with sync 3. "2017" one already here if you mean the 2016 Mk.3 model with SYNC 3, but if you mean the next generation one there's not much info out there, haven't been released anywhere, only spotted in camouflage Link to post Share on other sites More sharing options...
sgpeasant Neutral Newbie April 17, 2017 Share April 17, 2017 "2017" one already here if you mean the 2016 Mk.3 model with SYNC 3, but if you mean the next generation one there's not much info out there, haven't been released anywhere, only spotted in camouflageThe current Focus sold in RM as 2016 models do not have sync 3. ↡ Advertisement Link to post Share on other sites More sharing options...
Nio Firefly - coming to Singapore in 2026
Ford invents retractable exhausts
2022 Tesla Cybertruck and the Ford Executive Challenge
New MG3 hatchback
New MG3 hatchback
Let's talk about American pickup trucks.
2017 Hyundai i30
2017 Hyundai i30
Comparing Opel Astra 1.6 Twinport and Ford Focus 1.6 H/B
