Andrewkb Neutral Newbie September 22, 2003 Share September 22, 2003 See the pic .. the "recommended" hose is show in the pic .. but that's the one which connects from air filter box to the engine .. which I don't think will work .. since it's not vacuum !!! So I installed elsewhere .. the PVC hose... ↡ Advertisement Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie September 22, 2003 Share September 22, 2003 (edited) I installed my Ecotek & MC on the hose pointed by the red arrow ... Edited September 22, 2003 by Andrewkb Link to post Share on other sites More sharing options...
Yoong Neutral Newbie September 22, 2003 Share September 22, 2003 adding a vacuum relief valve control loh. like ecoteck. Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie September 22, 2003 Share September 22, 2003 How is the parallel connected ? A T-joint that split into 2 devices ? thou 1 is enuf but with 2 u have a better air in-rush during acc, but it has to be in parallel and not daisy cos 1 tubing has high air resistance than 2. Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie September 22, 2003 Share September 22, 2003 So still recommended that I install Ecotek + MC together ? Link to post Share on other sites More sharing options...
Yoong Neutral Newbie September 22, 2003 Share September 22, 2003 wat is MC u refering to? Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie September 22, 2003 Share September 22, 2003 MicroCompressor(MC)/E68/AirMax2 - All same device Link to post Share on other sites More sharing options...
Yoong Neutral Newbie September 22, 2003 Share September 22, 2003 (edited) like this. -----------T-----------T---------------->VACUUM LINE T indicate the tap. Edited September 22, 2003 by Yoong Link to post Share on other sites More sharing options...
Yoong Neutral Newbie September 22, 2003 Share September 22, 2003 wah! MC and ecotek erh? can also... u go it already? Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie September 22, 2003 Share September 22, 2003 Err ... this is serial/daisy chain not parallel leh I supposed parallel is like in this picture rite ? Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie September 22, 2003 Share September 22, 2003 (edited) I got extra Ecotek, you want or not ? Wat other vacuum relief valve control device you had in mind ? Edited September 22, 2003 by Andrewkb Link to post Share on other sites More sharing options...
Yoong Neutral Newbie September 22, 2003 Share September 22, 2003 this is paralle to the vacuum line. Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie September 22, 2003 Share September 22, 2003 Huh ? Which one is parallel to the vacuum line ? Yours or mine ? My perception of yours is: Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie September 22, 2003 Share September 22, 2003 I just got more confused :-P Link to post Share on other sites More sharing options...
Yoong Neutral Newbie September 22, 2003 Share September 22, 2003 you are correct. seem like u are electrically incline. but your parallel got one more addtional joint. ultimatelly i think it is the same as the flow is restricted by the input and output vac line hose diameter. actually my daisy refer to another. Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie September 22, 2003 Share September 22, 2003 still confused ...which is better ? The first pic or the 2nd pic ? Link to post Share on other sites More sharing options...
Yoong Neutral Newbie September 22, 2003 Share September 22, 2003 i think both r as effective. but the series one u refering is easier. Link to post Share on other sites More sharing options...
GDIzen Neutral Newbie September 22, 2003 Share September 22, 2003 Trying to ... you want to buy or not ... 1/2 PRICE? ↡ Advertisement Link to post Share on other sites More sharing options...
How much to install Retractable Awning for home?
Any recommendations to install wooden deck on patio?
Blenheim Palace set to install £1million gold toilet
Toyota Altis can install reverse camera using the in built LCD
Finger Prints or dirt in window film due to improper install
Install side stepper for SUV
Recommend your ICE installer here
Shop To Install Horns
