Ace_t Neutral Newbie September 12, 2003 Share September 12, 2003 Hi, can anyone tell me how to engage the ABS in a car ? was having a discussion about ABS with colleagues on how the ABS kicks in... is it jam brake and hold brake pedal and ABS automatically kicks in or u need to step and release brake and jam it without releasing brake for ABS to kick in. ↡ Advertisement Link to post Share on other sites More sharing options...
RadX Moderator September 12, 2003 Share September 12, 2003 (edited) 1. Go fast.. 2. Step hard/JAM BRAKE!!! 3. Feel the vibes agst feet, dun let go..keep foot there..like getting a reflexology massage.. 4. Come to stop without skidding..(most of time) Better if u try on wet roads...more pronounced effect.. Edited September 12, 2003 by RadX Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie September 12, 2003 Author Share September 12, 2003 thanx... so there's no need to 'pre-warn' the car by stepping brake first then jamming it. what happens when the ABS kicks in and u release brake pedal and jam again, will the ABS kick in again ? any time interval ? Link to post Share on other sites More sharing options...
RadX Moderator September 12, 2003 Share September 12, 2003 JAM and JAM and JAM...keep foot there like u life depend on it... As for jam-off, jam-off, unless u do it 30x/s, like the old days and like Schumi, then u doing it the manual ABS way...imaging Ace-T Braking System... ABS will activate when wheels detect some off-balance lock, which will induce skidding...if you were to on-off, you are not getting full effect of braking and stopping distance...which can mean a new front bumper or not.. Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie September 12, 2003 Author Share September 12, 2003 ok thanx a lot... If that's the case, better to jam and keep foot on pedal rite ? are all ABS the same or do they vary with car mfg ? Link to post Share on other sites More sharing options...
RadX Moderator September 12, 2003 Share September 12, 2003 Think for some Contis.....some of them share a common manufac.....but almost all function the same...way Link to post Share on other sites More sharing options...
E36UDM Neutral Newbie September 12, 2003 Share September 12, 2003 (edited) How Anti-Lock Brakes Work by Karim Nice Stopping a car in a hurry on a slippery road can be very challenging. Anti-lock braking systems (ABS) take a lot of the challenge out of this sometimes nerve-wracking event. In fact, on slippery surfaces, even professional drivers can't stop as quickly without ABS as an average driver can with ABS. Location of anti-lock brake components In this article, the last in a six-part series on brakes, we'll learn all about anti-lock braking systems -- why you need them, what's in them, how they work, some of the common types and some associated problems. The Brakes! How Brakes Work How Master Cylinders and Combination Valves Work How Drum Brakes Work How Disc Brakes Work How Power Brakes Work Getting the ABS Concept The theory behind anti-lock brakes is simple. A skidding wheel (where the tire contact patch is sliding relative to the road) has less traction than a non-skidding wheel. If you have been stuck on ice, you know that if your wheels are spinning you have no traction. This is because the contact patch is sliding relative to the ice (see Brakes: How Friction Works for more). By keeping the wheels from skidding while you slow down, anti-lock brakes benefit you in two ways: You'll stop faster, and you'll be able to steer while you stop. Inside ABS There are four main components to an ABS system: Speed sensors Pump Valves Controller Anti-lock brake pump and valves Speed Sensors The anti-lock braking system needs some way of knowing when a wheel is about to lock up. The speed sensors, which are located at each wheel, or in some cases in the differential, provide this information. Valves There is a valve in the brake line of each brake controlled by the ABS. On some systems, the valve has three positions: In position one, the valve is open; pressure from the master cylinder is passed right through to the brake. In position two, the valve blocks the line, isolating that brake from the master cylinder. This prevents the pressure from rising further should the driver push the brake pedal harder. In position three, the valve releases some of the pressure from the brake. Pump Since the valve is able to release pressure from the brakes, there has to be some way to put that pressure back. That is what the pump does; when a valve reduces the pressure in a line, the pump is there to get the pressure back up. Controller The controller is a computer in the car. It watches the speed sensors and controls the valves. ABS at Work There are many different variations and control algorithms for ABS systems. We will discuss how one of the simpler systems works. The controller monitors the speed sensors at all times. It is looking for decelerations in the wheel that are out of the ordinary. Right before a wheel locks up, it will experience a rapid deceleration. If left unchecked, the wheel would stop much more quickly than any car could. It might take a car five seconds to stop from 60 mph (96.6 kph) under ideal conditions, but a wheel that locks up could stop spinning in less than a second. The ABS controller knows that such a rapid deceleration is impossible, so it reduces the pressure to that brake until it sees an acceleration, then it increases the pressure until it sees the deceleration again. It can do this very quickly, before the tire can actually significantly change speed. The result is that the tire slows down at the same rate as the car, with the brakes keeping the tires very near the point at which they will start to lock up. This gives the system maximum braking power. When the ABS system is in operation you will feel a pulsing in the brake pedal; this comes from the rapid opening and closing of the valves. Some ABS systems can cycle up to 15 times per second. Types of Anti-Lock Brakes Anti-lock braking systems use different schemes depending on the type of brakes in use. We will refer to them by the number of channels -- that is, how many valves that are individually controlled -- and the number of speed sensors. Four-channel, four-sensor ABS - This is the best scheme. There is a speed sensor on all four wheels and a separate valve for all four wheels. With this setup, the controller monitors each wheel individually to make sure it is achieving maximum braking force. Three-channel, three-sensor ABS - This scheme, commonly found on pickup trucks with four-wheel ABS, has a speed sensor and a valve for each of the front wheels, with one valve and one sensor for both rear wheels. The speed sensor for the rear wheels is located in the rear axle. This system provides individual control of the front wheels, so they can both achieve maximum braking force. The rear wheels, however, are monitored together; they both have to start to lock up before the ABS will activate on the rear. With this system, it is possible that one of the rear wheels will lock during a stop, reducing brake effectiveness. One-channel, one-sensor ABS - This system is commonly found on pickup trucks with rear-wheel ABS. It has one valve, which controls both rear wheels, and one speed sensor, located in the rear axle. This system operates the same as the rear end of a three-channel system. The rear wheels are monitored together and they both have to start to lock up before the ABS kicks in. In this system it is also possible that one of the rear wheels will lock, reducing brake effectiveness. This system is easy to identify. Usually there will be one brake line going through a T-fitting to both rear wheels. You can locate the speed sensor by looking for an electrical connection near the differential on the rear-axle housing. ABS Questions Should I pump the brake pedal when stopping in slippery conditions? You absolutely should not pump the brake pedal in a car with ABS. Pumping the brakes is a technique that is sometimes used in slippery conditions to allow the wheels to unlock so that the vehicle stays somewhat straight during a stop. In a car with ABS the wheels should never lock in the first place, so pumping the brakes will just make you take longer to stop. In an emergency stop in a car with ABS, you should apply the brake pedal firmly and hold it while the ABS does all the work. You will feel a pulsing in the pedal that may be quite violent, but this is normal so don't let off the brake. Do anti-lock brakes really work? Anti-lock brakes really do help you stop better. They prevent wheels from locking up and provide the shortest stopping distance on slippery surfaces. But do they really prevent accidents? This is the true measure of the effectiveness of ABS systems. The Insurance Institute for Highway Safety (IIHS) has conducted several studies trying to determine if cars equipped with ABS are involved in more or fewer fatal accidents. It turns out that in a 1996 study, vehicles equipped with ABS were overall no less likely to be involved in fatal accidents than vehicles without. The study actually stated that although cars with ABS were less likely to be involved in accidents fatal to the occupants of other cars, they are more likely to be involved in accidents fatal to the occupants of the ABS car, especially single-vehicle accidents. There is much speculation about the reason for this. Some people think that drivers of ABS-equipped cars use the ABS incorrectly, either by pumping the brakes or by releasing the brakes when they feel the system pulsing. Some people think that since ABS allows you to steer during a panic stop, more people run off the road and crash. Some more recent information may indicate that the accident rate for ABS cars is improving, but there is still no evidence to show that ABS improves overall safety. http://auto.howstuffworks.com/anti-lock-brake.htm Edited September 12, 2003 by E36UDM Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie September 12, 2003 Author Share September 12, 2003 (edited) thanx bro(S) for the info altho the final paragraph looks quite alarming that ABS and non-ABS accident rate are the same. Perhaps it's the way ABS is being used during e-braking. For me I've never felt an ABS come into effect and might actually release brake pedal if I felt some pulsating movement under the pedal....thereby INCREASING braking distance. Edited September 12, 2003 by Ace_t Link to post Share on other sites More sharing options...
Soya Supersonic September 12, 2003 Share September 12, 2003 juz step n forget. abs is supposed to help u maintain steering control to avoid a collision and not shorten braking distance. Link to post Share on other sites More sharing options...
RadX Moderator September 12, 2003 Share September 12, 2003 Yep! Good point. Primary aim is steering control and braking distance is secondary and may/may not occur. Q. Does ABS reduce stopping distances? A. Yes, in braking situations where the wheels on a non-ABS equipped vehicle would lock up, ABS will generally provide shorter controlled stopping distance. The amount of improvement in stopping distance depends on many factors, including the road surface, severity of braking, initial vehicle speed, etc. On some surfaces, such as gravel roads, braking distances can be longer, but you will still have the control benefits of ABS. The important capability of ABS is control. ABS provides improved vehicle steerability and stability when braking. Link to post Share on other sites More sharing options...
E36UDM Neutral Newbie September 12, 2003 Share September 12, 2003 If you dun drive very fast, probably hard to activate not unless u brake hard enough to lock your wheels. In an emergency dun think you will release your right foot from the brakes at all Unless you have a very very fast foot if not its hard to beat ABS's speed of braking Link to post Share on other sites More sharing options...
Cloverleaf Neutral Newbie September 12, 2003 Share September 12, 2003 "For me I've never felt an ABS come into effect and might actually release brake pedal if I felt some pulsating movement under the pedal....thereby reducing braking distance." huh? very contradicting leh? Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie September 12, 2003 Author Share September 12, 2003 so your braking distance is actually increased as compared wif non-ABS ? that means in an event of e-brake, u need to stop as quickly as possible and still be able to steer away from the car in front , am I correct ? Me getting a bit confused here. Link to post Share on other sites More sharing options...
RadX Moderator September 12, 2003 Share September 12, 2003 aiyah...better to STEP and KEEP there and not off-steer la... Diff skools of thot la...but well...dun think u wan to try it out Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie September 12, 2003 Author Share September 12, 2003 sori.. should be Increasing braking distance... oops Link to post Share on other sites More sharing options...
Soya Supersonic September 12, 2003 Share September 12, 2003 yep, abs works best not in a straight line but rather, lets u steer away from a crash. Link to post Share on other sites More sharing options...
Ace_t Neutral Newbie September 12, 2003 Author Share September 12, 2003 firstly I need a car wif ABS... game to try I am. so me thinks using ABS has to come into play some skills in road handling as well. Link to post Share on other sites More sharing options...
RadX Moderator September 12, 2003 Share September 12, 2003 "...firstly I need a car wif ABS... .." Most have...but VOLVO car better in ABS...go ask SOY...la ↡ Advertisement Link to post Share on other sites More sharing options...
How Much Do You Know About ABS?
Mazda 5 ABS error
Mazda 5 ABS error
Understanding Anti-lock Braking System (ABS)
Hard to engage in 1st gear after transmission oil change
ABS warning lamp
ABS warning lamp
Honda Sensing
Honda Sensing
Manual gear cannot engage
Clutch stuck and gear were unable to engage
