Jackfoo 1st Gear September 11, 2003 Share September 11, 2003 Goodday people , Need advice from you all, just install an SAFCII on my baby but saw the mechanic is using his experience to fine tune the SAFC by driving round & round in the carpark & made the adjustment. Should i send my baby for a "check up" using Dynameter instead of manually tuning? Please help....SOS Have a nice day ↡ Advertisement Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie September 11, 2003 Share September 11, 2003 IMHO, if you want best results quickly, go for a dyno tuning. That way the adjustments can be made on the air fuel mix and you can get quantified results. Also, it's certainly a whole lot safer to tune like that than on the road or carpark - since they have to rev usually throughout the whole range - meaning the car probably would pick up quite some speed. Link to post Share on other sites More sharing options...
Paladin Neutral Newbie September 11, 2003 Share September 11, 2003 Cool. How much did u pay for your SAFC II including the butt dyno in carpark by the mechanic? Link to post Share on other sites More sharing options...
Jackfoo 1st Gear September 12, 2003 Author Share September 12, 2003 Goodday ModelDriver, Many thanks for advice. Any particular workshop you can recommend me for the Dyno? Any ideas what the pricing look like? rgds.....jack Link to post Share on other sites More sharing options...
Jackfoo 1st Gear September 12, 2003 Author Share September 12, 2003 Paladin, Got it from a friend at a very low price as he need to post out to China to work there for couple of years. Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie September 13, 2003 Share September 13, 2003 I do mine at Autowerke (11 Playfair Road). Understand there are some others available - AMK has one, believe even Ubi has one too. Ultramax also has - but that place ulu is an understatement. Cost should be in the region of $150 plus I think since you didn't buy things from them. Autowerke does my car for less than that because I did my piggy back with them. Link to post Share on other sites More sharing options...
Jackfoo 1st Gear September 13, 2003 Author Share September 13, 2003 Hello modeldriver, Thanks for the info. Will check with Autowerke, Link to post Share on other sites More sharing options...
Assassin Clutched September 13, 2003 Share September 13, 2003 Hi JackFoo, Welcome to MCF ! Do enjoy your stay here and come along for our weekly meetups. More info in the MEETUPS folder. Also check out the RESOURCES folder and the TIPS & TECHNICAL RESOURCES folder for more automotive info. Cheers Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie September 13, 2003 Share September 13, 2003 You're most welcome... Look for Kevin or Kelvin (can't remember how to spell his name). Nice be-spectacled guy. Link to post Share on other sites More sharing options...
Jackfoo 1st Gear September 14, 2003 Author Share September 14, 2003 Hello Assassin & ModelDriver, Thank you ..... is a great website to enjoy after a hard day work in the day. Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie September 17, 2003 Share September 17, 2003 most welcome. do drop by at meetups. Link to post Share on other sites More sharing options...
Jackfoo 1st Gear September 19, 2003 Author Share September 19, 2003 Goodday Modeldriver & fellow MCF members, Once again need advices from you all; kindly share your experience as i'm totally fresh with this topic(Dyno Tuning) Call up Autowerke to check on the pricing it cost about$180 for the Dyno tuning; McWell charge about $70 & UltraMax about $350. Questions: 1) Why there is a great different in pricing between this 3workshops is it due to different DynoMeter(Brands) being use? 2) Correct me if i'm wrong, the higher charge workshop perform more details/more function tests dyno tuning than the lower charge? 3) With the same Dynometer it is able to tune for different cars (Euro & Japan made cars)or it is specially made for just 1 types of car model/car brand? or the workshops have different software for different cars models. Many thanks in advance..... jack Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie September 20, 2003 Share September 20, 2003 Hiya... I only know the diff btw Autowerke and Ultramax. Autowerke dyno attaches straight onto your drive - i.e. they remove the wheels and attach the dyno. Ultramax does the chassis dyno - no need to remove wheels - your car is chained down. Some say the on wheel is more accurate than chassis, while others say the chassis one is better because it's really what you get when you drive on the road (because heavier rims for example will weigh you down, which Autowerke's dyno won't be able to measure). Didn't know that Mcwell has a dyno - been there enough times - they ain't got a dyno, unless they get someone else to do. But still $70 is pretty cheap. Very suspicious. As for tuning, the dyno can tune any car, only thing is the car must have something to tune with - e.g. the SAFCII must fit your car. The tuning is done by adjusting the air/fuel mix using that device, and running the car, and using the dyno to measure results. That's what the dyno does. It's just to measure HP/torque across the RPM range - but because its a controlled measurement, making tuning adjustments on e.g. the SAFCII you can see the effects on the graph. Hope this clears some doubts. Ain't no expect, just share what I know. Link to post Share on other sites More sharing options...
Jackfoo 1st Gear September 20, 2003 Author Share September 20, 2003 Hello Modeldriver, Many thanks for the informations, i think i will go to AutoWerke for my auto tuning for the 1st round. once again thanks.... have a nice weekend Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie September 20, 2003 Share September 20, 2003 no worries.... you have a good weekend too... do share the results after the dyno Link to post Share on other sites More sharing options...
Colinq Neutral Newbie September 20, 2003 Share September 20, 2003 I would suspect that McWell's $70 dyno is done with a GTech Pro? Link to post Share on other sites More sharing options...
Modeldriver Neutral Newbie September 21, 2003 Share September 21, 2003 din know they rent it out though... and wah... what wind blow you here... long time no post ! Link to post Share on other sites More sharing options...
Wrxblue 1st Gear September 21, 2003 Share September 21, 2003 A dyno test is always best done 'before' and 'after' a mod..to get a relative percentage. the relative results is more accurate as the absolute results doesnt really have any meaning is there is no baseline. as the main purpose of the test is to compare whether the mod has improve or reduce the performance figures of the car rite? ↡ Advertisement Link to post Share on other sites More sharing options...
Chemotherapy experience at NCC
Singpost courier dishonesty with incredibly lousy service
RS Chip Tuning
RS Chip Tuning
IKEA shopping experience
