How to smoke rear lights
Throttleb
How would you smoke(darken) your rear light cluster s;lightly , just get a painter to spray lightly on the inside??
DIY Gurus response most appreciated [thumbsup]
read there is some spray from VHT called Darknite but not sure how the finsihed produc will look like.
all i want is to be slightly darker cos its a dark red car with red light cluster..
try this website www.powerkits.com
alternatively, you can go to it's forum. Look for the nickname 'LordGT'. He's the one who brings in the goods. You can seek his help or advise.
forums.delphiforums.com/powerkits/start
If you wanna see how smoked lens should look like, go to www.specr.com.sg, click on the tab "Our Products", check out the photo of the Mazda 6 with the works.
Cheers.
You can't spray the 156's tail-light cluster from the inside, or do a good job in doing so. Remove it and you'll see why! [sly][;)]
>>Spraying is usually done externally, if i'm not wrong.
I think that's the logical way too. But I think the finish will be matt, unless another layer of clear-coat is sprayed over.
Matt finishing isn't a bad idea, actually. I understand Niteshade can be 'removed' if sprayed faintly. A clearcoat over it means it's gonna be permanent
