Saltedeggyolk 1st Gear March 19, 2017 Share March 19, 2017 Just scrapped my Altis 07. I'm looking for 08 March/April Toyota Altis. Axio 07 model with parf is fine too. Anyone looking to sell can let me know, we can do direct-direct owner transaction. Pm me for a discussion :) ↡ Advertisement Link to post Share on other sites More sharing options...
Drion 2nd Gear March 19, 2017 Share March 19, 2017 I'm hunting down PS4 with load index of 91.Think u need to special order from michelin ad Link to post Share on other sites More sharing options...
Kklee 6th Gear March 19, 2017 Share March 19, 2017 Think u need to special order from michelin ad AD got only 94W. PI have 91 but out of stock. Link to post Share on other sites More sharing options...
Jtan88 Neutral Newbie March 22, 2017 Share March 22, 2017 Hi I'm buying a iron gun body kit Toyota 86 for 90k. Four yr old. Apparently has two owners already. Anyone know anything bout it? Link to post Share on other sites More sharing options...
Wish69 2nd Gear March 23, 2017 Share March 23, 2017 Hi I'm buying a iron gun body kit Toyota 86 for 90k. Four yr old. Apparently has two owners already. Anyone know anything bout it? Are you a first timer buying a sport car? If answer is YES, I suggest you rent a 86 and test drive for a month whether it suit your driving style and comfort on the road before commit. The reason is that the trade in value of sport car is super low...the dealer will tell sport car is very hard to sell and somemore you are the third owner. You may also pay around $200 to the dealer for STA/Vicom inspection report. Good Luck!! Link to post Share on other sites More sharing options...
Jtan88 Neutral Newbie March 23, 2017 Share March 23, 2017 Yes. Test drived it. Seat is low but comfortable Link to post Share on other sites More sharing options...
Jtan88 Neutral Newbie March 24, 2017 Share March 24, 2017 Will there be any problems driving such a low car over the long run? Link to post Share on other sites More sharing options...
Wish69 2nd Gear March 24, 2017 Share March 24, 2017 Will there be any problems driving such a low car over the long run? Hi bro, that why I proposed you to rent a Toyota 86 for 1 month or 1 week to feel the ride...before commitment. Link to post Share on other sites More sharing options...
Carhorn 5th Gear March 25, 2017 Share March 25, 2017 Will there be any problems driving such a low car over the long run?u will have bad knees if u drive such a low car over the long run! :p but seriously, (a) i assume you are below 30 yrs old. if so, hv you check the insurance cost for a 2 door sports coupe? assuming u are on low or zero NCD. (b) i assume this is the 1st time u are getting ur own car. if so, hv u check the car thoroughly if certain areas have been welded back if it has been involved in accident? © i assume u are getting this as ur 1st car and am unsure about car knowledge based on what i quote ur above statement if so, stick to normal B&B cars my apologies if u feel indignant after reading my post 1 Link to post Share on other sites More sharing options...
rickbath 1st Gear April 3, 2017 Share April 3, 2017 Hey Folks, I've recently purchased a 2nd hand Toyota Axio and at times - especially during a hot day the AC does not perform too well. Recently i experienced that while i was driving and it started to get extremely hot, the AC started to blow not very cold air and after about 5 minutes its back to normal. I went to a shop and they said the only way to fix it is to change the compressor which is about $600-700. Does anyone know if there is a better / cheaper option? 1 Link to post Share on other sites More sharing options...
Wish69 2nd Gear April 3, 2017 Share April 3, 2017 Hey Folks, I've recently purchased a 2nd hand Toyota Axio and at times - especially during a hot day the AC does not perform too well. Recently i experienced that while i was driving and it started to get extremely hot, the AC started to blow not very cold air and after about 5 minutes its back to normal. I went to a shop and they said the only way to fix it is to change the compressor which is about $600-700. Does anyone know if there is a better / cheaper option? You can ask for recon set...cheaper. Alternately, change in JB. Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear April 3, 2017 Share April 3, 2017 Bro, try aircon servicing first... search the forum - got 1 shop specialize in it... AMK area Link to post Share on other sites More sharing options...
leehock13828 2nd Gear April 3, 2017 Share April 3, 2017 Hey Folks, I've recently purchased a 2nd hand Toyota Axio and at times - especially during a hot day the AC does not perform too well. Recently i experienced that while i was driving and it started to get extremely hot, the AC started to blow not very cold air and after about 5 minutes its back to normal. I went to a shop and they said the only way to fix it is to change the compressor which is about $600-700. Does anyone know if there is a better / cheaper option? Which dealer buy from? 1 Link to post Share on other sites More sharing options...
rickbath 1st Gear April 3, 2017 Share April 3, 2017 Alright, will use the search function which i apparently neglected to use ;p I purchased from direct seller. Link to post Share on other sites More sharing options...
Admiralty 4th Gear April 3, 2017 Share April 3, 2017 Hey Folks, I've recently purchased a 2nd hand Toyota Axio and at times - especially during a hot day the AC does not perform too well. Recently i experienced that while i was driving and it started to get extremely hot, the AC started to blow not very cold air and after about 5 minutes its back to normal. I went to a shop and they said the only way to fix it is to change the compressor which is about $600-700. Does anyone know if there is a better / cheaper option? I had similar issue on cx7...change a relay unit at $25, no more issue till I hand over the car...drive to mark cool look for 阿發...do a quick check. Link to post Share on other sites More sharing options...
rickbath 1st Gear April 3, 2017 Share April 3, 2017 I had similar issue on cx7...change a relay unit at $25, no more issue till I hand over the car...drive to mark cool look for 阿發...do a quick check. Cool, it seems they are the pro's in AC. Need to make appt? Any idea? Who do i look for? Sorry but i don't understand Chinese. Link to post Share on other sites More sharing options...
Admiralty 4th Gear April 3, 2017 Share April 3, 2017 I did't make appt...A fren suggested to go there for a opinion. I went early, around 9am. Looked for Ah-Huat. He did a quick check, suggested to change a relay unit. Then aircon margically become normal...no more waiting time for cold air. By the way...my compressor is only 3 yrs old. Suggest you get a check/opinion before deciding what is best... Link to post Share on other sites More sharing options...
SpeedyJIM Clutched April 6, 2017 Share April 6, 2017 (edited) I bought my altis engine mounting at $260.. check did i over paid Edited April 6, 2017 by SpeedyJIM ↡ Advertisement Link to post Share on other sites More sharing options...
Mercedes Owners Thread
Toyota Corolla Cross
Toyota Land Cruiser Mini
Questions about Toyota Mark X
Harrier 2017
Harrier 2017
