Simnon Clutched December 1, 2004 Share December 1, 2004 (edited) Lately, i found that my cooling water temperature gauge needle could not reach the middle position.It is sticking at the low end of the gauge and it does moves. I have checked the wirings and found all to be ok. Do not know if this is related to the quality of the coolant. The car has done about 10,000 km since I took over in May 04. Thank you Edited December 1, 2004 by Simnon ↡ Advertisement Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 3, 2004 Share December 3, 2004 Original meter in the control panel or aftermarket unit ? Link to post Share on other sites More sharing options...
Loner1980 Neutral Newbie December 3, 2004 Share December 3, 2004 I also notice this happening to my car. The needle only rise when i drive without air con. Any advice bro? Link to post Share on other sites More sharing options...
Simnon Clutched December 4, 2004 Author Share December 4, 2004 Hi ! Yeobh It is the original meter in the control panel. I was caught in the jam from JB to SG on thursday evening and the meter moved into the midle position. Do not know if it is time to flush out the coolant and change a new one. Maybe the water fails to heat up or the engine is running cold ? Really put my wits to its end. Cheers Link to post Share on other sites More sharing options...
Simnon Clutched December 4, 2004 Author Share December 4, 2004 Hi ! It looks a bit strange, normally it will shoot up after the aircon is cut in, more load on the engine. Cheers ↡ Advertisement Link to post Share on other sites More sharing options...
Lower your car interior temp when parking in the hot SUN
Feedback
Feedback
Dealer re-sell problem car
Discussion on Gout problem
HDB season parking renewal problem
