Genie47 1st Gear October 27, 2004 Share October 27, 2004 Like Tcl099 has said the drain plug is easily accessible w/o jacking up the car. It faces towards the rear and needs a 19mm socket or 3/4" to loosen. Now the word is to loosen. I spent a great deal of time and effort loosening. Those SA mechs could be bulls in real life. Strong but very little brains. I am taught for oil change you finger tighten the drain nut only. The oil gushed out when I removed the plug. I waited two hours for the engine to cool down to warm status. Actually until the exhaust pipe is easy to touch. I got burned bad when I enthusiastically started on it right away. Now the drain plug is facing towards the rear of the car. The plug has a number 8 on it and has a washer. I took care not to lose especially the washer. Now the oil is still draining (into a cheap tupperware container). I have those big metal tin for gasoline which I intend to store the used oil until disposal. I don't mind paying for disposal. $5-10 should be good because you cannot get a $10 labor charge for oil change. What is going inside? Conoco Hydroclear Super All Season 5W30. BTW I called up SA to fix an appointment for the 20k which they say is fully booked. So I scheduled one for Mon. They want me to be there early at 8am so that they can started on the A/C dryer issue . With my DIY oil change, I guess they will have less to do but just inspect the the nuts and bolts are tight and in order. ↡ Advertisement Link to post Share on other sites More sharing options...
Tien Neutral Newbie October 27, 2004 Share October 27, 2004 BRAVO!!! BRAVO!!! you are truly the master of darkside... care to take me in as apprentice? the washer need to change with every oil change? cos SA always charges me for washer when i go for servicing.... may be can get at song yi? or it's just normal washer available at any hardware store? Link to post Share on other sites More sharing options...
Dwoon 1st Gear October 27, 2004 Share October 27, 2004 I suppose it's easy when you have access to the car jack/lift which can raise the car while one can walk under and fiddle. But to do a back crawl under ...... I'd pay the $20 bucks labour to have the oil changed. Link to post Share on other sites More sharing options...
Godfinger Neutral Newbie October 27, 2004 Share October 27, 2004 Hi Can DIY own Oil but still go in for 20k svc? Wont they be surprise that we are suppose to let them change the oil? Will they turn the table around and void the warranty just becos we DIY oil but still go for 20k svc?? Link to post Share on other sites More sharing options...
Superchevy 1st Gear October 27, 2004 Share October 27, 2004 dont need to change the washer but those sa fellow will change for you 50 cent .as for the 20k servicing they quote me $200 plus if want to change air con dryer $400 plus . i tell them to go and sleep i buy oil and filter go to a shop get it change and service with all oil check all item i bring my self . total labour $20 leave away a happy man Link to post Share on other sites More sharing options...
Godfinger Neutral Newbie October 27, 2004 Share October 27, 2004 Hi These washers are very cheap thing but just to make sure that they dont soften at high Temp, get the orginal Engine Oil Drain Plug Washer. I wont DIY oil myself cos I have changed engine oil for numerous times during my army days.. Hand oily, shirt oily, head giggy, hand itchy.. Haha.. Fun and save $ but .. It all depends on individual. Link to post Share on other sites More sharing options...
Genie47 1st Gear October 27, 2004 Author Share October 27, 2004 20 bucks still better than SA. Link to post Share on other sites More sharing options...
Godfinger Neutral Newbie October 27, 2004 Share October 27, 2004 Hi So the matter of fact is that Can we go for 20k w/o SA changing engine oil? Just let them change Dryer and misc checking will do.. IS that possible?? Link to post Share on other sites More sharing options...
Genie47 1st Gear October 27, 2004 Author Share October 27, 2004 The requirement to go for the 20k is to replace the A/C dryer. They cannot turn around and void it. Your engine oil is clean that is a good thing. Link to post Share on other sites More sharing options...
Genie47 1st Gear October 27, 2004 Author Share October 27, 2004 I didn't use a jack or a lift. This car's drain plug is very easily accessible w/o the use of any lifting equipment. Also being a little thin helps. This will not be possible if lowering springs are installed. Link to post Share on other sites More sharing options...
Superchevy 1st Gear October 27, 2004 Share October 27, 2004 as long as the air con is cold and function well what the point change the dryer it cost a bomb u know u ask around with the air con man they will tell u dont need to change , after the 20k just drama and go back to continue the next normal servicing just to continue the warranty period / Link to post Share on other sites More sharing options...
Godfinger Neutral Newbie October 27, 2004 Share October 27, 2004 Hi So after minus the Oil change, Air filter change and spark plug change, how much will it roughly cost for 20K. Really can work anot? If can then I will change Engine oil outside and send in for A/C dryer change only for 20k svc. Link to post Share on other sites More sharing options...
Genie47 1st Gear October 27, 2004 Author Share October 27, 2004 (edited) Will know by Mon. Penalise me for being a handyman taking care of my car? Wait and see the fireworks if they make that charge. Edited October 27, 2004 by Genie47 Link to post Share on other sites More sharing options...
Godfinger Neutral Newbie October 27, 2004 Share October 27, 2004 Hi The dryer is a very cheap stuff. Part number is #96539635.. But what to do.. Want warranty then must follow their instructions loh. Link to post Share on other sites More sharing options...
Superchevy 1st Gear October 27, 2004 Share October 27, 2004 last week i call for the 20k full check plus change things need to replace is $200 plus . if want to change the dryer is about $400 odd i call and check that why nearly fainted. so decided to do outside and forget the 20k done in SA. Link to post Share on other sites More sharing options...
Godfinger Neutral Newbie October 27, 2004 Share October 27, 2004 Hi Let us know the outcome on Monday. Whether it is possible for your encounter. Is it is poossible then all of us will go suite. Link to post Share on other sites More sharing options...
Genie47 1st Gear October 27, 2004 Author Share October 27, 2004 (edited) These washers are called crush washers. There are many types, aluminium, copper or rubber types. Would like to know where to buy. Only getting US sources from BITOG. The one I'm seeing now looks like copper. I will flip it to present a new sealing surface. Edited October 27, 2004 by Genie47 Link to post Share on other sites More sharing options...
Godfinger Neutral Newbie October 27, 2004 Share October 27, 2004 That means it may not be compulsory for the A/C dryer change? I am confused.. Dryer is compulsory for maintaining of warranty or optional? ↡ Advertisement Link to post Share on other sites More sharing options...
LATEST!!! Just out dictionary for new bengs
Just passed my PPCDL, wats next???
Tool to change Spark Plug
Change Disc Rotors
Change Disc Rotors
X for twitter change request
