Melbs 1st Gear August 11, 2015 Share August 11, 2015 Thanks for your advice. Just look up my receipts. I have 2 x 4 channels amp powering the front and rears. Have a MTX 3 way crossover for the front but no processor. Do drop me a private message if you have a shop to recommend who can install and tune the system. hmmm, 2 amp with 4 channels each? your installer must have bridged your channels then to provide more power to your speakers. since you have 2 4 channel amps already, that's 8 channels you can use. you can just buy a processor, run the front 3 way full active, so you're using 6 channels out of your 8. the remaining two to power your rear speakers using passive crossover. your sub and sub amp stays the same. or use 2 channels for your tweeters, 2 channels for your mid range, and bridge the remaining 4 channels for your mid bass. just power the rear speaker using the internal amp of your head unit. sub and sub amp stays the same. i personally would go for this setup ↡ Advertisement Link to post Share on other sites More sharing options...
Jl255 Clutched August 11, 2015 Share August 11, 2015 how much are they selling this unit? my PI quoting me an additional $1300 to install this unit with ipod and android adapter. bumping my previous question :P Link to post Share on other sites More sharing options...
Augus Neutral Newbie August 12, 2015 Share August 12, 2015 hmmm, 2 amp with 4 channels each? your installer must have bridged your channels then to provide more power to your speakers. since you have 2 4 channel amps already, that's 8 channels you can use. you can just buy a processor, run the front 3 way full active, so you're using 6 channels out of your 8. the remaining two to power your rear speakers using passive crossover. your sub and sub amp stays the same. or use 2 channels for your tweeters, 2 channels for your mid range, and bridge the remaining 4 channels for your mid bass. just power the rear speaker using the internal amp of your head unit. sub and sub amp stays the same. i personally would go for this setup Thanks for the advice, Melbs. Link to post Share on other sites More sharing options...
Alextoh76 Clutched August 18, 2015 Share August 18, 2015 Hi guys, Anyone manage to use their steering wheel buttons to activate the mic to give voice commands rather than pressing the head unit before giving voice commands? Link to post Share on other sites More sharing options...
Melbs 1st Gear August 19, 2015 Share August 19, 2015 Hi guys, Anyone manage to use their steering wheel buttons to activate the mic to give voice commands rather than pressing the head unit before giving voice commands? what car? not all cars are compatible Link to post Share on other sites More sharing options...
Alextoh76 Clutched August 19, 2015 Share August 19, 2015 Hi, Understand. Just wanna check if any of u is able to activate auto andriod or car play from steering wheel control rather than having to push the mic button on the head unit user interface. Anyone? Link to post Share on other sites More sharing options...
Dieselord 2nd Gear August 22, 2015 Share August 22, 2015 Hi.. OT abit... I considering between pioneer 8750 and alpine w502+h701 processor Mine is juz a 2-way passive system.. Which is recommend to get more quality sound? Will be 1st time using these units as I currently using kenwood.. TIA Link to post Share on other sites More sharing options...
shuttlecock 1st Gear August 24, 2015 Share August 24, 2015 I wanna to install this 8750 to my new hyundai tucson. Any advise where can i change the whole panel in order fit the 8750. Wish to maintain the controls from the steering wheel too as used to adjust volume from there while driving. Regards Link to post Share on other sites More sharing options...
Jesmond Neutral Newbie August 25, 2015 Share August 25, 2015 Hi, I am using 8750 now, bought on May. I have been facing the issues below since day 1. While using Apple Car Play, lagging or screen hang if changing mode, such as from USB 1 to USB 2. It will not back to normal and have to restart the system. (have to restart the car.) when playing the song from my iphone, and reversing the car. After reversed the car, gear switched to D or N, the playing stopped or screen hang. No back camera view showed when reversing. (screen blank) Others: System will not start immediately when I started my car. It took a few minutes to start after that. All these are intermittent issues and not happen everytime, but recently seems like become more frequent. I tried to upgrade the firmware to the latest version from Pioneer website, the problem still unsolved. Anyone facing the same problem as me? By the way, anyone know how to 'off' the system (not off the display) without off my car? Thanks. Link to post Share on other sites More sharing options...
Gaolow 4th Gear August 25, 2015 Share August 25, 2015 when playing the song from my iphone, and reversing the car. After reversed the car, gear switched to D or N, the playing stopped or screen hang. No back camera view showed when reversing. (screen blank) Others: Only have the above issue when using the Car Play with the Spotify. Link to post Share on other sites More sharing options...
Melbs 1st Gear August 26, 2015 Share August 26, 2015 Hi, Understand. Just wanna check if any of u is able to activate auto andriod or car play from steering wheel control rather than having to push the mic button on the head unit user interface. Anyone? the answer depends on what your car is best to consult your installer I wanna to install this 8750 to my new hyundai tucson. Any advise where can i change the whole panel in order fit the 8750. Wish to maintain the controls from the steering wheel too as used to adjust volume from there while driving. Regards best to go to your local car audio installer and ask them if they have the dash kits for your suv Hi, I am using 8750 now, bought on May. I have been facing the issues below since day 1. While using Apple Car Play, lagging or screen hang if changing mode, such as from USB 1 to USB 2. It will not back to normal and have to restart the system. (have to restart the car.) when playing the song from my iphone, and reversing the car. After reversed the car, gear switched to D or N, the playing stopped or screen hang. No back camera view showed when reversing. (screen blank) Others: System will not start immediately when I started my car. It took a few minutes to start after that. All these are intermittent issues and not happen everytime, but recently seems like become more frequent. I tried to upgrade the firmware to the latest version from Pioneer website, the problem still unsolved. Anyone facing the same problem as me? By the way, anyone know how to 'off' the system (not off the display) without off my car? Thanks. sadly no i don't experience your issues. go back to your installer and ask if you can replace the unit. if they have a demo unit, try that if you experience the same thing. for your back camera view when reversing either camera is not installed properly or faulty or your settings is not properly configured. Link to post Share on other sites More sharing options...
kiong77 Neutral Newbie September 1, 2015 Share September 1, 2015 How long is USB cable that come with 8750? Can take photos of the USB cable? Link to post Share on other sites More sharing options...
BrianChoong Neutral Newbie September 2, 2015 Share September 2, 2015 I just install 8750BT (previously 5650) These two days I am testing the HU with my Note 2 I am trying the AppRadio I am happy with it as it can launch Waze and I control and type on the HU screen But, one thing I am not happy which is Yes, I need to connect my phone with the HDMI, But, this port, not able to charge faster than the power of my phone consume... My phone only launch the AppRadio and Waze... Anyone have this problem and what is your solution? Link to post Share on other sites More sharing options...
rovwei 2nd Gear September 4, 2015 Share September 4, 2015 I just install 8750BT (previously 5650) These two days I am testing the HU with my Note 2 I am trying the AppRadio I am happy with it as it can launch Waze and I control and type on the HU screen But, one thing I am not happy which is Yes, I need to connect my phone with the HDMI, But, this port, not able to charge faster than the power of my phone consume... My phone only launch the AppRadio and Waze... Anyone have this problem and what is your solution? Did u connect USB port for charging, apart from the HDMI? I tried that it is ok,though i tried a while only.. should be ok. Link to post Share on other sites More sharing options...
BrianChoong Neutral Newbie September 4, 2015 Share September 4, 2015 I connected my phone with the micro USB and turn on the bluetooth I can run AppRadio mode very well If I did not run AppRadio but just plug in the micro USB cable, yes, it will charge my phone When I turn on the AppRadio, on my phone screen, it show charging as well Just that...e.g. my phone battery is 90% I turn on AppRadio mode and Waze After I drive for sometime, may be about 10km++, the battery level will drop to 89% or 88% I read the manual...it said if such case happen, please turn off some services or apps on my phone But...my phone at that moment only have appradio and waze running... May be...it not build for GPS that using for longer time It seem like the power that supply from this HU is a bit low. Link to post Share on other sites More sharing options...
Bonjoey 1st Gear September 5, 2015 Share September 5, 2015 (edited) Sorry I am a bit confused... You connected the microusb to your Note 2. So one end is connected to your Note 2. The other end I supposed is connected to the HDMI port? In this case, maybe the HDMI port is not so efficient in charging? The part I wanna ask is, the mirroring is made possible due to the HDMI or the Bluetooth? Lastly, when there is mirroring, u can control the stuffs on ur phone by just using the HU screen? Asking as I will be a 8750 user soon and still considering whether to buy a HDMI/USB panel or simply buy a wireless module to connect my Note 4 wirelessly for mirroring. Thanks. :) Did u connect USB port for charging, apart from the HDMI? I tried that it is ok,though i tried a while only.. should be ok. Erm...if the phone only has one microusb port, then after connecting the HDMI, no space for connect USB cable? I am looking from perspective of Note 4. Edited September 5, 2015 by Bonjoey Link to post Share on other sites More sharing options...
rovwei 2nd Gear September 6, 2015 Share September 6, 2015 Sorry I am a bit confused... You connected the microusb to your Note 2. So one end is connected to your Note 2. The other end I supposed is connected to the HDMI port? In this case, maybe the HDMI port is not so efficient in charging? The part I wanna ask is, the mirroring is made possible due to the HDMI or the Bluetooth? Lastly, when there is mirroring, u can control the stuffs on ur phone by just using the HU screen? Asking as I will be a 8750 user soon and still considering whether to buy a HDMI/USB panel or simply buy a wireless module to connect my Note 4 wirelessly for mirroring. Thanks. :) Erm...if the phone only has one microusb port, then after connecting the HDMI, no space for connect USB cable? I am looking from perspective of Note 4. U need to buy HDMI to phone adaptor, you can connect Usb for charging.. my agent said can only support up to note3. Not sure true or not.. maybe u can try.. Link to post Share on other sites More sharing options...
BrianChoong Neutral Newbie September 7, 2015 Share September 7, 2015 Let me explain what I know 8750bt support iphone and android phone If you plan to show some of the apps or gps apps on the HU, there is few ways Iphone (Just connect the iphone cable with the USB port 1 will do) Got 2 options 1. Install AppRadio, but this see to have compatible issue with IOS 8, you can just google then u can see a lot information 2. Carplay mode, this is new, but limited function, I test this already, it work, but, really, lack of function. Android I install the HDMI cable module and link to the USB 2 at the HU, this is not include in the HU package, but, I think for android user, must install it. After in stall, it got a micro USB head for you to plug in to your android phone. 1. Mirror link mode - Connect the micro USB (the HDMI module) with your phone, at the setting, set to use android phone, and then select display with mode HDMI, now, you can see your phone screen appear on the HU screen. In this mode, what you see on your phone, is actually what you see on the HU. You cannot control your phone via the HU screen. If you put your phone as portrait mode, the HU will show the screen as portrait mode 2. AppRadio mode - i. Install AppRadio apps from Play store ii. Launch AppRadio apps and then in the apps, install those apps that show in AppRadio, e.g. Waza iii. Connect the micro USB (the HDMI module) with your phone, at the setting, set to use android phone, and then select HDMI. iv. Turn on your bluetooth and connect with your phone v. At your HU, press the mode button, you should able to see the HU with different user interface which is the AppRadio interface, you can launch the apps as Waze there. (If you do not see any new interface, may be you need to launch the AppRadio apps on your phone first) Regardless how you put your phone, landscape or portrait, the AppRadio able to show the apps with full screen with landscape mode. 3. Android Auto - This mode only support with Android version 5 (Lollipop), I am using Note 2, which is android 4.4 (kitkat), so I cant test this function, not sure need to plug in the cable or not... Note 4 I think receive the update to Android 5 already, you can try this mode. ↡ Advertisement Link to post Share on other sites More sharing options...
DVD Player cum Roof/head rest monitor
VW Will Spend Billions of Its EV Development Budget on Gas Engines
Xtremez Audio - Your Choice for Audio Installation & Upgrade
Car Show 2024
Car Show 2024
[Seek experts' views] Pioneer Z9250BT vs stock HU
The Doctor , Freelance ICE Tuner
