Osiris 1st Gear April 12, 2005 Share April 12, 2005 I tot alternator is the one charging the battery and the battery supply power? ↡ Advertisement Link to post Share on other sites More sharing options...
Maded Neutral Newbie April 12, 2005 Share April 12, 2005 The VS contains capacitors. This helps "steady" the currents - The DC current provided by the alternator is DC insofar as it does not dip below the 0V line for a negative voltage return. Some companies sell aftermarket tachometers that connect to your cigarette lighter outlet! This proves that the device can actually read the pulses present in the outlet "DC" supply to display the RPM. The capacitors present in the VS help with momentary voltage requirements, such as during cranking - your headunit will stay alive... Link to post Share on other sites More sharing options...
DarkLord 1st Gear April 12, 2005 Share April 12, 2005 Aiya I know got cheaper ones for only $75 even cheaper if you DIY. But $85 include pivot VS ?? Got fake look alike from Taiwan leh. And then the thickness of the cable used. Got gold plated or not, got rubber insulation ?? It's not Pivot. But it works just as well. The thickness of the cable is 8, with thick insulation. Link to post Share on other sites More sharing options...
Genie47 1st Gear April 12, 2005 Share April 12, 2005 Once the engine is running the alternator charges the battery and supplies power to all the systems. That is why you can still run around with an almost dead battery but not with a dead alternator. The alternator's supply isn't that steady so the go in-between is the battery. Link to post Share on other sites More sharing options...
Vtim 3rd Gear April 12, 2005 Share April 12, 2005 I've travelled in a car with an almost dead battery before. The alternator was doing the job as long as the car is running. Have a dead alternator, forget about travelling far even if your battery is alive. that's why, the important thing is the Alternator but there is one condition that you'll won't be able to jump start a car with a dead battery, ie, the battery have short circuited happens to my friend's 33 QV, wasn't able to jump start, check the batt with a meter & discovered that it had short circuited I Did suggested to him to remove the battery connection & jump start then drive to a shop to change batt but he wasn't keen Link to post Share on other sites More sharing options...
Normal_aspirated Clutched April 12, 2005 Share April 12, 2005 It's not Pivot. But it works just as well. The thickness of the cable is 8, with thick insulation. tats wat is meant by generic branding. Link to post Share on other sites More sharing options...
DarkLord 1st Gear April 12, 2005 Share April 12, 2005 Yupz.. As they are using the same principles... Link to post Share on other sites More sharing options...
Roy669 Neutral Newbie April 15, 2005 Share April 15, 2005 Logically make sense! Link to post Share on other sites More sharing options...
Slonez Clutched April 21, 2005 Author Share April 21, 2005 (edited) Just for fun, I install the Pivot VS (grey box). Immediately I can feel better engine response, smoother rev, similar to the effect I get when I had the E-Power VS. IMO, VS really works but you cannot expect huge boost in power, FC, etc. But for $100+, I think it is worrth it. Edited April 21, 2005 by Slonez Link to post Share on other sites More sharing options...
Lawsu Neutral Newbie April 21, 2005 Share April 21, 2005 Hi much exactly u pay for??... U got do any grounding as well? Link to post Share on other sites More sharing options...
Slonez Clutched April 22, 2005 Author Share April 22, 2005 The Pivot cost me $130 inc installation & a simple small bracket. My grounding was done 2 mths ago in JB, cost RM90. Link to post Share on other sites More sharing options...
Lionheart7004 Neutral Newbie April 22, 2005 Share April 22, 2005 Check out the E-Power too. I install it last 2 weeks and i do feel better response on my car. At least, i can see better power stability on our ICE too.. Link to post Share on other sites More sharing options...
Gary84 1st Gear April 22, 2005 Share April 22, 2005 hi to all bros...i called up a mobile accessories company tdy to find out abt their Pivot voltage stab. What that guy told me was that pivot this brand kinda outdated liao...Alot of pple complained gt probs. He also added that in Taiwan or Japan now, digital ones are the in-thing.....Asked abt the price, he said $275 plus installation....Any bros can verify??? Link to post Share on other sites More sharing options...
Slonez Clutched April 23, 2005 Author Share April 23, 2005 Chances are that the Pivot price ia already very open so no lobang or incentive for him to sell. New digital version probably give him better profit margin since it is not common yet. If a passive one like the Pivot got problem, what make the "digital" (I assume it is active) will be less problematic? Link to post Share on other sites More sharing options...
Gary84 1st Gear April 23, 2005 Share April 23, 2005 well makes me wonder also sia....He say if want pivot one, can gif me for 85 cos nobody want liao...But he say i scared your car gt prob after that then cum find me again... Link to post Share on other sites More sharing options...
Slonez Clutched April 23, 2005 Author Share April 23, 2005 Pivot got "chiong" one, original one should cost around $100+. Maybe that's why got problem. Link to post Share on other sites More sharing options...
Gary84 1st Gear April 23, 2005 Share April 23, 2005 icic...do u have a volt. stab urself?...If yes, which one u using?? Link to post Share on other sites More sharing options...
Slonez Clutched April 23, 2005 Author Share April 23, 2005 I had the E-Power then Pivot Sound, both work. No problem recommennding them. ↡ Advertisement Link to post Share on other sites More sharing options...
Battery Voltage up & down
Grounding VS Voltage stabalizing
E Power Voltage Stabilizer
2016 Estima Driving voltage 12.2V. Normal?
Voltage stabiliaer for home
Voltage Stabilizer,Is it necessary?
Video on How to detect starter voltage drop
Voltage drop from 13V to 12V within an hour
