Kangadrool Supersonic July 2, 2020 Share July 2, 2020 On 6/26/2020 at 10:44 AM, Kangadrool said: I will try to sun it this weekend to see how first. doesn't help... So, got it done by windows surgeon today. Performed a bypass to rectify the broken wire loom connector. ↡ Advertisement Link to post Share on other sites More sharing options...
Vanstud Neutral Newbie August 28, 2023 Share August 28, 2023 Hi guys need your guidance here. My swing type auto gate moves super slow and now refuses to open or close fully. I’ve changed the transformer and adjusted the micro switches to change speed and motor delay without success. The motor and mechanical parts underneath seem ok. question is what could be the root cause and should I look to change the circuit board or others? Circuit Board is Ranger SWG800R many thanks in advance. Link to post Share on other sites More sharing options...
Volvobrick Hypersonic August 28, 2023 Share August 28, 2023 On 8/28/2023 at 2:30 PM, Vanstud said: Hi guys need your guidance here. My swing type auto gate moves super slow and now refuses to open or close fully. I’ve changed the transformer and adjusted the micro switches to change speed and motor delay without success. The motor and mechanical parts underneath seem ok. question is what could be the root cause and should I look to change the circuit board or others? Circuit Board is Ranger SWG800R many thanks in advance. Any loose wires to the actuators? Try turning yo full speed and slowest to see if there is any difference. If no diff maybe really toasted liao! Link to post Share on other sites More sharing options...
Vanstud Neutral Newbie August 28, 2023 Share August 28, 2023 Thanks for the guidance. Checked all the wires and connections. Also turned the micro switchs to max…circuit board fried ? Link to post Share on other sites More sharing options...
BanCoe Hypersonic August 29, 2023 Share August 29, 2023 I wonder what kind of gates are used in those B&W houses , or maybe they got sentries 🤣🤣 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic August 29, 2023 Share August 29, 2023 On 8/29/2023 at 8:53 AM, BanCoe said: I wonder what kind of gates are used in those B&W houses , or maybe they got sentries 🤣🤣 Only Ridout B and W got lah! 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic August 29, 2023 Share August 29, 2023 On 8/28/2023 at 2:30 PM, Vanstud said: Hi guys need your guidance here. My swing type auto gate moves super slow and now refuses to open or close fully. I’ve changed the transformer and adjusted the micro switches to change speed and motor delay without success. The motor and mechanical parts underneath seem ok. question is what could be the root cause and should I look to change the circuit board or others? Circuit Board is Ranger SWG800R many thanks in advance. Check the hinges and alignment. Make sure the hinges are lub, the hinge bolts arent lose, if some have came lose the alignment will be out and the gate cannot close properly. Link to post Share on other sites More sharing options...
Vanstud Neutral Newbie August 29, 2023 Share August 29, 2023 Thanks mate for the advice. All hinges arms and bolts are secure. Been advised by the agent in Malaysia that the IC board might be fried ↡ Advertisement Link to post Share on other sites More sharing options...
