Jiayong 3rd Gear November 14, 2004 Author Share November 14, 2004 CR? whats that? pls enlighten me..yeah...the compression not totally even...one of them giving out 170 while the other 3 is at 180. ↡ Advertisement Link to post Share on other sites More sharing options...
Normal_aspirated Clutched November 14, 2004 Share November 14, 2004 (edited) CR = compression ratio. Worn out piston rings or valve seats, loss compression and power. 170 to 180 not very far apart, maybe can drag abit longer for next overhaul. Edited November 14, 2004 by Normal_aspirated Link to post Share on other sites More sharing options...
Jiayong 3rd Gear November 14, 2004 Author Share November 14, 2004 are they really able to port and polish till totally identical? cos this figures was after a port polish job. my mech say that small differences is ok...but other forum members think that is it a big case and i shouldnt settle for anything less. Whats your opinion? Will this small difference lead to a big problem in the future? Link to post Share on other sites More sharing options...
Normal_aspirated Clutched November 14, 2004 Share November 14, 2004 (edited) are they really able to port and polish till totally identical? cos this figures was after a port polish job. The slight difference wont cause much problem later. maybe that (reads 170) particular valves and valve seats need to redo...... Maybe guru Genie care to comment? Edited November 14, 2004 by Normal_aspirated Link to post Share on other sites More sharing options...
Guyver 1st Gear November 16, 2004 Share November 16, 2004 gaskets changed liao..a whopping $400 mann...sigh...my wallet as thin as me now. Old car is like that one lah.... at least u are young.... Link to post Share on other sites More sharing options...
Slinky Neutral Newbie November 17, 2004 Share November 17, 2004 I had this prob b4 on my starlet years back. Two days b4 it broke down, heard sounds of boiling water when I off engine but still didn't suspect anything. In the end, while I was on the way to NTU from Sengkang, engine temp shot up to the reds at CCK on KJE. Had to stop the car at the road shoulder and called my dad and mechanic. Waitied abt 20min and many cars and lorries just slow down and never help. Finally got a kind ah-neh stop and help me top up radiator water and I quickly drove to NTU. 5 Hrs later, I asked my friend in NTU help check again and he topped up water for me again. This time, car only managed to last till Mandai from NTU before it shot to the reds again. Finally, mech sent tow truck to tow my car to workshop and repairs costed me almost $500++ for a new radiator, gasket, water pump, etc . After this incident, I learnt to take care and pay attention to car but it was an expensive lesson. Link to post Share on other sites More sharing options...
Jiayong 3rd Gear November 17, 2004 Author Share November 17, 2004 yes mann....we must all take care of our babies..the slightest difference in behaviour...we gotto check it out liao.. anyway..like your carebear...used to have the exact same one when i was young that i did hug to sleep..haha.. Link to post Share on other sites More sharing options...
Slinky Neutral Newbie November 17, 2004 Share November 17, 2004 Hey! I'm still hugging my care bear to sleep. Sometimes, I share it with my panda hubby. Its very cute and cheerful right? Makes u wanna hug & kiss it.. Anyway, in case you're interested, here's the official care bear website : http://www.care-bears.com/ ------------------ Care Bears STARE! Link to post Share on other sites More sharing options...
Ivanyap84 Neutral Newbie July 21, 2011 Share July 21, 2011 So sry to hijack e thread but i got a major problem... i just encounter a strange problem on my forte... My engine temp went all e way to the HOT point when i was idling just now.. But when i move off, it drop back to normal... And my aircon was also affected when it went to H.. But it become ok once the engine temp drop back to normal range. Anyone can advice me on this???? Link to post Share on other sites More sharing options...
Ithunk 1st Gear July 21, 2011 Share July 21, 2011 check yr coolant Link to post Share on other sites More sharing options...
Jchuacl Clutched July 21, 2011 Share July 21, 2011 Are your both your fans working? So sry to hijack e thread but i got a major problem... i just encounter a strange problem on my forte... My engine temp went all e way to the HOT point when i was idling just now.. But when i move off, it drop back to normal... And my aircon was also affected when it went to H.. But it become ok once the engine temp drop back to normal range. Anyone can advice me on this???? Link to post Share on other sites More sharing options...
Ivanyap84 Neutral Newbie July 21, 2011 Share July 21, 2011 I did check and it look ok... Fan is also running... Link to post Share on other sites More sharing options...
Watwheels Supersonic July 21, 2011 Share July 21, 2011 So sry to hijack e thread but i got a major problem... i just encounter a strange problem on my forte... My engine temp went all e way to the HOT point when i was idling just now.. But when i move off, it drop back to normal... And my aircon was also affected when it went to H.. But it become ok once the engine temp drop back to normal range. Anyone can advice me on this???? Radiator fan not working. Your aircon is also sharing the same fan. Common for some make of cars for them to share the same fan among radiator and aircon. That's why only when car is on the move there's air movement to cool the radiator and aircon, when you stop the car the water temp. goes up and aircon not cool. Pop open the hood and on the engine. you should be able to see the radiator fan not working. Link to post Share on other sites More sharing options...
Jchuacl Clutched July 21, 2011 Share July 21, 2011 Both fans are running? You said fan which I presume only 1 fan is running. I did check and it look ok... Fan is also running... Link to post Share on other sites More sharing options...
Ivanyap84 Neutral Newbie July 21, 2011 Share July 21, 2011 Confirm e fan is working... Unless there's another fan? E big one behind e radiator? Sry ;p Link to post Share on other sites More sharing options...
Jchuacl Clutched July 21, 2011 Share July 21, 2011 There should be 2 fans. Use a torchlight and see. Confirm e fan is working... Unless there's another fan? E big one behind e radiator? Sry ;p Link to post Share on other sites More sharing options...
Ivanyap84 Neutral Newbie July 21, 2011 Share July 21, 2011 2?? Okok.. I go down n check again.... Link to post Share on other sites More sharing options...
LoverofCar 6th Gear July 21, 2011 Share July 21, 2011 So sry to hijack e thread but i got a major problem... i just encounter a strange problem on my forte... My engine temp went all e way to the HOT point when i was idling just now.. But when i move off, it drop back to normal... And my aircon was also affected when it went to H.. But it become ok once the engine temp drop back to normal range. Anyone can advice me on this???? check you radiator fan....could be it is not working.. ↡ Advertisement Link to post Share on other sites More sharing options...
Lower your car interior temp when parking in the hot SUN
Engine Mounting
Engine Mounting
MOM help FTs look for jobs ?
