Bhaal Neutral Newbie July 10, 2003 Share July 10, 2003 hi Do we ever need to replace the coolant or just top up everytime it drop will do? ↡ Advertisement Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie July 10, 2003 Share July 10, 2003 flushing should be done around once a year..... Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie July 11, 2003 Share July 11, 2003 Sicne we don't have winters in Sillypore, flushing once every 2 years is suffice. If you notice drop in coolant levels often that means there's not enough coolant and too much water in the system or worst case a leak somewhere. Recommended dilution ratio is 50/50 but I personally use 30/70 (coolant/water) for year round summer as water is the cooling component, coolant just raises the boiling temp. Link to post Share on other sites More sharing options...
Bhaal Neutral Newbie July 11, 2003 Author Share July 11, 2003 thanks for the reply. is there any difference between brands/types of coolants. my car is currently using a green colored one but i'm not sure what type. Link to post Share on other sites More sharing options...
Jasper Neutral Newbie July 12, 2003 Share July 12, 2003 i am not sure got any difference or not. but i just bought a bottle of ... Holts radiator flush. drain out old coolant, poke in water hose, just force water into the radiator, clean inside.... fill up with water & this flush, drive for 30-40 miles. drain out and top up with coolant. coolant i bought from carrefour, brand is "Total". A french brand. Link to post Share on other sites More sharing options...
Jacko Neutral Newbie July 12, 2003 Share July 12, 2003 Heard from someone that Merc coolant is better those out there in the market. I'm using Redline Water Wetter, about 370ml per bottle and top up ratio to 30/70 same like Turbobrick. One more brand is Engine Ice which is premix but quite $$$. Typically need 3 to 4 bottles to fill up the whole radiator(balance for spare) Link to post Share on other sites More sharing options...
Bhaal Neutral Newbie July 12, 2003 Author Share July 12, 2003 if i don't wish to flush out the existing one & dun noe what brand it is, can i just buy any brand & mix it in to top up? Link to post Share on other sites More sharing options...
Saaber Neutral Newbie July 12, 2003 Share July 12, 2003 no...don't mix....if the level is low, just top up with water.... Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie July 12, 2003 Share July 12, 2003 Engine Ice goes for >$30 a bottle. But no lah, not 3 to 4 bottles unless Ur car super big radiator lah.. I believe about 3 is the max. So far mine (2.0 Stream) and my fren (2.4 JDM Accord) both use around 2.5 bottles. Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie July 12, 2003 Share July 12, 2003 But must make sure not using some premix thing though - else if just top up with water would have wasted the $$$ that went into the premix one. Link to post Share on other sites More sharing options...
Saaber Neutral Newbie July 12, 2003 Share July 12, 2003 of course lah... Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie July 13, 2003 Share July 13, 2003 If you car has green coolant currently, you could top up with plain water like Saaber mentioned and monitor whether does the level drop. If all ok then leave it, else top up with 50/50 (since not complete flush) water and coolant mixture. For the standard green coolant, I recommend using CASTROL coolant which can be found at Autobacs or parts shop along Deskar Rd If you're flushing do change to Merc coolant, the BEST! Supposed to have water pump lubrication in it. Link to post Share on other sites More sharing options...
Cyrix Neutral Newbie August 21, 2004 Share August 21, 2004 bro...u say collant lower...just top up wif water....tap water can??? or must be distilled water like the battery water? Link to post Share on other sites More sharing options...
Luckcent 4th Gear August 21, 2004 Share August 21, 2004 Tap water will suffice. Dont over fill it. Just fill it to the mark. Link to post Share on other sites More sharing options...
Cyrix Neutral Newbie August 21, 2004 Share August 21, 2004 thks a lot bro....was just wondering when I saw this thread... Link to post Share on other sites More sharing options...
Luckcent 4th Gear August 21, 2004 Share August 21, 2004 No problem, but if you need to fill up the battery water, you need to use distilled ones. Link to post Share on other sites More sharing options...
Hoppe Clutched August 23, 2004 Share August 23, 2004 one qn, for older cars (with slightly rusty radiator), better to : 1) continue to use tap water or 2) use market coolers? Link to post Share on other sites More sharing options...
Luckcent 4th Gear August 23, 2004 Share August 23, 2004 You can always flush your radiator to clear the rust before putting in new coolant. ↡ Advertisement Link to post Share on other sites More sharing options...
Coolant question
Coolant question
Coolant level going down
Math Question
Math Question
What is the purpose of coolant
Question on Transfer of Car Ownership
Question for Car Servicing
