E68/AirMax can install??
Jackfoo
Then will depend car to car liao. Some car got LPT, but engine can be accommodated the HPT or Vtech can push extremely high rpm. [sly]
Supercharger also very very exp$$ & no GTD their works.
Edited by Mondeo
Someone told me it's the same thing ... by having air pass through a small pipe into the capsule, and then back into the small pipe again, you're "squeezing" air ... so probably the same thing ...
Just that for Capsule case, it uses the internal vacuum, whereas other "open-air" devices, sucks air from outside ...
it works vice versa by sucking air into the brake manifold/reservoir to help braking too.
the only thing is that this fitting for Air Max or E68 doesnt seem to advocate that.
Most cars use this principle where they connect a hose
from inlet manifold to brake reservoir.
If we tee this off and attach the e68, could it be that
brake performance might suffer.. just a thought. [:p]
Yes .. in fact, the website says that the microcompress/e68/airmax should not be fixed onto the brake vacuum hose ... else the brake vaccuum hose will become soft !
