Emi Neutral Newbie June 25, 2016 Share June 25, 2016 Huh? This is still cheaper compared to the time when COE was $70K No. My XT C0E was $75k. I paid $135k for it. ↡ Advertisement Link to post Share on other sites More sharing options...
BenTong Turbocharged June 25, 2016 Share June 25, 2016 No. My XT C0E was $75k. I paid $135k for it. Then you one of the lucky ones la Link to post Share on other sites More sharing options...
Rachdanom 2nd Gear June 25, 2016 Share June 25, 2016 No. My XT C0E was $75k. I paid $135k for it. Just a guess, reading about supply issues in the US....could be production struggling so they making the most out of each unit now especially since local demand seems to be picking up as more are seen on the road. Link to post Share on other sites More sharing options...
Tohto Hypersonic June 25, 2016 Share June 25, 2016 This middle one in the triple gauge. Is it measuring the coolant temp or engine oil temp? Or something else? IMG_20160625_1100031.jpg Engine oil temp. That is the symbol used for engine oil. Link to post Share on other sites More sharing options...
JuzFXT 2nd Gear June 25, 2016 Share June 25, 2016 (edited) No. My XT C0E was $75k. I paid $135k for it. Wow ...it will mean if $50k should be $110k Edited June 25, 2016 by JuzFXT 1 Link to post Share on other sites More sharing options...
Jthl 2nd Gear June 25, 2016 Share June 25, 2016 Engine oil temp. That is the symbol used for engine oil.Actually why do we need to monitor engine oil? I thought knowing the coolant temp will be better. 1 Link to post Share on other sites More sharing options...
WML888 2nd Gear June 25, 2016 Share June 25, 2016 Or maybe sun too powerful make cabin feel slightly warmer??That is why I upgraded solar films (max heat rejection for moonroof),added groovy shades also.But, my final verdict is manage the drive to enjoy the comfort. This middle one in the triple gauge. Is it measuring the coolant temp or engine oil temp? Or something else? IMG_20160625_1100031.jpg That I believe is oil temperature. 1 Link to post Share on other sites More sharing options...
Icecube187 2nd Gear June 25, 2016 Share June 25, 2016 Seems like is normal after i search online. Anyone experience the same?Yes its normal. FNA driver here. It shud be the electrical relays that pick up and drop off when deenergized. 1 Link to post Share on other sites More sharing options...
Slowcat 1st Gear June 25, 2016 Share June 25, 2016 My XT was parked last Sunday and not used for 6 days. Unable to start. Low batt and I had to use the physical key to open. Jump started and for the rest of the day ok. My SE says it's normal to hv low batt after 6 days. I think it's appalling. 1 Link to post Share on other sites More sharing options...
Slazen 1st Gear June 25, 2016 Share June 25, 2016 My XT was parked last Sunday and not used for 6 days. Unable to start. Low batt and I had to use the physical key to open. Jump started and for the rest of the day ok. My SE says it's normal to hv low batt after 6 days. I think it's appalling. 6 days shouldn't discharge the battery unless it's a design fault or old battery. But nevertheless it's appalling 1 Link to post Share on other sites More sharing options...
Slowcat 1st Gear June 25, 2016 Share June 25, 2016 6 days shouldn't discharge the battery unless it's a design fault or old battery. But nevertheless it's appallingMy car has no dash cam ... basically bone stock. I reckon old batt or there is some parasitic draw. The stock batt is 48 Ah ... not very high. I've seen BMW batt that is 100 Ah. Reckon I'll Google see if it's common or I hv a lemon. Link to post Share on other sites More sharing options...
Icarus 1st Gear June 26, 2016 Share June 26, 2016 My car has no dash cam ... basically bone stock. I reckon old batt or there is some parasitic draw. The stock batt is 48 Ah ... not very high. I've seen BMW batt that is 100 Ah. Reckon I'll Google see if it's common or I hv a lemon. This is worrying. Something must be drawing power from the battery when parked. Maybe the keyless entry? My previous cars (bare bone without keyless) were able to start even after my 2-3 work trips. 1 Link to post Share on other sites More sharing options...
BenTong Turbocharged June 26, 2016 Share June 26, 2016 Just a guess, reading about supply issues in the US....could be production struggling so they making the most out of each unit now especially since local demand seems to be picking up as more are seen on the road.This thread is the main cause why the prices went up. Look at the number of pages!!! Compared that with the OB thread.. OB used to be $12-15k more expensive than an FXT. See la see la.. Talk some more la... This is worrying. Something must be drawing power from the battery when parked. Maybe the keyless entry? My previous cars (bare bone without keyless) were able to start even after my 2-3 work trips. Suspect so. Even the showroom unit was out of juice... But then could be all the "molestation".. Link to post Share on other sites More sharing options...
Jerrimie Clutched June 26, 2016 Share June 26, 2016 My XT was parked last Sunday and not used for 6 days. Unable to start. Low batt and I had to use the physical key to open. Jump started and for the rest of the day ok. My SE says it's normal to hv low batt after 6 days. I think it's appalling. mine was parked for 10 days but had no problems starting when i came back. I had front back incar camera which was running throughtout the 10 days leh. 1 Link to post Share on other sites More sharing options...
redstuff 4th Gear June 26, 2016 Share June 26, 2016 I just scrapped my 10-yr old FNA. Have frequently went on holidays of up to 2 weeks 2-3 times a year and just left the car in the car park. Never once had problems starting the car after the holidays. Link to post Share on other sites More sharing options...
Zommy3 Neutral Newbie June 26, 2016 Share June 26, 2016 That is why I upgraded solar films (max heat rejection for moonroof),added groovy shades also. But, my final verdict is manage the drive to enjoy the comfort. That I believe is oil temperature. Hi, hear a lot Subaru owner mentioned groovy shades. Can show some photos? Thx Link to post Share on other sites More sharing options...
Cboonh 2nd Gear June 26, 2016 Share June 26, 2016 This is worrying. Something must be drawing power from the battery when parked. Maybe the keyless entry? My previous cars (bare bone without keyless) were able to start even after my 2-3 work trips. Iirc, the manual or some instructional video did mention disabling the keyless entry if you'll be away for awhile. The keyless sensor is active... Will always be scanning for keys. Having said that it's low power consumption also.. Personally, I came back from a 1 week trip, no prob, car still can start. Link to post Share on other sites More sharing options...
WML888 2nd Gear June 26, 2016 Share June 26, 2016 Hi, hear a lot Subaru owner mentioned groovy shades. Can show some photos? ThxDrop by the dealer's show room to see the real things. ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Subaru Solterra BEV
Advice on exhaust.
Advice on exhaust.
New Subaru XV
New Subaru XV
