Car Engine Temp rising up!!! Help!!
Jiayong
I only see 1 fan... Hmmm... But now like ok liao leh... Aiyo!!!
Haizz....
could be themostat that cut in and out the fan abit siao...Bring to AD lah since Forte should be still new and under warranty right?
Haizz....
I had an experience on my car...the temp rise up and at the end is because radiator got jammed....coolant flow affected....AD changed my whole radiator....luckly under warranty then....
Interesting, I would expect to have 2, 1 for redundancy in case the other fails. Probably do a check at the AD to be sure as signs like this don't come without a reason.
Haizz....
Agreed...over heating can have many implication and damage....
Seems like ok liao leh.... Went to jb and back to try... Dunno wat is wrong........ Anyway gg down to let them check tomolo... But anyway thanks bros!!! Cheers... :)
Oh My God!! it came back....... tot ok liao.. went back to park the veh... den it start again... damn unlucky................. [bigcry] [bigcry] [bigcry]
Check ur car at stationary with the engine running with and wifout aircon on,see if ur fan is moving. Check ur coolant level n radiator hoses for leaks or bloatedness. Bloated is a sign ur fan not working or intermitten or ur fan cutoff at wrong timing. There is something call a coolant temp sensor connected to ecu. Maybe that is faulty. Or blockage in radiator as per wat one of the bros here mention.
I assume that the temp is now working properly and not at the H zone.
When the engine is cold, the fan may not start until certain temp is reached or the aircon is switched on. Maybe after driving a while and finished parking the car, don't switch off the engine 1st - check if the fan is running without the aircon running - if the fan is running without the aircon running and the temp is at the normal operating temp - the coolant temp control for the fan.cooling is working.
I suspect it's the motor that runs the radiator fan. The motor have this set of carbon brushes, I think it's going to wear out soon.
Hypersonic
Either your radiator fan is not working or radiator pipe is leaking, which will lead to engine temp rising.
when i start engine, will the fan starts straight away??
Fan will only kick in at certain temp, unless your temp sensor kaput liao, got check your coolant or are u using the correct type, check got engine oil, or could be your O2 sensor faulty liao.
Try flushing your radiator completely first, its not expensive
Edited by KaKiLang
i also just changed my water radiator tank (plastic type).
heng ah...discovered it the same day when the tube started leaking.
Like a hippo, it drank 4litres for less than 20KM distance
