Andrewkb Neutral Newbie January 26, 2004 Author Share January 26, 2004 For my car, it's such a simple thing ... how does it work ? ↡ Advertisement Link to post Share on other sites More sharing options...
E36UDM Neutral Newbie January 26, 2004 Share January 26, 2004 (edited) I'm not an expert with camber kits but that looks like for ur front. As long it works its good enough btw does it come with bushings? Edited January 26, 2004 by E36UDM Link to post Share on other sites More sharing options...
Yeobh 4th Gear January 26, 2004 Share January 26, 2004 The bolt has a cam-like centre portion ( offset from the bolt centre line). By screwing the bolt in or out will force linear movement to the wedge like assembly connecting to the wheel discs brake assembly. The linear movement will alter the wheel camber angle. For macpherson strut the method of adjusting the camber is to replace the exsiting strut top fix hole mounting plate with a new mounting plate that comes with elongated holes.The elongated holes allow certain amount of movement for the macpherson strunt, once the correct camber is set, the strunt is then bolt into place. Link to post Share on other sites More sharing options...
Saaber Neutral Newbie January 26, 2004 Share January 26, 2004 you are also using it lah... Link to post Share on other sites More sharing options...
E36UDM Neutral Newbie January 26, 2004 Share January 26, 2004 Yup i know if not lagi jiatlat..... Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie January 26, 2004 Author Share January 26, 2004 Dunno about bushing .. this pic is what I found ... Link to post Share on other sites More sharing options...
Yongwd 1st Gear January 26, 2004 Share January 26, 2004 how about "on the fly" adjustable camber bolts? Link to post Share on other sites More sharing options...
Saaber Neutral Newbie January 26, 2004 Share January 26, 2004 not jiatlat lah... Link to post Share on other sites More sharing options...
E36UDM Neutral Newbie January 26, 2004 Share January 26, 2004 Then i wun change tyres leow Link to post Share on other sites More sharing options...
Saaber Neutral Newbie January 26, 2004 Share January 26, 2004 ...but you still must go and do your alignment lah... Link to post Share on other sites More sharing options...
E36UDM Neutral Newbie January 26, 2004 Share January 26, 2004 oh yes that one must do coz really out leow Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie January 26, 2004 Share January 26, 2004 alignment out ah....change car lah....dun spend the money doing such things.....ask mike, he sure agree one Link to post Share on other sites More sharing options...
Saaber Neutral Newbie January 26, 2004 Share January 26, 2004 ahbuthan, if not sliding all over the place liao.... Link to post Share on other sites More sharing options...
E36UDM Neutral Newbie January 26, 2004 Share January 26, 2004 alignment cost me $50 only leh Link to post Share on other sites More sharing options...
E36UDM Neutral Newbie January 26, 2004 Share January 26, 2004 yup screeching everyday man Link to post Share on other sites More sharing options...
S2P2 Neutral Newbie January 26, 2004 Share January 26, 2004 $50 leh....better change car Link to post Share on other sites More sharing options...
Saaber Neutral Newbie January 26, 2004 Share January 26, 2004 aka initial d style... Link to post Share on other sites More sharing options...
E36UDM Neutral Newbie January 26, 2004 Share January 26, 2004 change car i will lose like seow ↡ Advertisement Link to post Share on other sites More sharing options...
Math Question
Math Question
Question on Transfer of Car Ownership
Question for Car Servicing
COE renewal question
Question of polyclinics
Noob questions on property
PSLE Maths question. How to solve?
