Rpm problem...HELP!!!!
Cyrix
I think u shd sent your ride for a tune-up.
A good tune up can identify and rectify problems describe by u.
Unfortunately, I'm not able to recommend u any workshop.
But if you ask around and look in the ads u shd be able to find some reputable tune-up shop.
cheers
My previous car had the same problem of irregular idling rpm when stationary. But not all the time - sometimes no problem but comes back again after a while. The following is what I did:
1) Electronic diagnostic test - fault indicated at fuel regulator - changed
2) Check plugs and cables - changed
3) Check throttle body - cleaned
4) Check a/c compressor and vacuum - no problem
5) check MAF sensor - cleaned with solvent
6) changed New MAF - cured!!!!!!
Same problem came back a week later..........Final diagnosis - most probable cause - ECU error!!!!!!!!!!!!!
Finally - car scrapped.
Thanks for sharing.
In your case U went for diagnostic test and check and clean a couple of things.
Apparently the problem was not actually identified. If it was the problem would be solved.
A good tune up check ignition system, mixture and exhaust emission.
It also check the the valve are correctly adjusted IAw engine specifications.
If all parameter are according to engine specs and the problems still persists than we focus on the component that might contribute the problem, one at a time.
Having the diagnostic equipment, does not necessary mean that the mechanics or worker is fully capable of solving the problem. Even agent, have to refer to their manufacturer shd out of the norm prop up.
My views
Yup, what I did was more like a progressive trouble-shoot to eliminate the possibilities. But at the end of the day, the problem still came back. It goes to show that the more electronics there is, the more complicated it can be.
Agreed [thumbsup]
Modern electronics is cool, hightech,impressive..
If spoil .... then complication and headache come in.
bro....i will do just tt...just wan to ask u...my EK can fit a DC2 ECU???..
any performance???
put in a DC2 cam, cylinder head, throttlebody and intake manifold and you will get good increase in power...thumbsup.gif
