Tyre rotation
Acemundo
Hi,
just wondering how do we know if our tyres are the type that can rotate from left to right.
i know rotating from front to back is the standard, but as I got 1 new vs 4 old tyres, was thinking of rotating from left to right if possible.
by the way, to do our own rotation, means better to have 2 jacks at least right?
If you want to rotate left to right, your tyre's thread pattern has to be similar at both side.
The top tyre cannot be rotated left to right as the inner and outer thread pattern is different.
The bottom tyre can.
Edited by Mikeckchong
thanks for the graphics.......really helpful.
i did heard of such thing as it being tyre dependent.....but now i see it, i understand fully.
thanks!
Even if you have the hydraulic lift it can't be done, unless you also happen to have the machine to remove and refit tyres.
Just think.......if you take your left tyre and try to put it on the right, the tyre will face backwards instead of forward. Unless your tyre happen to be miltidirectional instead of unidirectional.
Actually the diagram cum explanation is wrong.
The lower tyre is directional too. Unless you rip the tyre from the rims and fix it on in reverse. Else the tyre thread will be facing backwards. WRONG usage.
With directional tyre, the only tyre rotation you can do is only front and back. Cannot do diagional or lef/right. Unless you rip the tyre out from the rim and re-fit back on the other side.
Then tyre rotation front and back is LPPL.
Morale of the story, DUN BOTHER TO DO TYRE ROTATION. [idea]
The tyre picture on top is special from left to right threads.
The tyre picture at the bottom is special as the threads are pointing to one-driection like and arrow head.
The bottom design is such that when moving over water or other fluid, the water will escape by the side of the tyre for better friction on rainy days.
So really dun bother to do tyre rotation. [thumbsup]
