Rayleigh 6th Gear February 21, 2004 Share February 21, 2004 Hi Guys Need to check with you guys the following. 1)In auto car, if you stop on a slop (eg HDB carpark), with the gear in "D" mode, if you release your foot brake and does not step on the accelerator, does your car roll back? Or is there a slight/heavy roll back? 2)Is is ok for roll back? Will the gear box or the engine be damage in relation to question 1? 3)On that slop mentioned earlier, must the gear be shift to "2" mode? 4)I test drave my friend's matrix (brand new) yesterday and had a shock when the car roll back while in "D" mode (moving from stationary on a slope). I think this is an abnormal behavious. Could it be because the car is too heavy and the creep forward force cannot overcome the weight of the car on the slop? 5)In auto, what is the procedure in moving off the from slop without damaging the car. 5)In auto mode, normally at what speed when the fourth gear is engage. Can we see the gear change at RPM needle. ↡ Advertisement Link to post Share on other sites More sharing options...
Magfocus 5th Gear February 21, 2004 Share February 21, 2004 Let me see... 1)In auto car, if you stop on a slop (eg HDB carpark), with the gear in "D" mode, if you release your foot brake and does not step on the accelerator, does your car roll back? Or is there a slight/heavy roll back? Your car would roll back if its a steep slope, unless the gradient is more gradual. Usually its only a slight roll back. 2)Is is ok for roll back? Will the gear box or the engine be damage in relation to question 1? No problems at all, both engine or gearbox would not be damaged. 3)On that slop mentioned earlier, must the gear be shift to "2" mode? No, leaving it in "D" is fine 4)I test drave my friend's matrix (brand new) yesterday and had a shock when the car roll back while in "D" mode (moving from stationary on a slope). I think this is an abnormal behavious. Could it be because the car is too heavy and the creep forward force cannot overcome the weight of the car on the slop? Like I said earlier, it depends on the gradient of the slope and probably the weight of the car. Nothing abnormal about that. Its perfectly normal. 5)In auto, what is the procedure in moving off the from slop without damaging the car. One foot on the brake, tranny in "D". Move off, release brake, push the accelerator, thats it!! 5)In auto mode, normally at what speed when the fourth gear is engage. Can we see the gear change at RPM needle. Depending on the make of the car and possibly gearing. Yeah, the RPM should change when the gear changes. Hope it answers your questions.. Link to post Share on other sites More sharing options...
Hitman Neutral Newbie February 21, 2004 Share February 21, 2004 Excellent advice Link to post Share on other sites More sharing options...
Magfocus 5th Gear February 21, 2004 Share February 21, 2004 Just mainly my opinion actually.. Link to post Share on other sites More sharing options...
Rayleigh 6th Gear February 21, 2004 Author Share February 21, 2004 (edited) Hi Magfocus Thanks for your advice. Just a few more doubts, In relation to Question 1 and Question 4, will the roll back stop? Cos when I tried on my friend's Matrix, the car rolled back more than a half a meter and still did not stop until I step on the brake or accelerator. Is this normal? If this is normal then it is no different from maual car except that it does not require biting point. Edited February 21, 2004 by Rayleigh Link to post Share on other sites More sharing options...
Rayleigh 6th Gear February 21, 2004 Author Share February 21, 2004 Magfocus Paiseh to bother you again. In relation to question 2) you mentioned that the gear and the engine will not be damage. Why is that so? If the gear is need "D" mode. The engine is already engaged and trying to move the vehicle forward (As seen on flat surface). Therefore at that instance the car roll backward, isn't that back roll reversing the motion/action of the "D" mode gear? Hope you understand what I'm trying to say. Link to post Share on other sites More sharing options...
Dualie Clutched February 21, 2004 Share February 21, 2004 Auto can does roll back if the slope is steep enough. Once it start rolling, it will roll and roll until U step on brake or accelerator or if U engage a lower gear. This is NORMAL. A manual car will roll on the slightest gradient, wherelse a auto car need a steeper gradient before it will roll back. Link to post Share on other sites More sharing options...
Cordia_gsr Neutral Newbie February 21, 2004 Share February 21, 2004 it will nevr stop till the gradient of the slope ease off. it's very common for all auto cars, be it small or high capacity. Just as advise, one foot on brake and one foot on accelerator. Link to post Share on other sites More sharing options...
Rayleigh 6th Gear February 21, 2004 Author Share February 21, 2004 Hi Dualie One doubt down. Thanks for the information. Link to post Share on other sites More sharing options...
Magfocus 5th Gear February 21, 2004 Share February 21, 2004 As the others have mentioned, the roll back would not stop, until you hit the brakes or reach level ground, or hit an obstruction Basically, its perfectly normal for an auto car to roll back on a slope. Link to post Share on other sites More sharing options...
Rayleigh 6th Gear February 21, 2004 Author Share February 21, 2004 Cordia_GSR hm....... you mean left leg on brake and right leg on accelerator???? no hard feelings!!!! Link to post Share on other sites More sharing options...
Cordia_gsr Neutral Newbie February 21, 2004 Share February 21, 2004 that's right, it's like half clutch style . i forever remember this because that's where i got the boot back-sitting on the car behind on slope when i just got my license many years back then. i got all puzzled like you why auto cars still roll back. it's a painful experience. Link to post Share on other sites More sharing options...
Rayleigh 6th Gear February 21, 2004 Author Share February 21, 2004 All MCF brother Thanks for the information. You guys have been agreat help to me. Will be collecting my Red Matrix in a few days time. Me cannot wait so tested my friend's matrix. Link to post Share on other sites More sharing options...
Magfocus 5th Gear February 21, 2004 Share February 21, 2004 Congrats on your new Matrix! Do post a pic of your ride when you get it.. Link to post Share on other sites More sharing options...
Coyote Neutral Newbie February 21, 2004 Share February 21, 2004 Good to pose question, if not sure, cos we may not know everything - right. I also learnt alot from others in MCF. So dont worry if the question sounds stupid, in the end, not only you will learn but others who is not so sure will also learn. Link to post Share on other sites More sharing options...
Cordia_gsr Neutral Newbie February 21, 2004 Share February 21, 2004 that's right. congrats on your new ride. remember to run-in well Link to post Share on other sites More sharing options...
Vtim 3rd Gear February 21, 2004 Share February 21, 2004 you bro, your right man. we are all here to learn something, knowledge is never ending but if you don't ask, then the knowledge is not gain ↡ Advertisement Link to post Share on other sites More sharing options...
Persistent Lower Back Pain
Are station wagons making a come back with sedans fading?
Why Singapore does not support renewable energy and EV?
Feedback
Feedback
Is Scoliosis Treatable
