Ilmw 1st Gear July 13, 2002 Share July 13, 2002 Is there a list of "standard" tools for the car? I don't mean to just change tires, but for everything, from working under the bonnect, to doing mods. Car in question is Mitsubishi Galant. ↡ Advertisement Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie July 13, 2002 Share July 13, 2002 Are U referring like screwdriver, spinner those tools? Link to post Share on other sites More sharing options...
Ilmw 1st Gear July 13, 2002 Author Share July 13, 2002 Are U referring like screwdriver, spinner those tools? Yes, and not just tool type, but also sizes .. Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie July 14, 2002 Share July 14, 2002 (edited) Different car brand/model got different size tool, but for the spinner & oil filter tool should a must to have. DIY changing oil! But TB garage got full set (full size ) of tools, we can try to make use of our car Right TB Edited July 14, 2002 by Mondeo Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie July 14, 2002 Share July 14, 2002 Hi! there, Ilmw, I keep a set of tools in 2 kits, box & bag. 1 set of combination spanners, cheap ones 6mm-24mm. 1 set of Elora comb. spanners, not cheap ones 10mm,12mm,13mm,14mm,17mm. 1 set of 1/4" socket wrench, cheap ones, 1.5mm-14mm 1 set of 3/8" socket wrench, Elora, not cheap same as comb. spanner sizes, ratchet, slide bar, 2 sizes extension. 1 set of 1/4" socket wrench, Elora, not cheap ratchet, 2 sizes extension. Phillips & Flat screwdrivers Chisel Pliers Allen key set by Elora Test probe for wiring Multimeter Tyre Pressure gauge Raincoat Car & w/shop manual Car parts CD Fuses Cable ties 3M tape Spare bulbs, bolts, work light taken from side indicators, searchlight, fanbelts, mini air compressor, Jumper cables, long enough to jump-start a dumptruck. Breakdown triangle, floor blinkers from Hyundai cars. Various oils & lubricants And God knows what else. Rgds Paul Yong Link to post Share on other sites More sharing options...
Luke721 Neutral Newbie July 14, 2002 Share July 14, 2002 Hi! there, Ilmw, I keep a set of tools in 2 kits, box & bag. 1 set of combination spanners, cheap ones 6mm-24mm. 1 set of Elora comb. spanners, not cheap ones 10mm,12mm,13mm,14mm,17mm. 1 set of 1/4" socket wrench, cheap ones, 1.5mm-14mm 1 set of 3/8" socket wrench, Elora, not cheap same as comb. spanner sizes, ratchet, slide bar, 2 sizes extension. 1 set of 1/4" socket wrench, Elora, not cheap ratchet, 2 sizes extension. Phillips & Flat screwdrivers Chisel Pliers Allen key set by Elora Test probe for wiring Multimeter Tyre Pressure gauge Raincoat Car & w/shop manual Car parts CD Fuses Cable ties 3M tape Spare bulbs, bolts, work light taken from side indicators, searchlight, fanbelts, mini air compressor, Jumper cables, long enough to jump-start a dumptruck. Breakdown triangle, floor blinkers from Hyundai cars. Various oils & lubricants And God knows what else. Rgds Paul Yong Now I know an extra person to call when i need help Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie July 14, 2002 Share July 14, 2002 Hi! there, Luke721, How's things going for you? I hope you won't call me for breakdown assistance, otherwise, no more business for towing services. Rgds Paul Yong Link to post Share on other sites More sharing options...
Civic Neutral Newbie July 14, 2002 Share July 14, 2002 maybe need yr help someday liao !!!!! hehehehe Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie July 14, 2002 Share July 14, 2002 Hi! there, Civic, I vely good for Civic, my last car also Civic, vely good car, engine can still run without water. Rgds Paul Yong Link to post Share on other sites More sharing options...
Civic Neutral Newbie July 14, 2002 Share July 14, 2002 true or not !!!!! maybe someday must drain the water out than VTEC for 5k to try ....hehehehe Link to post Share on other sites More sharing options...
RadX Moderator July 14, 2002 Share July 14, 2002 hmmm..... with those tools....u sound more like a cat burglar!!! It must weigh quite a bit mate! Link to post Share on other sites More sharing options...
Magfocus 5th Gear July 14, 2002 Share July 14, 2002 I think in terms of tools, cant beat TBs He is probably better equipped than most workshops Link to post Share on other sites More sharing options...
Civic Neutral Newbie July 14, 2002 Share July 14, 2002 yar lor , still have the little ramp!!!!!!! Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie July 14, 2002 Share July 14, 2002 Paiseh lah, my tools all over the place one. Link to post Share on other sites More sharing options...
Magfocus 5th Gear July 14, 2002 Share July 14, 2002 yar lor , still have the little ramp!!!!!!! Not only the ramp, still have pumps, gauges, patches etc Link to post Share on other sites More sharing options...
Magfocus 5th Gear July 14, 2002 Share July 14, 2002 Paiseh lah, my tools all over the place one. Yah all over the place in a nice big tool box eh? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie July 14, 2002 Share July 14, 2002 Big clumsy tool box lah, try walking a distance with that big sucker Well tools are like toys to a DIY guy, keep collecting more and more over time. Link to post Share on other sites More sharing options...
Magfocus 5th Gear July 14, 2002 Share July 14, 2002 Big clumsy tool box lah, try walking a distance with that big sucker Well tools are like toys to a DIY guy, keep collecting more and more over time. Dont you have the tools in your car?? Not forgetting the pump, gauges etc ↡ Advertisement Link to post Share on other sites More sharing options...
Taobao Sure Can Buy List
SPARE PARTS LIST
SPARE PARTS LIST
Tool to change Spark Plug
List of Autoparts Distributors in Singapore
Comments on T3B system as a trading tool
Singapore Bib Gourmand list
Car Insurance Comparison List~!
Scan Tool
Scan Tool
