Tien Neutral Newbie August 20, 2004 Author Share August 20, 2004 this is one good tip!!! you have any shop to recommend? how much cable do we need for 5-6 points? i saw some have this metal piece connected to the -ve terminal of batt... cables are first connected to this piece, then this piece is screwed to the -ve terminal. what do you call this metal piece? ↡ Advertisement Link to post Share on other sites More sharing options...
Arah Neutral Newbie August 20, 2004 Share August 20, 2004 so far no sifu so cannot confirm if the workshop is on.... what car you driving? think you can help us ID those parts? if yes maybe we can use your car's grounding as blue print and trial n error... Bro....just get 1 of our Chevykaki who has already done grounding on their car then copy the pointslah. Can actually use their cable measurements also, much faster and effectiveleh. Just an idea. Link to post Share on other sites More sharing options...
Ahliew Neutral Newbie August 20, 2004 Share August 20, 2004 (edited) grounding strip/strap. my city has 1 apparently i think i also saw one on bro yeoman's ride too? a gold plated plate. i could be wrong Edited August 20, 2004 by Ahliew Link to post Share on other sites More sharing options...
Arah Neutral Newbie August 20, 2004 Share August 20, 2004 That metal strip is an essential component with it you are able to run the cables much more tidy. Oh yeah dont forget to get tons of cable ties. Link to post Share on other sites More sharing options...
Phochem Neutral Newbie August 20, 2004 Share August 20, 2004 its the distributor, not sure if the shops there stock any. Jus get a pre-cut grounding pack from car accessories shop and use the distributor supplied, the cable in the pack is usually 3m(8AWG) in length. Some cars might need longer than 3m so its best to get extra cables(commonly in red colour), lugs and heat shrinks from sim lim tower jus in case. I tink 5m shld be more then enuff liao. i went to the shop at the basement, take the escalator down and the shop is on the left hand side. Link to post Share on other sites More sharing options...
Phochem Neutral Newbie August 20, 2004 Share August 20, 2004 Yes, thats the fastest way liao. Link to post Share on other sites More sharing options...
Tien Neutral Newbie August 20, 2004 Author Share August 20, 2004 i can only think of 1 bro here.... U!!! Link to post Share on other sites More sharing options...
Tien Neutral Newbie August 20, 2004 Author Share August 20, 2004 the audio shop beside those carpark entry/exit barriers? Link to post Share on other sites More sharing options...
Arah Neutral Newbie August 20, 2004 Share August 20, 2004 kekekekek . Link to post Share on other sites More sharing options...
Arah Neutral Newbie August 20, 2004 Share August 20, 2004 3 m can get you 5 point gounding . Link to post Share on other sites More sharing options...
Phochem Neutral Newbie August 20, 2004 Share August 20, 2004 really depend on car lah. 'cos there's one cable i ran it to the car's ECU is ard 1.5m liao. Link to post Share on other sites More sharing options...
Phochem Neutral Newbie August 20, 2004 Share August 20, 2004 Not those, the shop is located at the basement. Kinda like a hardware shop for electricians Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear August 20, 2004 Share August 20, 2004 At SLT, you can get the 8AWG for $2.50 per meter (max). I still have about 30-40 lugs. Let me know if you want. Link to post Share on other sites More sharing options...
Tien Neutral Newbie August 20, 2004 Author Share August 20, 2004 heard this SLT frequently... what shop is this and where? Link to post Share on other sites More sharing options...
Ahliew Neutral Newbie August 20, 2004 Share August 20, 2004 (edited) sim lim tower lo. almost everywhere in there sells wires and those electrical stuffs but where cheaper or not, got to check out with those regulars liao Edited August 20, 2004 by Ahliew Link to post Share on other sites More sharing options...
Tien Neutral Newbie August 20, 2004 Author Share August 20, 2004 thanks man! Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear August 20, 2004 Share August 20, 2004 SLT aka Sim Lim Tower is a building. Located opposite Sim Lim Square. Once you are in the building, proceed to the basement. you sure can find shops selling cables. Link to post Share on other sites More sharing options...
Tien Neutral Newbie August 24, 2004 Author Share August 24, 2004 anyone else wanna join in? and i guess can get a few fellows to show us their grounded cars =============================================================== ok, i personally wanna ground my aveo. understand i can easily get it done at accessories shop for some $$ however, in the spirit of "getting to know my car better", i thought of doing this myself... anyone wanna join? of course, for this to work, i will need an old hand who is good with ground to volunteer his knowledge and expertise... any one interested, regardless of make or model, pls indicate your name below. time n date to be advised later, most likely one of the weekends. still, nothing is firm ok? cos we need some old bird willing to volunteer first... Learners ====== 1. tien (aveo, 1.4A) 2. Viz88 (aveo 1.4M) 3. Capricorn (??) 4. sgrc3r (aveo, 1.5A) 5. Advisors ====== 1. 2. 3. ↡ Advertisement Link to post Share on other sites More sharing options...
Workshop for simple jobs
Grinding racket
Grinding racket
Over 900 flats to be built in Sin Ming; first new HDB project in the area in over 30 years
