Gnahp Turbocharged July 31, 2025 Share July 31, 2025 On 7/30/2025 at 9:38 AM, kobayashiGT said: oh.... actually ICE also no need servicing one! no wonder all petrol kiosk got sell 1L pack engine oil! I was joking lah there will be sediments at the bottom of the oil pan that cannot be burnt away can only cleared by draining the old oil ↡ Advertisement Link to post Share on other sites More sharing options...
Scholesy 4th Gear August 1, 2025 Share August 1, 2025 On 7/30/2025 at 1:19 PM, ER-3682 said: I remember last time,a W124 Mercedes Benz Gearbox,never change ATF before,Car driving okay,the 2nd Owner,bought it & went Flushing,Car Gearbox "Slip" when just drive out Workshop...later Gearbox need to Overhaul. actually this "phenomenon" happened to me too 😁 car aircon no problem but seeing 80k and doing major service, opted for aircon flush. after that, the coldness worsened. ac still working but not as cold or strong as previous. 2 Link to post Share on other sites More sharing options...
ER-3682 Supersonic August 1, 2025 Share August 1, 2025 On 8/1/2025 at 8:32 AM, Scholesy said: actually this "phenomenon" happened to me too 😁 car aircon no problem but seeing 80k and doing major service, opted for aircon flush. after that, the coldness worsened. ac still working but not as cold or strong as previous. Still working better than the Cooling Coil puncture...then need to change..so many cases..after Aircon Flushing..Coil gone..because high Pressure cause the Old Coil to burst. 2 Link to post Share on other sites More sharing options...
mersaylee Hypersonic August 1, 2025 Share August 1, 2025 On 7/30/2025 at 6:35 PM, Jamesc said: Are you the one? Singaporean wanted by police for his role behind the headline-grabbing nude games in Penang earlier this month. Superman also took part in that pubic and private event...😁 1 Link to post Share on other sites More sharing options...
Beregond Supersonic August 1, 2025 Share August 1, 2025 On 8/1/2025 at 8:32 AM, Scholesy said: actually this "phenomenon" happened to me too 😁 car aircon no problem but seeing 80k and doing major service, opted for aircon flush. after that, the coldness worsened. ac still working but not as cold or strong as previous. There is only 1 explanation. Either your ws that flush your AC didn't follow the book. They pump too low or too high PSI for your ac. Or they follow according and pump the correct PSI. which mean if u have top up AC gas before elsewhere. Before they flush the AC. Your AC system is already running on higher PSI then standard recommended, which is why u feel super freezing cold. But now its just cold 2 Link to post Share on other sites More sharing options...
Scholesy 4th Gear August 1, 2025 Share August 1, 2025 On 8/1/2025 at 9:29 AM, Beregond said: There is only 1 explanation. Either your ws that flush your AC didn't follow the book. They pump too low or too high PSI for your ac. Or they follow according and pump the correct PSI. which mean if u have top up AC gas before elsewhere. Before they flush the AC. Your AC system is already running on higher PSI then standard recommended, which is why u feel super freezing cold. But now its just cold more likely didnt follow the book. my car is first hand so ac stock never touched so i assume PSI shd b factory. but these days many ws simply just increase scope of services to get more revenue. not all mec are properly trained or hand over to properly operate an equipm. from a ws friend, he say mec turnover is very high now. so end up on job training mec also no choice have to take else no manpower. big name ws included. 1 Link to post Share on other sites More sharing options...
Repulsive_War_018 Neutral Newbie November 27, 2025 Share November 27, 2025 On 7/28/2025 at 7:40 PM, Gnahp said: I did a quick calculations 😁 if you change the engine oil 3 times in succession, you will reduce the old oil ratio to 9% if you change 6 times in succession, that will bring down the old oil ratio to 0.8% You are a savior!! Your calculation gave us new breathe. Nice. ↡ Advertisement Link to post Share on other sites More sharing options...
China’s Largest Car Service Chain is Quietly Taking Over Malaysia
Volvo Servicing
Volvo Servicing
Lee Sheng Auto - One Stop Auto Repair Centre! From accident repair & claims, spray painting, diagnostics, general repairs to servicing.
