Johnnytanki Neutral Newbie October 27, 2005 Share October 27, 2005 May i know which are the 5 pts? Also if i am installing the D1-spec VS which come with 3 pt loop grounding...can i add on additional pt for grounding? ↡ Advertisement Link to post Share on other sites More sharing options...
Kanr 1st Gear October 27, 2005 Share October 27, 2005 wats the prices range ,thks??? Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 27, 2005 Share October 27, 2005 definitely u can add more grounding points.. some suggested points: Cylinder Head = Engine Block - Distributor = The part which separates electrical power into each plug - Bulk Head = The iron wall between engine bay and car interior Suggested connecting points - Example Two A = 1st body earth for electrical parts - B = 2nd body earth - C = Engine block - D = Throttle body - E = Alternator - F = Battery negative terminal - G = 3rd body earth ** Please click on the above image to get closeup views of each portion. Suggested connecting points - Example Three (recommended by Sigma Automotive) 1) Engine head near spark plugs - better spark plug performance 2) Engine head near stock earth wire - better injector & ignition coil performance 3) Near alternator - reduces power loss 4) Near cell motor - quicker engine start-up 5) Stock body earth cable for electrical parts - electric parts perform better 6) Stock body earth cable near battery - enhance general stock body earth conduction Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 27, 2005 Share October 27, 2005 juz grounding cables?? from 22-70 bucks. typical installation with normal grounding cables around 50 bucks Link to post Share on other sites More sharing options...
Johnnytanki Neutral Newbie October 27, 2005 Share October 27, 2005 Under your example 2....u mention click on the above picture...but cant see any picture leh Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 27, 2005 Share October 27, 2005 paisay..pic gone..the details were from another mcf bro Link to post Share on other sites More sharing options...
Hobby Clutched October 29, 2005 Share October 29, 2005 Let me clarify. Yes, I got three brother after install my VS, the battery went dead. First car, the battery already 18 month liao.Battery dead after 2 hour of VS install. Second Car, the battery water total dry up.Battery dead after 3 day of install. Third car, it happened that the maintain free battery was about a year liao. Battery dead after about 1 month. I have installed my VS in April 05, battery still going strong. Recently went to CAS,tested my battrey is still good condition. All the above mentioned cases even it dont install teh VS, teh battery will kaput anytime. cheers!!! Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 29, 2005 Share October 29, 2005 thks for clarification bro..in that case i shd have installed Max volts...nvm... Cheerio! Link to post Share on other sites More sharing options...
Wayhow Neutral Newbie June 12, 2006 Share June 12, 2006 Once the engine is running the alternator charges the battery and supplies power to all the systems. That is why you can still run around with an almost dead battery but not with a dead alternator. The alternator's supply isn't that steady so the go in-between is the battery.the last time my alternator died, i push start the starlet all by myself open door, neutral gear and push until rolling... then faster jump in and before the car slows to a stop, engage 2nd gear, rev, and crank the ignition... once started then no problems le... but i wouldnt wanna do that again Link to post Share on other sites More sharing options...
Chogokin 1st Gear August 25, 2006 Share August 25, 2006 Sun Automobile's Hot Inazma Hyper Voltage System Type MR was at S$260 with free installation, works and many sought after it. Where can I get it done ? Thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Battery Voltage up & down
Grounding VS Voltage stabalizing
E Power Voltage Stabilizer
2016 Estima Driving voltage 12.2V. Normal?
Voltage stabiliaer for home
Voltage Stabilizer,Is it necessary?
Video on How to detect starter voltage drop
Voltage drop from 13V to 12V within an hour
