Sucker Clutched October 17, 2004 Share October 17, 2004 Hi there, I was told that the engine mounting for Manual Car is not suitable for an Auto Car. The Manual Car engine mounting is hard and the Auto Car will have vibrations. Is it correct? Thanks Sucker! ↡ Advertisement Link to post Share on other sites More sharing options...
Apollo 1st Gear October 17, 2004 Share October 17, 2004 nope.... dunno who tell u crappy stuff like this. afaik, u must use back the same type of engine mounting and should at all times use back OEM ones. there r 2 type of mounting. rubber padding (general cars) and hydraulic ones for more expensive/ continential cars. 1 Link to post Share on other sites More sharing options...
Oogmsn Neutral Newbie January 19, 2010 Share January 19, 2010 Hi anyone knows if there is a way to change for engine mounting rubber cheaper? I was quoted at 380++ for the rubber, and I saw online that the rubber is less only around USD35 per pair online, but they only have it for left hand drive. Any kind soul can help to provide advise if there is cheaper alternative? My car is a Suzuki Swift 1.5. Link to post Share on other sites More sharing options...
Kimikichin Clutched January 20, 2010 Share January 20, 2010 Hi anyone knows if there is a way to change for engine mounting rubber cheaper? I was quoted at 380++ for the rubber, and I saw online that the rubber is less only around USD35 per pair online, but they only have it for left hand drive. Any kind soul can help to provide advise if there is cheaper alternative? My car is a Suzuki Swift 1.5. Hmm. 380++ seems abit ex? What registration year is your Swift? Sports Edition? Link to post Share on other sites More sharing options...
Nmnhnlm Clutched January 20, 2010 Share January 20, 2010 You can buy the mountings and change youyself. You can use rubber mountings or those poly urethane aftermarket ones. I don't like Hydraulic mountings cause it leaks as it ages. Used to have a 318is and 520i. Hyro mountings, sucks. And still have vibration. Link to post Share on other sites More sharing options...
Stinkray Clutched January 20, 2010 Share January 20, 2010 since we are in this topic.... normally how long will stock rubber engine mounting last ??? 3yrs ?? 4 yrs ?? Link to post Share on other sites More sharing options...
Yuan 6th Gear January 20, 2010 Share January 20, 2010 since we are in this topic.... normally how long will stock rubber engine mounting last ??? 3yrs ?? 4 yrs ?? Depends on the driver's usage and mileage of the car. Link to post Share on other sites More sharing options...
Yuan 6th Gear January 20, 2010 Share January 20, 2010 Hi anyone knows if there is a way to change for engine mounting rubber cheaper? I was quoted at 380++ for the rubber, and I saw online that the rubber is less only around USD35 per pair online, but they only have it for left hand drive. Any kind soul can help to provide advise if there is cheaper alternative? My car is a Suzuki Swift 1.5. My OEM engine mounts cost about S$460 including labour. I am not sure whether your above quote includes labour. Link to post Share on other sites More sharing options...
Nmnhnlm Clutched January 20, 2010 Share January 20, 2010 My OEM engine mounts cost about S$460 including labour. I am not sure whether your above quote includes labour. WTF so expensive!!! Even mountings for my 520i dont cost anywhere near there!! I just change them myself. A bit of hassle but still ok. Link to post Share on other sites More sharing options...
A_korusawa 5th Gear January 20, 2010 Share January 20, 2010 You can buy the mountings and change youyself. You can use rubber mountings or those poly urethane aftermarket ones. I don't like Hydraulic mountings cause it leaks as it ages. Used to have a 318is and 520i. Hyro mountings, sucks. And still have vibration. hi, my car is not swift . . . . you mentioned "rubber mountings or those poly urethane aftermarket ones". ok, I can buy the OEM rubber type from stockist. but, what' bout the poly urethane types??? thanks Link to post Share on other sites More sharing options...
Celicar Turbocharged January 20, 2010 Share January 20, 2010 WTF so expensive!!! Even mountings for my 520i dont cost anywhere near there!! I just change them myself. A bit of hassle but still ok. Wow, that must have been quite a feat. Don't you have to take out at least some parts of the engine to do so? I think I've to change mine as well, the vibration of the car seems to be getting more pronounced and I'm not planning to change ride any time soon. Link to post Share on other sites More sharing options...
Hermitage 1st Gear January 20, 2010 Share January 20, 2010 Hi anyone knows if there is a way to change for engine mounting rubber cheaper? I was quoted at 380++ for the rubber, and I saw online that the rubber is less only around USD35 per pair online, but they only have it for left hand drive. Any kind soul can help to provide advise if there is cheaper alternative? My car is a Suzuki Swift 1.5. One word, 2 syllables...JAYBEE Changed mine there for about RM550 for the whole set including transmission mounts. Mine's not a Swift though, but I've seen quite a few local units running around there, so aftermarket original/OEM parts should be quite easily available... Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear January 20, 2010 Share January 20, 2010 wow i was quoted 1000 for my mitsu mountings. omg! lucky haven change. any recommendation for workshops for mitsu cars? Link to post Share on other sites More sharing options...
Silver_blade Turbocharged January 20, 2010 Share January 20, 2010 WTF so expensive!!! Even mountings for my 520i dont cost anywhere near there!! I just change them myself. A bit of hassle but still ok. Depend on which mounting eg. sides, center, etc....Some are cheaper, while those 'hydraulic' types are more expensive. Link to post Share on other sites More sharing options...
Yuan 6th Gear January 20, 2010 Share January 20, 2010 WTF so expensive!!! Even mountings for my 520i dont cost anywhere near there!! I just change them myself. A bit of hassle but still ok. Expensive meh? The pricing range is around there when I ask a few workshops and even my stockists for my Jap made car. For my Jap made car, engine mountings cannot be changed by layperson like myself. Need a mechanic to do it. There are parts that need to be dismantled to change the mountings and only a trained person can do it. Link to post Share on other sites More sharing options...
Kwanheng 1st Gear January 20, 2010 Share January 20, 2010 Hi there, I was told that the engine mounting for Manual Car is not suitable for an Auto Car. The Manual Car engine mounting is hard and the Auto Car will have vibrations. Is it correct? Thanks Sucker! really good lie lol how can this be possible? Link to post Share on other sites More sharing options...
Oogmsn Neutral Newbie January 20, 2010 Share January 20, 2010 Hmm. 380++ seems abit ex? What registration year is your Swift? Sports Edition? Kimkichin, mine is a 2005 model - SWIFT 1.5 AT. Basically, the problem started recently when I accelerate too suddenly, there will be a slight "thump" sound coming out from the engine area but no other issue when driving it. The workshop told me it's that problem with the engine mounting rubber & quoted me that price. What's the normal rate? Link to post Share on other sites More sharing options...
Byond 1st Gear January 20, 2010 Share January 20, 2010 bro, i also changed my engine mountings (mazda 2sp) for $460 last OCt 08... changed 3 of them... after changing, ride was smooth with minimal vibration... Anyway, mountings are wear and tear item... my driver's side mounting leaks, there is a crack at the rubber joint, which causes the oil to leak onto my engine bay...a very messy affair... ↡ Advertisement Link to post Share on other sites More sharing options...
Teana repair/parts
Teana repair/parts
SCHNELL Engine Oil 5W40
P2096 Check engine light
