Teckheng Neutral Newbie June 13, 2004 Share June 13, 2004 my dad told me cannot... he say the radio is fix to the computer chip and cannot be remove ? he bluff me or really cannot install ICE ? wad is the disadvanage of installing ICE ? my baby is only 4months old. Should I install ICE ? ↡ Advertisement Link to post Share on other sites More sharing options...
Emiffy Neutral Newbie June 14, 2004 Share June 14, 2004 Yes you can. I'm assuming it's a 3-series E46. The 5-series E39 also can. If yours is a 7-series, then I'm lost! Link to post Share on other sites More sharing options...
RadX Moderator June 14, 2004 Share June 14, 2004 Emiffy...sooooooooooooooooo cute!!!!! Link to post Share on other sites More sharing options...
Soya Supersonic June 14, 2004 Share June 14, 2004 of course u gotta ICE up. worse case, ditch the HU and revamp the whole set up. Link to post Share on other sites More sharing options...
RadX Moderator June 14, 2004 Share June 14, 2004 (edited) No problems..should be able to do it. The regular installer that the bimmer fellas go to is at Hong Guan, located at Bt Timah. Do a search in the BMW forum and you can locate him. Edited June 14, 2004 by RadX Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear June 14, 2004 Share June 14, 2004 It can be done. It depend on how much you want to do. 1) You can maintain your orginial BMW HU. Connect a amp and change speakers for a simple upgrade. 2) Remove the HU and use a aftermarket HU. The installer will install a piece of plastic over the orginial hole and your headunit will be in the centre only. From here, its up to you on how much you wanna blow on your system. Basically its the sky's the limit. The advantage of (1) is that you can actually maintain your control from your steering wheel. Bad is that upgrade is limited...not much of a choice as you only can do a amp and speakers...cannot install preamps, X'overs etc. Advantage of (2) is that sky is the limit...no stopping you of transforming your car into a boom box. Disadvantage is that you cannot control the HU from the steering wheel. Better installers would have no problem doing such a job as E46 are not a rare sight on our road and some of the owners have did it before. You can call the following installer for a check on the options avaliable to you. Hong Guan, JM Mobile (aka Jimmy Mobile), Dynasty Soundcraft, Zoom Audio, Tye Electronics, Mova (Bukit Timah) Link to post Share on other sites More sharing options...
Soya Supersonic June 14, 2004 Share June 14, 2004 wonder if the stock beemer HU comes wif RCA preouts to enable a basic amp upgrade coz wowo HU doesn't. Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie June 14, 2004 Share June 14, 2004 yes you may do so. BMW's ECU is quite complicated. I take it that when you wanna fix ICE, your gonna go to the extend of fixing woofers, amps ... etc. Thats gonna suck alot of electricity from your car, therefore performance wise, pls do not expect much esp. a valvetronic 318. However if you wanna say maintain or increase your performance, you may choose to fix pulleys. Cost approx $400 from BVO. Apparently the pulleys provides the kind of performance you would expect with your aircon, lights, radios, or misc items switched off. Therefore giving the extra juice and throttle response. Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear June 15, 2004 Share June 15, 2004 I am not sure if it comes with RCA, but it can be done. Seen it done on many E39s and E46 before. Even the C Class (new ones) also can be done...the controls on steering wheels and display on the speedometer is retained. ↡ Advertisement Link to post Share on other sites More sharing options...
How much to install Retractable Awning for home?
Any recommendations to install wooden deck on patio?
Blenheim Palace set to install £1million gold toilet
Toyota Altis can install reverse camera using the in built LCD
Finger Prints or dirt in window film due to improper install
Install side stepper for SUV
Recommend your ICE installer here
Shop To Install Horns
