Silverh Neutral Newbie April 8, 2002 Share April 8, 2002 Hmm...perhaps I should consider going higher too...Thanks for the info. ↡ Advertisement Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie April 8, 2002 Author Share April 8, 2002 I suggest U try 240kPa or 250kPa all round and note the rear tire may need slightly (10 or 20kPa) less. I pump around 40kPa above recommended on my brick's front tires as the factory specs are too low and causing shoulder wear on my front tires. The rears are fine with factory specs. Link to post Share on other sites More sharing options...
Magfocus 5th Gear April 8, 2002 Share April 8, 2002 Perhaps i should try too, see what its like Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie April 8, 2002 Author Share April 8, 2002 The general tip is higher pressure for economy and high speed driving and lower pressure for comfort. Link to post Share on other sites More sharing options...
Magfocus 5th Gear April 8, 2002 Share April 8, 2002 I am sure there must be a limit to the max allowable pressure... Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie April 8, 2002 Author Share April 8, 2002 Of course lah Max pressure is indicated on the side wall of the tire but usually shouldn't go above 2-4psi of manufacturer recommended pressure. e.g. for my brick: recc 33psi, I pump 36psi (front) recc 30psi, I pump 32psi (rear) So far best setup for me is the above pressures after trial and errors and butt feel Link to post Share on other sites More sharing options...
Oinkened Neutral Newbie April 8, 2002 Share April 8, 2002 Hi Silverh, The ghia version of the focus is quite different from the comfort and the Ambiente version. 1) leather wrap steering wheel, 2) wood grain triming for instrutment panel & door, 3) one more room light, 4) dimmer : speedometer panel, 5) s/s triming strip for door step ( only at fr dr ). 6) electric control driver seat heigh adjustment. 7) internal dr opening handle in chrome, dr panel also some diffen. The main obvious difference is that that will be a GHIA embled on the back of all ghia model. If you have fitted in the foglights then u will have the rheostat. This is found in all models of comfort that have foglights installed The fact that you have your focus for only a month and clock only 1000m plus km confirm that you are driving the new focus 2002 comfort model. If you wish to check it out, just go to onemotoring or ur log card and check ur omv. If it is 14-16 k then it is the comfort model. If it is 18-22k then it is the ghia model. I am driving a comfort 2002 model as well and unlike u guys I have 16 " rims installed. This should increase my fuel comsumption. I have gotten my car for just 3 months and have clocked 7000 km. (have neber travel further than woodlands). My fuel comspt. is about 10 km/l. I am very sure that I am clocking about 370-380 km when it reaches the 1/4 tanks level. That is approx. 35-50 l. Focus full tank is about 55 l and remember even if u fuel light lights up, u sld still have about 5-7 l left. Link to post Share on other sites More sharing options...
Oinkened Neutral Newbie April 8, 2002 Share April 8, 2002 Actually the back tyres does not neccessary have to be less than the front. In fact if the car is for family driving where it is common for 4 people to be in the car, the tyres behind should be at least the same or even more than the front. Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie April 8, 2002 Share April 8, 2002 I think Focus stock tyres are high profile 60 right!? not to worry whether comfort- its already comfort tyres. So first should considerate the higher pressure. Link to post Share on other sites More sharing options...
Silverh Neutral Newbie April 9, 2002 Share April 9, 2002 Thanks Oinkened, btw what tyre pressure do you use and it's yours an auto or manual ? I think I ought to get my car for a early checkup. Seems like my Focus is the most thirsty around ! Link to post Share on other sites More sharing options...
Magfocus 5th Gear April 9, 2002 Share April 9, 2002 (edited) The suspension is quite firm, so with the higher profile tyres, it would be more comfortable Mitigates the firm suspension. My tyres feel like they have too much pressure already! Edited April 9, 2002 by Magfocus Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie April 9, 2002 Share April 9, 2002 How much tyre pressure U pumped in? Link to post Share on other sites More sharing options...
Magfocus 5th Gear April 9, 2002 Share April 9, 2002 34psi for the front, 32psi for the back, feels very firm already. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie April 9, 2002 Author Share April 9, 2002 Actually the back tyres does not neccessary have to be less than the front. In fact if the car is for family driving where it is common for 4 people to be in the car, the tyres behind should be at least the same or even more than the front. U're right on this point. Whenever I have full load or airport load I'll pump 36psi front and back. Most of the time I am either solo or only have one passenger up front so never really biased for the rear much. Link to post Share on other sites More sharing options...
Mondeo Neutral Newbie April 24, 2002 Share April 24, 2002 Issued on 16 April 2002 OUCH! ONE MORE FOCUS RECALL Ford has issued the ninth recall for the otherwise pleasant Focus compact. The latest safety recall involves more than 500 SVT Focus hatchbacks; the company says the throttle on the high-performance model could stick in the open position. The SVT Focus is built along with the other three-doors in Hermosillo, Mexico. No accidents or injuries have been traced to the problem. __________________ Tickford Owners Club of Tasmania Link to post Share on other sites More sharing options...
Silverh Neutral Newbie April 25, 2002 Share April 25, 2002 The fuel consumption for my Focus has improved. I increased the tyre pressure to 240 for front and remain 220 for the back tyres. So could be the change in tyre pressure of somehow the engine begins to be more efficient after a while. Anyway, I travelled to Ipoh (Msia) last weekend and my full tank could cover 600+km. Really enjoyed the drive. It was very stable even when I hit 170km/h. Fortunately I didn't get any summons even though there were 4 police blocks along the way ! I attribute it to me slowing down when approaching overhead bridges and blind spots 'cos there's where the TP likes to locate their cameras. However, I still can't help noticing the "tee tee" sound from below the car each time I parked my car. Anyway I will check it out when I send my car for 1st servicing. It has covered 3100 km. Link to post Share on other sites More sharing options...
Magfocus 5th Gear April 25, 2002 Share April 25, 2002 I realised that i get better consumption if i pump V power. Previously at half tank i got about 240km now with synergy 8000 i got only 210km. You have travelled 3100km and you have not gone for your first service?? Link to post Share on other sites More sharing options...
Silverh Neutral Newbie April 25, 2002 Share April 25, 2002 Well, it's because before I went Msia it was only 1600+ and after I came back it hit 3000. So that's how it exceeded ↡ Advertisement Link to post Share on other sites More sharing options...
Comparing Opel Astra 1.6 Twinport and Ford Focus 1.6 H/B
2018 / 2019 Ford Focus
Ford Focus titanium
Ford Focus titanium
Focus
Focus
Ford Focus battery, where and which brand to change?
Anyone knows Ford Focus Maintenance/servicing Cost
[Post Event] MCF Hangout with VW May 2018
2004 Saleen N2O Focus
