Ghostrider8 Clutched February 11, 2004 Share February 11, 2004 Wonder what presuure to pump for 205/50/R16 tire? Still 220 or more ↡ Advertisement Link to post Share on other sites More sharing options...
Saaber Neutral Newbie February 11, 2004 Share February 11, 2004 check here: http://www.mycarforum.com/forum/gforum.cgi?post=290262;sb=post_latest_reply;so=ASC;forum_view=forum_view_collapsed;;page=un read#unread://http://www.mycarforum.com/forum/gfo...=un read#unread://http://www.mycarforum.com/forum/gfo...=un read#unread://http://www.mycarforum.com/forum/gfo...=un read#unread Link to post Share on other sites More sharing options...
Ghostrider8 Clutched February 11, 2004 Author Share February 11, 2004 bro, the site do not have my Stream detail. Any bro on 16" tire, how much air do u guy pump? Link to post Share on other sites More sharing options...
Virus 2nd Gear February 12, 2004 Share February 12, 2004 220 is OK. Normal range is between 200 - 240, depending on personal driving style and preference. Link to post Share on other sites More sharing options...
Saaber Neutral Newbie February 12, 2004 Share February 12, 2004 check with andrewkb, he is driving a stream now... Link to post Share on other sites More sharing options...
Ravinged 5th Gear February 17, 2004 Share February 17, 2004 My 93 Civic on 14 inch now ... 250 for front ... 240 for rear. A little bouncy. Ed Link to post Share on other sites More sharing options...
Saaber Neutral Newbie February 17, 2004 Share February 17, 2004 try 220 loh... Link to post Share on other sites More sharing options...
Ravinged 5th Gear February 17, 2004 Share February 17, 2004 220 cannot ... too draggy ... I tried already ... front/rear ... 210/200 ... 220/210 ... 230/220 ... skip 240/230 ... now on 250/240 ... best effect. Ed Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear February 17, 2004 Share February 17, 2004 Wonder what presuure to pump for 205/50/R16 tire? Still 220 or more Wattz dis ? We have another ghostrider here ?? How much to pump depend on what is your tyre & peference. For your size normally they recommend you do around 220-240. For comfort. But some tyres like Goodyear Eagle need to pump it a little more to extract the performance. If you have doubt, refer to the door panel of your car for the recommended pressure. If not check thru your manual, they should have some guideline for you to follow. Link to post Share on other sites More sharing options...
Toybabe Neutral Newbie February 17, 2004 Share February 17, 2004 U pumped so much?? I always have the impression that the tyre will burst Link to post Share on other sites More sharing options...
Ravinged 5th Gear February 17, 2004 Share February 17, 2004 These are tyres lah babe ... not balloons ... I am now again on Goodyear GT ... I pump in 210/200 (front/rear) ... the bottom flatten out quite abit, and I feel that drag so much when I take off. So slowly pump in according to the ratio and see which is the best ... BINGO ... 250/240 is giving me the best performance ... it's quite big a ratio for 14" tyres ... I was surprised too when I had to pump in that much. Tyres wise, initially quite slippery ... but as the tyre wear out, the grip gets better and I have no skidding so far on wet road. And rather quiet too. If you are not into hard driving like me, then can give it a try. 75/pc Ed Link to post Share on other sites More sharing options...
Toybabe Neutral Newbie February 17, 2004 Share February 17, 2004 Whats the rationale of pumping different PSI for front and back?? I always pump either 220 or 230.. Link to post Share on other sites More sharing options...
Ravinged 5th Gear February 17, 2004 Share February 17, 2004 Most car are front wheel drive ... and therefore greater pressure on the front wheels. Advisable to pump a little higher for the front to compensate for the weight of the engine block resting on your front tyres. Rear wise, I assume you don't really fill up your boot 100% every single day. Ed Link to post Share on other sites More sharing options...
Ravinged 5th Gear February 17, 2004 Share February 17, 2004 Refer to these threads ... http://www.mycarforum.com/forum/gforum.cgi...e=unread#unread http://www.mycarforum.com/forum/gforum.cgi...e=unread#unread and this also another very informative thread ... http://www.mycarforum.com/forum/gforum.cgi...e=unread#unread ↡ Advertisement Link to post Share on other sites More sharing options...
Portable Tyre Pump
Portable Tyre Pump
HSA recalls 3 brands of high blood pressure drugs
Tyres pressure for 225/45/R17
Pump Petrol In JB - Worth it
How often do you pump air for tyres?
Bedok Esso faulty pump
Here we go again... Pump price up
How useful is higher pressure radiator cap?
